Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD 52525 - Blue Screen RBGHV or YPrPb
One night the TV was fine, but the next morning it had a blue screen with the following message: Check connections or power. The connections for RBGHV or YPrPb may be invalid. The TV then turns off in a minute or two. As far as I know nothing was changed overnight - no kids hitting buttons, power surges, etc. If it matters it is connect to a Time Warner HD cable box with DVR. I checked the YPrPb connections on the cable box and they are secure, but must admit that I really know nothing about either. Thanks in advance, Linda
  • 4 more comments
  • Linday Aug 23, 2007
    Ok, I did that and now the screen does not come on at all. The timer light has a steady green light for a couple of minutes and then the lamp light turns a steady red. It did not do this before. Not that I think unplugging it caused the lamp to go out, but maybe I should mention that right after the problem started when I took the TV off of cable to antenna (via device), it did display the show what was playing on that channel.
    I have tried trying off the TV for several minutes and also unplugging it again with the same results as above. At this point I am not sure if I need to order a lamp or if this could just be a false reading because of the prior problem.
  • Linday Aug 24, 2007
    One thing I forgot to add is that at one point when trying various things (before asking here) I got a green screen with a darker green, jagged, moving oval in the middle. But to be clear, right now I am getting no picture and a steady red lamp light.
    Right now if I can't get a solution here I really don't know whether to pay $300+ for a lamp or pay the fee (at least $150 from what I can determine) to have someone come out.
    Thanks. I will try this in the morning as it is late, but wanted to go ahead and send my email. Hope you don't mind me spelling it out.
    Lindabtx @ yahoo dot com
    It took a while, but I got the code - 34. What is odd is that after giving me the code the lamp light went off and I got the same error message I got in the beginning (check connections, RBGHV or YPrPb) but it was on a rapidly flashing green screen and wasn't very clear. This lasted about 5 minutes and then the screen went blank and the lamp light turned red again. I don't know if it makes a difference, but when the lamp light is red, it is the only light on.
  • Linday Aug 26, 2007
    My husband remembered yesterday that he purchased an extended warranty so we should have the new lamp on Tuesday. He is convinced this is the only problem and doesn't want to do anything else until he installs that.
    If that doesn't fix it he will then have to try the steps you have given him.
    Thank you so much for your help. I'll be getting back to you with feedback if necessary.
  • Anonymous Mar 30, 2014
    where does cable connect to on tv and do they make it with different ends for cable box connection
    Genius:
  • 1,153 Answers
1. Initialize settings by pressing "menu, 2, 4, 7, 0 enter" after settings have been initialized press the system reset button on the front once the LED stops blinking, reprogram the netcommand and tuner settings. 2. (Initialization and reset does not help) Suspect the DM PCB part # 934C116002
Posted on Aug 25, 2007
  • Lashawn Robinson Aug 26, 2007
    May have something to do with cable, but if not and this is all you set then:1. (Lamp may light and go out) suspect bad lamp part # 915P020010 2. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 3. (Lamp may light and go out) Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if low or missing check C9A37 and C9A38 both 3300 UFD 10 V on the Power PCB (part # 930B921002) 4. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 5. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on and does go to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Lamp Power PCB (ballast) part # 939P978010 7. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010
    President:
  • 3,130 Answers
Try unplugging the TV set from the wall for at least an hour or so.
Posted on Aug 23, 2007
  • 1 more comment
  • Larry  Dillon
    Larry Dillon Aug 24, 2007
    Turn the set on. Let the led change to red. Then press and hold the device and menu button together on the front panel for five seconds. Set has to be on in the shut down mode, or you will get a 1,2 code. Let me know what the code is. It will be a two digit code flashing from the LED. I also happen to have the factory service manual if you think that will help. That will save you at least 30 bucks or so. Leave an e-mail address and I will send you a copy. That way you can see how to do the diagnostic codes right from the manual.
  • Larry  Dillon
    I sent you the service manual. Go to the diagnostics page and see what comes up.
  • Larry  Dillon
    Larry Dillon Aug 27, 2007
    Yes please let us know.
SOURCE:
Can you help with this error message: "Check connections or power. The connections for RGBHV or YPrPb may be invalid." Getting no picture for any devices connected to the screen.
There is a problem with the Component video cables and/or connection. These are the 5 RCA cables. Red, Blue, Green and two additonal cables for audio in red and white. Be sure they are connected to the proper ports on each end. Not sure what you have connected to the TV with these cables, but HDMI would be best. You also should have selected "Video" from the Input button on the tv's remote. Check these and follow up if possible.
Jun 30, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen and steady green status light.
mitsubishi will rebuild the chasis for $200 with a 6 month warranty
mits.parts 1-800-553-7278
fax 1-706-654-4299
Sep 02, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen on tv
DID YOU TRY TO CHANGE THE CHANEL MANUALLY? OR CHECK THE INPUT BUTTON
May 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green horizontal lines on screen no picture
The green CRT's (color picutre tube or color wheel, or ballast) will need to be tested for replacement.
It is quite common with these tv's
You will need an ohmmeter and or voltmeter and test each component for currency and accuracy
May 06, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Error message: check connections or power-the connections for RGBHV or YPrPb may be invalid. The screen is a two tone blue and is flashing.
DO NOT do anything to your Mitsubishi WD-52525 until you read this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html . There has been a worldwide problem in computers and TVs over the past several years with faulty electrolytic capacitors (from Taiwan) that decay, dry out, swell and die. The power supply is often the first component to go bad, but other systems also degrade over time. As the forum explains , this problem is widespread in these sets causing multiple types of display problems after several years of use. Mitsubishi is aware of the problem and will cover most of the cost of repairing the chassis, even years out of warranty, but apparently ONLY if you get an estimate from a Mitsubishi certified repair station and contact their customer support BEFORE doing any work on the set. I just followed the recommended procedure on that forum and Mitsubishi is covering half the cost of my $700+ repair when my 3+ year-old set recently died and showed only a blue screen. I'm not sure if this is your problem, but it might be.
Apr 21, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blue screen on WD-52525
Hi, Standby i'll sent you how.for a while
Apr 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
wait the 4 days. any work done on it by a non authorized party could ruin your warranty
Dec 15, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
162 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
