Question about Cobra 29 LTD CB Radio
Antenna We are using our cobras as a way to talk between different employees inside a building and was told that placing a magnetic antenna on the tin roof of the building will give enough ground. However the red light lights up on the radio saying it is out of tune. Do I need to go to a base station antenna when the people that are using it are only 100 ft apart.
  • 1 more comment
  • Anonymous Nov 08, 2007
    my radio has the red antenna light coming on and also no sound what could be the solution?
  • dei622 Aug 19, 2008
    i have the same problem,i have a wilson silver load antenna with 9 ft coax.when mounted to the cab roof or mirrors the antenna light comes on.would a heavy duty ground cable from the mount to the frame of the truck do the trick.this is the first time this has ever done this.
  • ldo311 Mar 28, 2009
    tried to put a browning model BR28 broadban anntenna on a 77 chev. pickup on the cab using a magnetic base. Is it sometimes necessary to shorten the stinger on the anntenna. Because at this point almost all the way drawn out almost at a 2
  • 126 Answers
Checking and setting the swr can only be accomplished with an inline swr meter, not with the radios swr cal switch and the radios meter. Once you have set the swr of the antenna, you cal the radios meter to reflect the actual swr reading and use it like a dummy light on a car, just as an indicator of high swrs. To set your swr:
You must have an inline swr meter, which can be purchased online or from a truck stop. The ones at truck stops are cheap ones, but will do the trick for the most part.
You connect your antenna 18ft coax to the antenna plug of the swr meter, and a jumper coax (any length) to the transmitter plug of the swr meter and then to the radio.
Close all doors and make sure no one is messing around with the vehicle or antenna. You must be set up as you would normally be transmitting.
Now set your cb radio to channel 40 and your swr meter to fwd. Key up your microphoneantenna - 1.gif and at the same time turn the set knob on the swr meter until the needle is at the line that reads set. Unkey your mic and set the the swr meter to ref. Key up again and note what your reading is. Now leave the swr meter in ref and turn the cb to channel 1. Key up and take your reading. If the reading on ch 1 is higher than ch 40 you must raise the stinger on your antenna. If ch 1 is lower than 40, you lower your stinger. You are trying to get lower than a reading of 3 and as close to 1.5 as possible. If you lower your stinger as far into the antenna as it will go and you need it shorter, you cut the bottom of your stinger no more than 1/2" at a time, and recheck your swr reading after each cut.
Once you have gotten the best reading you can, connect your antenna directly back to the radio.
The setting of your swrs is to make your antenna as efficient as possible, by trying to get it as close as you can to a 50ohm impedance. THE ONLY PART OF YOUR SYSTEM THAT CAN CHANGE YOUR SWR IS YOUR ANTENNA, not your coax and not your radio. Your radio and coax can give you false readings, but only the antenna can actually change the swr.
On the swr meter, the fwd/ref switch stands for forward (power that is being transmitted out) and reflected (power that is reflected back into the radio.
Just for information sake, the swr cal switch on your radio is used to set the meter to reflect the swr that your antenna is set at. The meter on your radio is like a dummy light on your car. ONCE AGAIN, YOU CAN NOT SET YOUR SWR ON YOUR RADIO, only the antenna.
Dean
Rollin CBs
Mt. Vernon, TX
Posted on Jan 23, 2008
    Brigadier General:
  • 6,966 Answers
Hi, Other than the ground, another reason the red (SWR) warning indicator lites up is mis-tuned antenna. Ground - for CB to work efficiently, the ground plane must be at least 9 feet; Antenna - the antenna must be tuned to the operating frequency (Channel) of your CB; Both interacts with each other and can cause the red warning light. Any antenna (even a mobile magnetically mounted) will do as long as it is rated for 27MHz, the big issue is how to get a ground plane of 9ft. If you plan to install it on a metal roof, that should be more than good enough to provide the necessary ground plane but your problem would be the coaxial cable going in to your radio (I expect it will be long). If I may make a suggestion, get hold of a mobile antenna with a magnetic mount. Put it on top of a metal filing cabinet, radiator grill or any metal furnishing of your office (as long as aesthetically acceptable to you). Get 2 pcs of an electrical wire (say #14) about 9; put 1 on each side of the base or bottom of the magnetic mount or the metal filing cabinet, the exposed portions may be covered by the carpet, plant boxes or whatever; doesn't really have to be that straight; you can do the same to the metal chassis of the CB radio; you can also put a grounding wire from the chassis of the CB radio to your metal plumbing. You can use the built-in SWR calibrating instrument of the radio to check if you have a low SWR. Ideally it should be 1.5 or lower. Hope this be of some help to your and give you ideas. Good luck and kind regards.
