Question about Eton E5 Radio
Eton E5 On the Eton E5 there is a distortion on ssb signals. Won't tune in finely, so all conversations are sounding like robots. Cannot make out any words. A worbling sound. Any help would be appreciated. Thank you.
  • Anonymous Mar 29, 2014
    Probably wiped out the power supply ckt components....it is Totally inoperative.....It wasn't used but a few times. My laptop transformer is similar in appearance to my eton xformer...hopefully I might be able to localize the damage if I can find a schematic? ..and possibly salvage it. power supply was 12VDC Neg ground instead of 5VDC Pos ground.
  • 3 Answers
This may be caused by a problem with some AC adapters supplied with these radios. (It is a known problem with the Grundig G5, which is supposed to be an identical radio.) I have read that you can request a replacement adapter from Eton.
Posted on Dec 26, 2007
Why is my sound coming out distorted or not at all?
Is the preamp or channel strip set.to Line level or Mic level?
If ita not at line level then it is trying to push signal out that isnt loud enough, hense the distortion
Dec 18, 2014 | Korg KO2 Kaossilator 2 Dynamic Phrase...
2002 acura tl type s cd player works but sounds distorted, everything else plays and sounds fine?
thats a lazer problem in the cd usually a cd cleaning disk will sort that problem if not a its the lazer head thats distorted best this to do it put a conversion tape to ipod or iphone and play your tunes off those devices via your tape, there only cheap to buy.
May 04, 2014 | 2002 Acura 3.2TL
My eton E5 will not reset when I press the reset button.
Unplug the AC adapter. Remove the batteries. Press & hold down any front panel button for about 10 seconds. Repeat for any 2 more buttons. Then reset with the paper clip. Do not install weak batteries, or try to restart or reset the radio after it shut off because of weak batteries. Weak, dead, or shorted batteries, tend to make the processor inside or the reset function to screw up.
Oct 18, 2013 | Eton E5 Radio
Cannot select USB or SSB.Displays LSB or LISB? Very poor reception
On the Satellit 750 you have a button marked SSB. If you have selected a shortwave band then you can press the SSB button. Pressing the button repeatedly will toggle between LSB and USB.
You will need to know the exact frequency and the broadcast time, and the side band. Turn the radio on. Select a frequency which you know carries SSB signal and wait. Those that broadcast on SSB are not radio stations, maybe ham radio operators.
You can also select a short wave band, press the SSB button once or twice to select the side band and launch the automatic tuning system. It will scan the meter band and stop for a few second when it receives a strong enough signal. If you are able to perceive a clear signal on LSB or USB then you found a broadcaster. Some radios just have SSB and you cannot choose the side.
Personally, when I buy a radio I always insist on SSB but I have never been lucky tuning in an SSB signal. I keep trying once in while.
Jun 23, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Hi i recently bought a cobra 29 ltd chrome cb radio for my car,i also installed a new antenna ,i have a strong signal,but i am unable to hear conversations because the sound is distorted.It sounds like...
You can't tune the radio. You are supposed to tune the antenna.
I have a page for tuning your antenna. This can cause some distortion, but it shouldn't be that bad. Go here for how to tune your antenna.
also the internal speakers aren't that great. Try an external. I can't just use an internal because an external is so much better.
Something else to consider. There is a lot of skip right now. Skip is when the ionosphere becomes charge by solar flairs, and causes radio signals to skip across it, making them travel hundreds and even thousands of miles. There are some cb operators out there who run a lot of power. 10k watts and up, who just talk skip all day. A lot of those guys sound extremely distorted and over modulated. You may be hearing these guys out there. Its their radio's not your receive.
Also. People who are close to you, may over load the front of the radio in the receive section, which will make it sound distorted.
Aug 16, 2010 | Cobra 29 LTD CB Radio
Off freq on ssb TX.
.002 Mhz is really not that much off, try having them tune to your signal When I talked SSB I would have everybody tune to my signal.
Jun 09, 2009 | Galaxy Radios DX-959 40-Channels Base CB...
Sound Distortion on Some Channels
you need to fine tune for the distortion channel or else try to auto program
Oct 18, 2008 | Samsung SlimFit TX-S2783 TV
Users manual for the grundig g5 shortwave radio
I can't find one either but there is a downloadable manual for the Eton E5 at Retrevo.com  Just search for Eton E5
Jan 24, 2008 | Grundig YB 400PE AM/FM/SW Radio
Eton E5 Radio Logo
464 people viewed this question
Top Eton Audio Players & Recorders Experts
k24674
Tom Chichester
Are you an Eton Audio Player and Recorder Expert? Answer questions, earn points and help others
