Question about Samsung ML 1651N Laser Printer
Samsung ML-1651N Printer
Printer will no longer accept paper feed from paper tray. Only manual feed will work. Is there a simple solution or should I pourchase a new machine?
  • Anonymous Apr 01, 2008
    same problem
I have the exact same problem with my ML-1651N printer. It started out as an annoying problem that i solved by pulling the paper try out and then pushing it back in again. Now that solution doesn't work anymore.
Posted on Aug 24, 2007
SOURCE:
Wheres the manual paper feed on a samsung ml-3051n
The Upper Tray (Tray-1) is the Manual Paper Feed Tray.
CreativeTECH
Jan 05, 2011 | Samsung ML-3051N Laser Printer
Samsung ML-2250 the printer is no longer able to feed paper from paper tray. Just spins and doesn't print.
Hi, the only suggestion I could give you is to look where the paper leaves the tray to make sure there are no pieces from a paper jam. Some people even tried using a vacuum cleaner to try cleaning it out.
Other suggestion is to make sure you have the proper paper size selected.
Start, control panel, printers, your printer, printer preferences.
The mechanism that lifts the paper in the In tray up to the paper wheels may either be jammed or broken.
I guess that will help.
Thanks for using fixya...
Oct 28, 2010 | Samsung ML2250 Laser Printer
The printer stops printing after the first page or so, but if i open & close the paper tray it prints the next page, but then stops againg etc
You probably have it set up for "manual feed" from the printer preferences in your computer. Change it to "paper tray" or "AUTO"
Apr 02, 2010 | Samsung ML 1651N Laser Printer
Printer does not feed paper
Dear sir; That's very difficult to tell you detail how to take apart the parts, but I can teach you a easy way and tricky way, this cause you problem is paper pick-up roller, right above the paper tray. therefor you have move out the tray , remove the toner ctg. flip machine over (bottom up) then you will see the roller very clear, clean up with rubber rejuvenator, try it out, and please let me know how does it work, good luck! HAVE A HAPPY HOLIDAY !!!
Dec 18, 2008 | Samsung ML-2510 Laser Printer
Can't print labels
I found out that each time you print from the manual load tray, i.e. letters and labels, once you have the paper in the manual load tray press print and then press the demo button to start the manual feed. I hope this helps.
Aug 28, 2008 | Samsung ML 1430 Laser Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Paper feed problems with Samsung M-2010 printer
i have an ml-1740. i like it just fine. this week i had a prblem where the paper came out of the printer crinkled on the right side and the printed image was a little tilted. (if i feed through the manual feed it came out perfect) i was going to inspect all of my rubber wheels when i noticed small chunks of paper that had wedged themselves in the paper path from the tray. simple fix -- clear anything and everything from the path 1st! hope this helps someone out there.
Apr 24, 2008 | Samsung Office Equipment & Supplies
Printer not take paper
Look for a small piece of paper or other foreign object stuck in the paper path, or a rubber roller which has gotten slick and will no longer pick a sheet.
A broken gear in the drive mechanism, broken gear tooth, a small piece of broken plastic (from inside the printer itself), all of these can produce a problem like this.
Nov 28, 2007 | Samsung ML 1651N Laser Printer
Samsung ML 1651N Laser Printer Logo
188 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