Posted on Aug 24, 2007
Why dont you try some sort of walkie talkie? cb type or even the frs type should work just as well and require no outside antenna.
Posted on Feb 22, 2008
I have had a Cobre 29 LTD Classic, a 29 NW LTD Classic and now a 29 LTD Chrome.It seems that the first two died because of possible bad antenna connections. I was able to calibrate the radios and adjust...
I see two possible problems. First, with a magnetic antenna it is difficult to get the proper ground for the antenna. Make sure the magnetic base is clean as well as where you place it. Second, try running your power lead DIRECTLY to the battery and not using the cigarette lighter. Hope it helps.
Tom
Feb 27, 2013 | Cobra 29 LTD CB Radio
Whats the best antenna and location on an f250 ford p/u ext cab superduty
Something like either a Wilson 1000 or 5000 magnetic mount on the roof--coil and whip unit detach as needed.
Apr 12, 2012 | Cobra 29 LTD CB Radio
Poor reception within buildings that are only 30 mtres away. The antena is situated UNDER a tin roof
tin roof acts as a faradyne cage (http://en.wikipedia.org/wiki/Faraday_cage)
Your antenna will need to be outside of the building and then it will work fine!
Mar 28, 2011 | NetGear PROSAFE ANT2409 Indoor/Outdoor 9...
When explaining that an antenna needs to be 'gounded', does this mean that the bracket the antenna is attatched to needs to be actually hard wired to the vehicle frame or when using a magnetic mount...
Hi, my name is John. Welcome to FixYa. Yes, That is not sufficient enough for your antenna. Need any further information let me know. Thanks for choosing FixYa...John
Nov 23, 2010 | Cobra 29 LTD CB Radio
I have a pickup with a fiberglass bed cover, inside is a Cobra 29. When the k40 antenna is on the bedcover (magnetic mount w/ 6x6 inch metal plate glued to the bedcover) radio will give me an antenna...
Well, the k40 is designed for roof or trunk mount,you would not be getting a good ground,plus you would be getting feed back from cab,no good transmit or receive. Get a good 102" fiberglass or steel whip that's bumper mount,mount it on right rear bumper and you will be good to go.
Mar 28, 2010 | Radio Communications
I have everything hooked up but all i get is static. I had someone from radion shack check the ground and hookup and they said it all looked good. I have tried numerous CB's and different anntennaes still...
Truck boxes may be the best looking place to mount a CB antenna but in my experience they are the worst place for performance.
The 'ground' you need is not an electrical ground but an RF ground. The easy answer is that you need to mount the antenna to a mirror or the bumper or even use a magnet mount instead on the roof. The body of the vehicle provides an RF ground that the small truck box cannot. The only way it might work is to use flat, wide ground straps at all four corners of your box to the bed of the truck. You need metal-on-metal contact.
Feb 07, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
How do i install a cb radio on a pick up truck
You will need a CB radio antenna, The CB radio and mounting hardware as well as the power wire.
Choose a place to mount the radio. Mount it. Run the power wires from the radio to the fuse box. Put red wire in with the fuse that is hooked to switched 12 volt. Ground the black wire to any metal of the vehicle.
Next find a place to mount the antenna. If you use a mag mount, the roof of the cab is a best bet. Run the wire into the vehicle, it can go through the door, just make sure its not going to get pinched.
Hook the coax from the antenna to the radio
Now you have to tune the antenna. this is important because if you don't you you will blow the transmit final transistor out in the radio.
This link will take you to an article that will explain how to tune your antenna.
Nov 04, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
I Cant Pick Up Any Signals On my Cobra 25 LTD 40-Channels Base CB Radio all i hear is nothing. no truckers saying stuff. i just get white noise i do have an antenna. it is a tv antenna w/ bunny ears :) i...
Your problem is probably the rabbit ears. They are for tv in the 54+
Mhz and CB is 27 Mhz. For simplicity, go to Radio Shack and get a back of the radio indoor antenna. They run under $20. If you want to get more; try a roof antenna or a 1/2 wave cb marine antenna outside.
Hope it helps.3
Tom
Jul 19, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
Static and Recieving Problem
make sure people are talking on the channel it may be no one is talking . the static tells you it is receiving something. the cobra 19 and sister radio magnum sold at wallyworld are notorious for having bad solder joints on their boards.
Aug 27, 2008 | Cobra 19 DX IV CB Radio
Cobra 29 LTD CB Radio Logo
846 people viewed this question
Top Cobra Radio Communications Experts
Steve Allison
Steve Allison
Ernest Taylor
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
