Question about Samsung HCL4715W 47" Rear Projection Television
Convergence After 5 years of excellent peformance, the convergence problem began to show up, first as an intermitent loss of convergence over a period of about six months. Finally, yesterday the blue and green curved into a horizontal arc (pin cushion?)ie top and bottom half curved in towards the center of the screen. Blue convergence adjustment now has no effect. Red seems ok as it is still linear and still adjustable. Video and sound is OK. Need advice on possible areas of concern particularly on a most likely chip that governs the green and blue crt convergence controls. The symptoms of intermitent failure to total failure of the convergence adjustment seems to indicate a possible gradual degradation of a certain chip rather than an intermitent connection or a bad solder joint. Any advice from anyone with a similar experience?
  • 2 more comments
  • Fredlee Aug 28, 2007
    Replace both IC's STK392-040 made absolutely no difference to convergence problem ie the blue is offset to the right (unable to adjust) and the green curved towrads the center of the screen (pin cushion). SOmething else the STKs like that drives it?
    Resistances on board associated with the STKs looks OK and checked OK by comparison in-circuit ohms check. Resistances were checked while the STKs were off the circuit board.
  • Leluron Nov 29, 2007
    I believe I have a convergence problem too. No pictures occur. shadowy lines (red, green and blue) bow towards the center of the screen.
    Please HELP.
    Samsung HCL4715W 47 in. Rear Projection Television.
  • mmont0 Jun 04, 2008
    I have the same convergence problem where the red seems ok and the blue and green bow down towards the center. Will replacing the entire board solve the problem?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
Replace both convergence IC's part# STK392-040. Also check for burnt/discolored resistors nearby.
Posted on Aug 24, 2007
  • David Makowski
    David Makowski Aug 28, 2007
    If the convergence IC's heatsink is cold to the touch,you need to check the two 5A micro fuses which supply the +30 and -30 volts to the convergence IC's (they are soldered in small fuses hard to find but look for them right under the heatsinks of the STK's) When the IC's shorted out they opened the fuses protecting the resistors.
Motor spins too slow to make juice.
After six years I'd buy a new juicer, assuming that you have used the current unit constantly over that time period.
May 17, 2015 | Breville Juice Fountain Elite Juicer
Convergence Bad
Changing the convergence IC's could cost $300-$400 total.CRT based TV rear projectors are more or less obsolete now,with everything going to DLP and LCD.These days 5 years is the expected life on these TV's (most extended warranty contracts only cover up to 5 years)
Sep 22, 2007 | Mitsubishi WS-55511 55" Rear Projection...
Convergence problem
The convergence board is bad in this set. Samsung no longer has this board in stock. You will have to take the board out and rebuild it by replacing both of the STK convergence amp IC's These IC's are soldered to the printed circuit board. They will be standing up against a metal plate, called a heat sink. They are black in color and are about 2" by 3" . They have white lettering on them that start with STK and the some numbers. You get those numbers and go to mcmelectronics.com, enter the exact number of the IC and order two of them. Before you install the new IC's you will need to apply some heat sink compound onm the back of the new IC's. This heat sink compound is avaialable thruogh radio shack. Good Luck
Aug 23, 2007 | Samsung HCL4715W 47" Rear Projection...
What year is my oliver backhoe
All desktops are manufactured over a period of years. Subtract six months from the date of purchase, assuming that you bought it new.
Oct 16, 2014 | Computers & Internet
I have a Toshiba 43 inch projection TV. Six months ago the convergance function was repaired by a TV repairman. Now the TV is periodically turning on and off by itself while we are watching it. What...
More than likely, as the tuning is governed by a remote control function, it is a dodgy remote control.
Try putting the remote control out of the room.
Hope this helps.
Oct 31, 2010 | Toshiba 43HX71 43" Rear Projection...
1996 A-4 Intermitent Heater Problem
may need a new heater matrix
Dec 15, 2008 | 1996 Audi A4
Jobri Dolphin 2 yrs old, starts, than intermitant, than stops. Wait few minutes, starts up, does the same
Hello xthus, I suggest first call Jobri LLC at 800-432-2225 ask for Michelle of quality control. If she can't replace the unit ask for any or all technical information. With this info repair is possible with my guidance. Let me know of the outcome. Good Luck!
Oct 02, 2008 | Jobri Health & Beauty
Blue Convergence
You will need to change the convergence amp ICs there are 2 of them they cost around 12 dollars each.
Mar 06, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Hitachi 43fwx20b intermittent vertical hold loss...humidity?
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 27, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Samsung HCL4715W 47" Rear Projection Television Logo
684 people viewed this question
Jerry Greenberg
Jerry Greenberg
