Question about Quantum Fireball Plus LM 10.2 GB ATA-66 Hard Drive
Troubleshooting hard drive installation using Windos XP Pro SP2
When installing XP, it let's me get to about the end of the formatting and then I get the blue screen of death. This is what it reads. PAGE_FAULT_IN_NONPAGED_AREA STOP:0x00000050(0x80374020,0x00000000,0x8088259A,0x00000000) I am using a Intel Desktop Motherboard with a Intel Celeron CPU.
    President:
  • 317 Answers
Have you added any new hardware? This is typically caused by a faulty RAM module. But could also be any other new hardware you might have added. If you haven't added any new hardware, try removing one RAM module at a time and performing the installation (assuming you have 2 installed), and try again. Or, you might need to purchase a new one, or borrow from another PC to try temporarily.
Posted on Aug 23, 2007
SOURCE:
I want to format my pc and fix xp service pack 2.how can i will be able to do this???
Hi, before you format your hard disk, make sure you have saved all important files that you like to keep on an external drive, for example a USB Stick. Formatting your hard disk will destroy all data.
If you want to format and reinstall Windows XP do the following:
Insert your Windows XP CD. Restart your computer. Your computer should then automatically start from the CD and show the Windows XP Setup.
In Windows Setup you can choose the partition on which you want to install Windows. There you can also format the partition, before installation. To do this, just follow the directions that are shown.
Jul 12, 2010 | Computers & Internet
My 250 gb hard drive is only showing capacity of 127gb
Firstly install SP3 if that doesnt work you need to update your bios to get large disk support. If you dont want to perform any of these fixes you could simply split the drive into 2 or more partitions to access the full 250gb. Goto Control Panel/Computer Management/Disk Management you will see in there the missing gb's of your drive. Simply right click it format it and give it a drive letter.......Cheers from Scott
Apr 18, 2010 | Microsoft Windows XP Professional SP2
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Replacing window vista with xp pro sp2
hello,to install xp pro, you will need to uninstall vista by formatting your hard disk
May 01, 2009 | Computers & Internet
System crashed , no restore partition, origionall had xpsp1, have Dell reinstall Cd with xp sp2....will it have to be re activated?
Yes, but it will erase any personal data you have. Let me know if there is data to save and I will give more suggestions.
Apr 13, 2009 | Dell Inspiron 600M Notebook
Need to install install XP PRO on used cluttered hardrive.
Please follow this excellent guide XP Pro Clean Install to lead you through the process.
Check first to be sure your system meets the requirements for an installation of XP.
Also make sure beforehand that you back up any documents or files you wish to save from the old drive, because you will not have access to them after installation. Make sure you have a CD with Drivers for the hardware installed on your system; you will need these to access the internet once you install the new OS. Also be sure to have downloaded AntiVirus software installation files so you can load this onto the new system before going online.
You could, if you choose, buy a new hard drive and install your existing drive as a slave to the new master on your existing computer. In this way, you will still have access to all your old files and documents, without having to back them up.
Best of luck, and enjoy XP!
If this information solves your problem, or answers your question, please take just a moment to rate this post...thanks!!
Mar 30, 2009 | Microsoft Windows XP Professional SP2 for...
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Want to change my pc from vista to xp so.
uninstall windos vista. install windos xp professional sp2 using installation cd
Jan 28, 2009 | Toshiba Satellite A205-S4617 Notebook
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
Open Questions:
AOL MAil SuPPoRt PHoNe {1^855^536^5666}#[email protected] NuMbER CONNECTICUT This AoL MaiL USA phone number is ranked #2 out of 2 because 7,728 AoL MaiL USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:855:,:5365666 is to reach the AoL MaiL USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, AoL MaiL USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. AoL MaiL USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I********** and ways to call or contact AoL MaiL USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling AoL MaiL USA Calling AoL MaiL USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from AoL MaiL USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with AoL MaiL USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare AoL MaiL USA's phone numbers against each other. Contacting AoL MaiL USA in General While I********** is AoL MaiL USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I********** is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach AoL MaiL USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact AoL MaiL USA.
Oct 22, 2019 | AOL Computers & Internet
See all Quantum Fireball Plus LM 10.2 GB ATA-66 Hard Drive Questions
Quantum Fireball Plus LM 10.2 GB ATA-66 Hard Drive Logo
173 people viewed this question
Top Quantum Computers & Internet Experts
SirEbrum
Shawn DuRee
Ekse
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
