Question about InFocus ScreenPlay 4805 Multimedia Projector
Screen goes blank momentarily
When watching any show on any channel, if there is a flash of bright light or an explosion such as in an action movie. The projector screen goes blank and begins searching for video source, selects video 2 or the cable box source and sets up image and movie or show resumes. It is like I just pressed the video source button. This occurs most every time in an action movie or tv show. What is it and what should I do. PS I do not believe this occurs while watching DVDs
  • 167 Answers
Cover up the infrared remote sensor on the projector. The heat of these colours or something might be messinf with the infrared remote sensor. TRy this and see what happens. It may just be bad contacts. Some projectors just cant handle stuff like this. Some were meant for presentations and presentations only. BUt seriously try covering the remote sensor to see what happens. If it is an older projector the infrared signal detector might be sensitive to bright light or stuff like that.
Posted on Jan 26, 2008
SOURCE:
Youtube just produces a green screen
You may need to update your Adobe Flash Plugin. Use another browser to see if the problem occurs.
Mar 12, 2013 | Photography
My hannspree tv screen goes black blank
If the picture shows a picture briefly upon power up then goes off after a few seconds, you have a back light fault. It could have a problem in the 24vdc circuit, failing back light inverter board, or a blown CCFL lamp.
Dec 05, 2012 | Televison & Video
I have a Sharp 32 inch 720p tv, power works, no other buttons do
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
Nov 05, 2009 | Sharp LC-32SB23U 32 in. LCD TV
DLP projector won't show bright images
This unit should be under warranty and can be fixed, also if it is not under warranty, they can also fix it.
check out fixmyprojector.com
Jul 25, 2009 | Mitsubishi XD2000U Multimedia Projector
Sharp aquos display comes on for a few seconds then blank screen
I have the same problem with my 37" HP which is the same as Sharp Aquos, it's bad backlight inverter boards, the screen comes on for a second then nothing, no menu, no channel change indicator then turn it off and you hear the clicking of the power supply about 10 seconds after.
Jan 01, 2009 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
TV shuts off with high color images . Example: explosions,bright lights etc
Normally, the screen control being up a little to high, would cause this problem. If no one has worked on this unit when it started may be a sign of something else, for example, the 200 volt line may be running a little low. Check the brightness and contrast for starters and if that doesn't help, then, the screen control would be my next step. Hope this helps.
Jun 03, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Pip
On the front of the TV while it is on, press on the ACTION and POWER buttons at the same time and hold them for about 5 seconds until the screen goes blank and comes up with a diagnostic screen. Once that happens release them and press action again to clear the diagnostic information. Now your TV is se back the way it was brand new so you will have to proram the channels back into memory and apply your color,brightness,hue etc..settungs as those have all gone back to factory as well.
Mar 22, 2007 | Panasonic PT-53WX53 53" Rear Projection...
InFocus ScreenPlay 4805 Multimedia Projector Logo
161 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
