Question about Samsung ML 1651N Laser Printer
Dell 1700 Printer
The load/remove light keeps blinking. checked paper tray, path. Removed tray, cartridge, back cover, turned machine off. No luck. any ideas?
    Scholar:
  • 31 Answers
There is a sensor that is under the toner cartridge. make sure that it's sticking up. The fuser in the back of the printer has one sensor flag that is supposed to stick up all the time except when paper goes through it. What I see alot of times is that the sensor flags get stuck halfway down and all they usually need is a little help back up. Sometimes when removing a paper jam from the back of the printer the flag can be broken off, if that happens then your most likely looking at replacing the fuser. If you feel up to it you can take off the two side covers (the left one has a screw half way down in the front that you have to take out first) and then there are four screw on the back that take off the back cover so you can get a look at the fuser better. Remember to look for a screw that attaches the back cover directly to the fuser when you pull take it apart. Make sure there isn't any dust blocking the sensorts. Hope that helps.
Posted on Aug 23, 2007
SOURCE:
I get a clicking noise when I print on a Dell 3115
The print cartridge carrier could be stuck and clicking agains the wall or gears might be clicking.
If your machine doesn't work at all, open the cartridge cover, take the cartridges out, close the cover, wait for it to call the carriage carrier to the side, then turn it off, unplug wait 2 minutes, plug it back in, turn it on, open the cover, install the cartridges back, close the cover and try printing again.
If that doesn't solve the problem follow these steps
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
If the problem still remains
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
After you have done all the suggestions, whats the status of your printer, are you still unable to print? is the printer still just clicking? are you able to remove the cartridges from the machine or is it just clicking?
If your not able to do the suggestions or the cartridges won't come to the center, your printer has a mechanical hardware problem that will require service.
Sep 05, 2009 | Computers & Internet
Printer will not work after paper jam fixed
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Jul 09, 2009 | Canon iP4500 Photo Printer
Paper jam
try this
alternative :
Jun 12, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
alternative :
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
Paper jam ;prints on paper but paper won't come out
hey, go over this:
alternative :
Mar 24, 2009 | Dell 1700n Laser Printer
Paper jam
give this a try
alternative :
Mar 24, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Paper Jam
try these steps
alternative :
Feb 14, 2009 | Dell 810 All-In-One InkJet Printer
Paper keeps jamming even after clearing the path etc.
try this
alternative :
Oct 09, 2008 | Epson Stylus C120 Color Printer InkJet
Paper Jam
hey, give this a try:
alternative :
Jul 25, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Samsung ML 1651N Laser Printer Logo
85 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
