Question about HP LaserJet 4600dn Color Printer
4600n No one in our office can print. No error messages or anything. I am looking for a local technician to come by and troubleshoot for us. Any suggestions? Richmond, VA
    Problem Solver:
  • 5 Answers
First the printer is a connected over local or network .
if its connected over network configure the ip address for the printer & try to ping the ip of the printer through the system.
Posted on Jan 09, 2008
  • 32 Answers
Can't come to VA but will the printer print a test page from the pannel?? Check the net card setup. Is it a shared local printer and set to work ofline?
Posted on Aug 27, 2007
SOURCE:
How to fix brother printer in error state error?
Check that Your printer is properly connected and there is ink in cartridge. Also Check for the paper jam. If every think fine and still its showing same error message read blog Printer in error state.
Oct 05, 2018 | Brother Office Equipment & Supplies
How do I Fix a Unable to Initialize error message 51 on a Brother MFC 820CW
Error 51 relates to print head parking position.
It is blocked and carriage cannot be seated correctly.
Try to get carriage away from parking position by pulling power lead when head has moved away from parking position then slide it out the way and use a flash light to look at parking position.
look for paper debris or similar which might block it or upset a sensor.
Jan 24, 2015 | Brother MFC Office Equipment & Supplies
Spooling error
Right click My Computer > Manage > Services and Applications > Services > Print Spooler. Try stopping and starting. Make sure it is set to Automatic and Login is Local System.
If this is in office network, then IT needs to handle. GL
May 31, 2013 | HP psc 1310 series
Error 322 - see printer message
The fixing assembly (The hot rollers) of the printer is faulty. This need to be replaced by a service technician.
Faxes are received in memory because they cannot be printed.
Nov 11, 2009 | Canon FAX-L350 Plain Paper Laser
Pcl xl error subsystem: KERNEL error: IllegalTag
Why not just that the printer is broke?
Please I need a lot more descriptive information before I can help you.
Would you consider sending me the original document and a "Print to File" of the document. I will also need to know where in the printout the error occurs.
I can run it through some of the tools I have and see if I can spot the failure.
Please send the files to; [email protected]. I will let you know I have them and get a quick look at them to see if it something simple.
Don
Oct 22, 2009 | HP Color LaserJet 4600n Printer
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error message ''Unable to Print 4F''
How to repair error "print unable 4F" in the Brother dcp-135c .
thank alot.
Jan 06, 2009 | Brother MultiFunction Center MFC-440CN...
Asharp AL-1631 won't print anything but a mess.
E7 is a few different things. Are there two more numbers flashing after the E7 appears?
F5 has to do with the copy lamp.
It should be looked at by a technician. It needs to be looked at for the E7 issues.
Jun 13, 2008 | Sharp AL 1631 Copier
HP 4600n tray 1 greyed out
Put the labels in another tray.
Jun 11, 2008 | HP LaserJet 4600dn Color Printer
Minolta 2300 dl laser printer fatal error 17H
had printer for approximately 2 years. Used daily in office setting. today the printer tried to print, then just stopped and it said fatal error 17H in the window. We cleared paper jam and rebooted, gives the same error message. Anything we can do?
Apr 14, 2008 | Konica Minolta Magicolor 2530 DL Laser...
HP LaserJet 4600dn Color Printer Logo
211 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
