Question about Janome MyLock 634D Mechanical Sewing Machine
Lower looper needle broke
Machine was working great when the lower looper broke,i was informed that it was because the timing was out, my friend who is a mechanic has been for thirty years knows he can replace the looper, he thinks the reason it broke was because the screw was loose and had nothing to do with the timing,as it had been working great, please help with a solution, is it possible for a person with a great deal of mechanical knowledge to do a home repair, thank you
    Problem Solver:
  • 6 Answers
 Well, first of all, while it might be possible, I highly doubt it.
More then likely the timing is off. There are several adjustments that need to be made correctly or you will end up with more problems. Your best bet is to take it to a qualified service technician.
Posted on Oct 10, 2007
I have a funlock 004D/004, the lower looped broke and I replaced it with one I ordered online. It makes a chain when I run it but when I try to sew fabric nothing catches. Any suggestions?
you have to make sure the looper is properly positioned. With the screw loosened slightly you should be able to move the looper up and down slightly, thus adjusting the timing. You are looking for the lower looper tip to come in slightly above the needle eyes, as close as possible without touching. Then the upper looper must come in right behind the lower looper "head" as close as possible without touching. The upper looper should then extend past the left needle by about 2-2.5mm, and the needles will come down before the eye of the upper looper returns to the right.
Dec 12, 2016 | Sewing Machines
Broke a needle, replaced it. Now stitching is all wonky. Rethreaded many times, changed both needles. Adjusted upper and lower loopers. Nothing is working. Worked fine until the broken needle
Um, possibly the machine is out of time--happens frequently when needles break. You can search the internet for sewing machine timing or take it for service.
Nov 20, 2016 | Sewing Machines
Thread broke on bottom looper the first time out of box i had to try and thread and the tension was still tight The bottom threads were not stiching
I'm going to assume here you're talking about a serger. Unthread the lower looper and the eyes of the needle. Set the lower looper tension to 0. Rethread the lower looper, then the needle eyes. Then reset the lower looper tension (try about half a number lower) and see if it chains. If it won't chain, try replacing the needles.
Mar 17, 2014 | Janome Sewing Machines
Correct threading for 4 th. Juki ind. overlocker
Overlockers and or Sergers are ALWAYS threaded the same way. Upper looper, Lower looper, right needle, left needle. If you have a model number for your Juki we might be able to find you more information.
The best way to figure out tension problems is to thread each thread in a different color so you can determine which thread is giving you problems.
These machines can be frustrating and EVERY time the thread breaks you MUST start the threading problem from the beginning... upper looper, lower looper, right needle left needle.
Aug 31, 2012 | Sewing Machines
Bernette 334D bent lower looper
The bent looper needs to be replaced. It is also very likely that the machine has been knocked out of time. Professional service may be needed to get it working again.
Dec 21, 2017 | Sewing Machines
When the needles go down the lower looper move on the back of the needles goin up the lower looper moves in front of the needles and causes the thread brake and makes a craking sound when the lower looper...
I have a Singer 14SH654 Serger, trouble started when I broke a needle. I replaced needle now it does not sew properly with two needles. Can anyone help me
Jul 03, 2010 | Singer 14SH654
Timing on a Huskylock 535D surger
the eyes of the needles must line up with lower looper as they pass (timing) the distance between the needle and the looper must be exact. No distance between them and not touching. yep, that tight. they shouldnt move the needle even the slightest amount as they pass each other, yet no space between them.
Kent
Feb 07, 2009 | Husqvarna Husky 165
Lower loop broke- do I have to start from step one?
yes, take all threads out, and re=thread according to the diagram, following the threading order.
Mar 02, 2008 | White Sewing Speedylock 1600 Mechanical...
Lower looper
It is impossible for a looper to come unthreaded if you are holding one end and the other is still feeding off the spool. Somewhere a thread broke - must be either the upper looper or the needle. Try completely re-threading your machine. Many machines have an "order" they prefer to be threaded. Try starting from the right tension guide and work to the left.
Sep 17, 2007 | Janome MyLock 634D Mechanical Sewing...
Janome MyLock 634D Mechanical Sewing Machine Logo
53 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
