Question about KitchenAid KEHC379 Electric Double Oven
Microwave door The door on my microwave has lost the spring that holds the door when you open it. Can I replace it myself and how? Thanks!
    Genius:
  • 1,554 Answers
Before you do you may want to check the warranty.
some parts have a 10 year warranty
http://products.construction.com/portal/server.pt/gateway/PTARGS_0_2_493_204_249_43/http%3B/205.142.52.224/swts_content_files/15315/211253.pdf
Posted on Feb 29, 2008
I recently had a small spring go on the oven door, but before I could put it in, the left side started sticking towards the open position. It is getting harder to open and close now, even with the spr
I would look for something more like a larger spring that the small spring was regulating. The door being askew would suggest that there is some tension that is no longer in place.
Jan 14, 2015 | Blodgett Ovens
We have a classique oven and it wont close properly. It stays open about 25-30mm can you please give us advice? thanks
I presume the gap you are talking about is at the top of the oven door. If so, this means that the door springs are worn/lost their tension. The only way to fix this is to get the springs replaced.
Feb 13, 2011 | Ovens
Microwave door will not latch closed
I just had this problem with a Samsung microwave/hood combo. I pried/popped the inside molding out with a screwdriver. The little lip that the spring attached to had broken. I drilled a hole in the center of the door latch, reattached the spring, replaced in door, replaced inside decorative molding, and fixed in 5 minutes. Thank goodness because it's such a pain to replace these units.
Jun 30, 2010 | Neff B4540 Stainless Steel Electric Single...
Door will not stay closed
Hello,Sounds like the door hinge springs are weak, it will probably be necessary to replace them both.
Thanks
Jun 02, 2010 | Whirlpool GBS277PDS Electric Single Oven
Oven door won't close completely
You will probably have to replace the springs I doubt if they can ve fixed. you can open the door all the way and you will see a hole in the spring just inside the door. you can stick a nail in that hole, both springs that will hold the door open and you can lift the door out and check the springs I will tell you to have patience its not easy.
Apr 21, 2010 | Kenmore 47702 / 47704 / 47709 Electric...
Multiple replacement of Microwave door springs
KitchenAid Architect Series KEBC107KSS Electric Single Oven problem error F1E7
Sep 15, 2009 | KitchenAid KEBC107 Electric Single Oven
KEMC308 Microwave oven door
Had the same problem and bought the part online. It's not difficult to replace, simply hold the door by the handle as you loosen the 2 screws. Put the face of the door on the floor and remove 2 screws holding the plastic insert. You will have to remove the front vent panel (2 Screws) just below the microwave door.Then you might have to move the oven vent over to get to the final 2 screws on the bottom of the plastic panel. Once you have the palstic panel off the springs are exposed, simply look at how it is placed in the holder before you remove the damaged one. Replace and then re-assemle the door.
May 23, 2008 | KitchenAid KEMC308 Electric Double Oven
Kitchenaid Microwave torsion spring replacement
I just replaced torsion spring 4452396 on my microwave. We heard a "pop" and then the door got heavy. here are a couple things I learned...THE HARD WAY!
We had the stainless steel front to the door and needed spring 4452396, not 4451008. The stainless steel door is heavier so therefore a stiffer spring. I'm not sure i could justify the 4x cost in the part...but that's just the way it is. It's a bit of a pain to repair the thing..so it's worth it to get the correct spring. You don't wan to be doing this every couple of of months!
You have to remove the front panel of the door to access the springs. there are 2 of them...they cross each other in an "x" pattern on the lower part of the door. We had to pull the unit out a bit to get the spring in the hole for correct position. No need to remove the door etc. If you need help with this...email me.
My mistake was when I was trying to figure out how to gain access to the springs I assumed you did from the inside of the door. I removed the two black things you see on the lower right/left of the door (screw on the bottom of them) then proceeded to remove the two recessed screws on the inside top corners of the door. Well next thing i know.....CRASH! the whole front of the door fell off and shattered! Come to find out those screws and brackets on the bottom hold the face of the door on. The glass is intergrated into the color panel of the door..so it's one piece! 150.00 later and a new piece of glass/panel i learned a hard lesson.
Let me know if you need help...it's fairly easy to do now that I look back on it. dave dlacki@gmail.com
May 14, 2008 | KitchenAid Architect Series KEMC308KSS...
Whirlpool oven door
Push the hinges out till they click once. At this point, get your nails or screws ready. Use a screw driver and wedge the hinges further apart. When you see the hole in the hinge appear, put the nail in it to hold it open. With both done, drop door in place; open door slightly, and remove nails.
Oct 17, 2007 | Ovens
KitchenAid KEHC379 Electric Double Oven Logo
160 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
