Question about GE 27GT722 27" TV
Black horizontal lines across bottom 1/3 of screen
Model is 27GT271. Shows a band of distortion (scan lines spaced out) about 2" high at about 5/8 down screen, then picture is normal until about 4" from the bottom where distortion re-occurs all the way to the bottom. Occasional, picture snaps back to normal for a brief period. But always eventually reverts to distortion pattern mentioned above.
  • tobor8man Aug 24, 2007
    Thanks, but solution is far too technical for me unfortunately. If I knew how to ID the vertical supply rectifier diode or what the heck a zener diode or a pumpup cicuit was, I could have probably fixed the darn thing myself by now. The set's not worth taking to a shop so I was hoping there might be a simple, do-it-yourself (layman's) solution. Oh well...I guess it's fodder for our next garage sale.
    New Friend:
  • 76 Answers
This is due to vertical section failure. Change the vertical supply rectifier diode and supply filters. Then check zener diode leakage in pumpup circuit section. Also check any electrolytic capacitors leakage in vertical section. If it is old model tv change vertical height, vertical lenearity presets also. I hope given details useful to you.
Posted on Aug 23, 2007
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Feb 07, 2009 | Proscan PS27123 TV
Toshiba 52WM48 - Dark line across top of screen about 4 inches
replace the vertical ic, LA 7833 and four capacitors near it, i encountered this last two days.change the parts and it ok now.
cost of this parts is about $20.00
Jan 22, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba CF2772B New in 1992. Has black band across the bottom
If the pix was good up until this point, I would take the plunge and repair it, even though it may be close to 200 US...accordianman
Nov 11, 2008 | Toshiba 27A33 27" TV
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
RCA CRT TV thin white horizontal lines
Look for bad capacitors in the vertical deflection amp, and in the pin amp sections. This is common on most of these types of TV sets.
The caps tend to go high in ESR with age. It is best to use an ESR meter to find the bad caps. It will be a lot faster than workign out waveforms with a scope.
Wikipedia explanation about capacitor ESR:
Jerry G.
Apr 23, 2008 | Televison & Video
Open Questions:
GE 27GT722 27" TV Logo
102 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
