Question about Kirby Ultimate G Bagged Upright Vacuum
Replacing Belt Can't find the manual and it's time to replace the belt. Can someone help with instructions. Thanks!
  • Anonymous Feb 28, 2009
    i think my Kirby g6 is put together backwards. I need help to get a belt installed. the hook is backwards I need pictures
  • 625 Answers
On the front of the power head is a knob with the KIRBY name on it. Rotate this knob in a counter clockwise direction and it will "lift" the belt off the motor spindle. Release the head lever, only one direction it will turn and remove the head. Turn the head over on its back, turn the KIRBY knob to release the old belt. Remove the brush guard by turning the two release fixtures. Remove the guard. Pry the brush out of the head. Remove the old belt. While the brush is out remove any build up of hair and lint off the ends that's where the bearings are. put a few drops of 3 in One oil on the ends. Put the new belt over the brush and re-install the brush into the head. the brush will go in only one way. With your finger pull the belt into the housing and rotate the KIRBY knob until the pawl inside grabs the belt. Re-install the brush guard by engaging the two metal pieces into the front of the head and pull down backwards over the head and rotate the holding clips back horizontal. re-install the powerhead on the machine, lock it in place and rotate the KIRBY knob clockwise. You should be all set!
Posted on Aug 24, 2007
Timing after installing new belt
There are about 3 MAIN delicate issues here, could be needle bar, top shaft or bottle shaft, to understand timing first knowing that needle hook is passing the cusp of the needle on its way up....
Feb 25, 2014 | SewShop.com Singer Model 758 Touch & Sew...
Kirby Sentria brush roll not spinning! HELP!
this video will help you with your problem
Oct 11, 2012 | Vacuums
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
Broken belt on infinity vacum
You may find the belt for your vacuum through the link below. Unfortunately the only way that Shark sells this belt is with both belts as a set, you can not purchase each indiviudal belt separately.
I have also uploaded the instruction manual for your vacuum in a .pdf file on Fixya. Please note that it may take sometimes up to 24 hours for the manual to show up. Please check the following link over the next 24 hours. This instruction manual gives you step by step instructions on how to replace the belt, and also contains diagrams that will help you follow along.
Here's the link where the instruction manual will be downloaded. The belt change instructions are on page 15:
http://www.sharkclean.com/manual/NV31_REV_0706.pdf
Here's the set of belts that go on the Euro-Pro Infinity Upright model NV31, Shark Part Number 1085F:
http://www.govacuum.com/eushrebesetf.html
I hope this was helpful to you in solving your belt problems. If this was helpful please rate the repair helpful by clicking on the thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 25, 2010 | Euro-Pro NV31 Infinity Vacuum
Belt is off
You need to replace the belt. Over time they stretch and wear and then don't stay on and make it so the vacuum doesn't pick up well. Here is the belt you need and a manual you can view which has instructions:
Eureka Maxima Belt and Manual
Feb 07, 2010 | Eureka 4700A Maxima Bagless Upright Vacuum
How to change a broken belt on a eureka surfacemax 300
Here is some info that will help:
You need this belt:
Eureka SurfaceMax 300 Belt
This is the manual with instructions:
Owner's Guide
Jan 02, 2010 | Vacuums
Vacuum is about 4 years old does not pick up well
Have you ever replaced the belt? That is most likely the reason that it is not picking up like it used to. You are actually supposed to change the belt yearly. Here is the belt you need and the manual which has instructions:
Dyson DC07 Belts and Manual
Dec 31, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Kirby Ultimate G Bagged Upright Vacuum Logo
160 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
