Hello: Live in Arizona, and the sun has fried the rubber button cover for our gas grill ignitor. It is battery operated (AAA). It is a built in grill made by American Outdoor grill. The ignitor works fine, but the rubber cap (button cover) is soft (almost melted) and has major cracks in it. Without the rubber cap the button will fall off. Any help, most appreciated.
Thanks!
SOURCE: Gas Grill
The "safety" inside the gas tank has tripped. Close the valve on the tank, remove the hose from the tank, reconnect the hose and SLOWLY open the valve on the tank. This should reset the safety.
SG
SOURCE: Weber Genesis outdoor grill. The ignitor clicks
If you hold down the igniter can you smell the gas coming out of the burners.
Have you disconnected the pipe from the barbie to see if the bottle regulator is actually letting gas through.
Turning the gas on in free air with no one smoking or naked fllames near the pipe is ok
You just crack open the valve a turn or two and you should hear and smell it.
If there is gas coming out og the pipe and not out of the burners then the gas control valve in the barbie is at fault and needs replacing
SOURCE: GE Monogram ZGG27N21CSS Grill
I had the same problem, the burners were corroded. The only way to fix temporarily is to take them out. Once you take them out take out the screw and cover on the end that goes into the gas and try to shake out the rusted parts.
SOURCE: Ignitor Quit Working
Remove the switch and the wire from it as you will have this little switch and a wire push the switch and watch the end of the wire there should be a spark it not you can dog wife check it if you want too. stick the end of the wire to the dog re the wife and push botton if they scream and jump a few feet the switch is good . jus kidding . if it is good just locate the end of the wire so that it is in a more effective position to light the gas,
SOURCE: Conver a 27" built in outdoor grill to a 30"
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Same as above, but with a Thermos bbq
The button can be ordered from Arizona Grill and Hearth ,in Tucson
