Question about Radio Shack Pro-2055 Base Scanner
My screen has gone blank.
I have the volume and conversation, but no way to see who is talking and can not load anything new in.
This problem is caused by oxidation on the cable tip. All that has to be done is pull the flex cable from the connector on the back of the display and cut off the tip of it. Put a dab od antioxident on the cable and put it back in the connector. This has fixed several scanners we have had come through our shop.
Posted on Jun 26, 2009
  • tnkid Sep 19, 2010
    It has to be the cable to the lcd. That requires removing a few more screws, and soldering to get to it. But it worked after I got to the right cable,
Led78... you nailed it my man!! got mine out of the closet, where it hasbeen for a year, sniped the tip, and she works!!!! thanks man!!!
Posted on Aug 05, 2009
This is a common problem wtih these scanners with a date code of 2005 take it to the Radio shack you bought it from if under warranty for repair. If not youll have to pay for the LCD repair.
Posted on Oct 24, 2007
My screen has gone out
Please New Software install in the Phone Problem will Solved
Oct 31, 2012 | Samsung Cell Phones
The sound is good but the picture is gone. It is a new tv--42" flat screen. Even the input--other messages are blank
If you can't see the volume increasing and decreasing when you press the volume button and if the menu will not appear when you press the menu button then the television has a problem even though it is brand new. When you have no picture the problem is most likely loose inverters or the inverter board needing to be replaced.
Feb 10, 2011 | Emerson Televison & Video
Blank screen the screen has been working for over a year and all of a sudden went blank its not my pc as i plugged my pc into another screen and worked fine.... the standby flashing stops flashing when i...
Since you have tried another monitor with your computer, then we can only assume that your LCD monitor had gone bad.
If the light is green but you can't see anything on the screen, then most likely the backlight has gone bad. Unless you want to take the monitor apart, I would suggest buying a new monitor.
Apr 19, 2010 | Samsung SyncMaster 203B LCD Monitor
The screen has gone blank and the sound has also now failed.
does the shop where you had it fixed give you a warranty Id talk to them sounds like a heat realted problem on the mainboard
Dec 04, 2009 | Televison & Video
My acer 4520's screen is blank when i'm turning it on.
There are approx 4 reasons why this might happen:
  1. The backlight has gone (Find a dark place and shine a torch into the screen and see if you can see an image in the background, if you see an image then the backlight has gone) - Needs a new backlight (Engineer to remove and fit) or have a new panel fitted.
  2. The panel has died - Need a new panel
  3. A cable has worked itself loose or is broken
  4. The inverter has gone - Need new inverter
  5. Long shot, the bios has got corrupted - Engineer could re-flash the bios
  6. Long shot, Mainboard onboard graphics has gone - Need new mainboard
My personal opinion is that the backlight or inverter has gone - Either way it needs to be opened up to repair it, consult a service centre and get a quote or repair it yourself if your up for it.
Thanks
Sep 05, 2009 | Acer Aspire 4520-5582 Notebook
Screen has gone blank
try reformatting your mobile phone. Sometimes, these phone hangs.
May 16, 2009 | Nokia 6300 Cellular Phone
All I see is a blank blue screen on polaroid dvd player
try pressing the in/out button that should fix a blank blue screen
Jan 30, 2008 | Polaroid PDV-0701A Portable DVD Player
Blank screen
i have the same phone and the problem just lies on the flexcable inside the phone that attached the keypad to screen.
Dec 09, 2007 | Sony Ericsson Z520i Cellular Phone
Radio Shack Pro-2055 Base Scanner Logo
486 people viewed this question
Top Radio Shack Radio Communications Experts
xxxxxx xxx
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
