Try reinstalling easy share software/drivers. if that doesn't work then update you computer at windowsupdate.com and use the photo and scanner utility to get the pictures from the camera.
This may be due some or all of the following reason:
Corrupt file-system, corrupt registry entry, improper/incomplete device driver installation or software installation or may be due to a virus infection.
Make sure you have a backup of important files/photos/documents in your system.
Try repairing you file-system using check disk utility that comes with windows. Repair your registry using a registry tool. Update the device driver or the application. esapp.dll & ltdis10n.dll belongs to Kodak Easy Share application. First completely remove the application and try reinstalling it. Have a full system virus scan with latest virus definition update.
Update your windows system with current patches and fixes using Windows Update utility.
All the best
This is the instructions on how to remove existing ESS system in order for you to start on a fresh.
Please follow the instructions:
Uninstall Easy Share software:
Select Start > Settings > Control Panel > Add / Remove Programs. For Windows XP operating systems, select Start > Control Panel > Add / Remove Programs.
Select Kodak Easy Share software.
Select Remove (or select Change, and then select Remove).
Run the Clear utility:
Visit the CLEAR Utility for Kodak Easy Share software Web page at www.kodak.com/go/clear
Click the Download button, and then follow the on-screen prompts.
After restarting your computer, visit the Kodak Easy Share software Web page at www.kodak.com/go/easysharesw and install the latest version of Easy Share software.
It is not possible to email directly from the camera.
If you're experiencing emailing difficulties directly from the Easy Share Software:
Please do a Clean Install on the software:
Possible solutions:
Remember you need to turn the camera on when transferring.
Try a different USB outlet
Try a different cable
Try a different computer.
If all fails please contact KODAK in order to arrange a repair or order a new cable. Remember your USB cable is covered under the same warranty as your camera, so remember your serial number when calling: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
If you suspect it could be directly related to your software.
You need to follow the instructions:
You need to upgrade your version to be compatible with Windows Vista: Please do a Clean Install on the software:
If this fault message is on your computer starting Easy Share Software: Please do a Clean Install on the software:
There is a setting in the easyshare software that allows you to run on startup.. or in your case, NOT run.. I have used easyshare in the past but have not experienced what you see directly, though I have seen the icon sitting there near my clock...
The Kodak Easyshare software just index the pictures they do not store them at all you can locate the pictures on the computer by
Click start then look for search type in in the search box *jpg And it will display all the pictures that you have on your computer
To fix the problem regarding the easyshare software try uninstall it from your computer Then download the clear utility www.kodak.com/go/clear then download the latest version of the easyshare software www.kodak.com/go/easysharesw
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
I have upgraded my Easy share software to version 7.1 ever since I cannot open the program. It comes up with The message of "One or more system DLL's could not be loaded :ES App.dll " then appears the message of "Easyshare unable to run. Please run Setup and choose repair to fix the application.[0,5006,0] " . When I run the repair program, it blocks part way through and the error message of 1334x97x3839719742x appears. Short of getting rid of Kodak off my computer which I dont want to do as I have important pics in the album, and I have a Kodak digital camera. What can I do to fix.
