Question about Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
Just bought the Pioneer GM-7300M. Have all power connections hooked up...receiving power from battery and remote...amp will not power on. Was testing the connections and when I unhooked the rmote turn on and touched it back to the hookup the power light flashed on. Any ideas?
  • Anonymous Mar 25, 2014
    Pioneer gm-6500f amp won't power up why ??
    Pioneer amp gm-6500f won't power up ?? Why
Chenge the fairroll,and reset your sistem go
Posted on Aug 24, 2007
    Novelist:
    Champion:
  • 219 Answers
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
I just bought two ten inch JL Audios and i hooked them up and they work great.... i installed them two days ago, and since then my battery has died on me twice.... i dont know what the problem is... i...
Hi there, check when you have switched off the power in the car to see if the amp power lights are still on, if so there could be a problem with your remote wire. Check the cables to he rear of your stereo and with a test meter, determine which one loses power when the ignition key is removed. When you have found this cable, splice your remote lead to this one, and your amp should switch off when you switch the car off, thus saving your battery. You could wire it to a permanent live feed and install a switch to allow you to run the amp without the key in the ignition but dont forget your battery will run down fast because Amps use a LOT of power.
May 06, 2011 | Pioneer Car Amplifier GM-5100T - 2CH 760...
My Pioneer GMX552 Seems to have been hooked up properly, with power and the speakers have power to them. The RCA pin are connected, however I am not receiving any sound. Can I get a list of...
i doubt its the rca cable. check the connections from the back of the head unit, also check that you didnt blow any fuses either from the wire from the battery or on the amp also check the remote wire (little blue wire) and make sure its grounded really well
Mar 26, 2011 | Pioneer GM-X522 Car Audio Amplifier
I have a Pioneer GM X862 car amp, with a constant red light on it. Also, it is supplying the subs with power, they are lightly vibrating but its not pushing like it should. No bass.
Make sure your power line comes directly from the battery and that iyt has no abrasions or cuts in it. Check your ground and make sure that it has a good connection to the vehicle chasis. Ensure that the remote line is connected properly to the remote lead from your head unit/receiver.
Common mistakes in this area are using the remote turn on lead as a power lead. It does not have near enough power to drive the amp so you will only get a slight trickle of power.
Jake
Oct 02, 2010 | Pioneer GM-X862 Car Audio Amplifier
KEF PSW2000 subwoofer has power but no sound
to test a speaker you can hook up a batterie any where from AAA AA C D or a 9 volt batterie if the speaker makes a tone then it is fine and your problem is else where
Nov 03, 2008 | Pioneer GM-7200M Car Audio Amplifier
My GM-7300M anot woking
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage on both terminals is 12v or higher, the amplifier may be in need of repair.
Let me know if you have any other questions.
Aug 07, 2008 | Car Audio & Video
Installation
Buy an amp wiring kit. The battery cable goes to the battery (duh, right?) with the fuse within 18 inches of the battery. The ground gets bolted to a clean section of the car chassis/body. the remote lead goes to the radio's remote out (blue/white stripe). the rca cable goes to the radio's Sub/rear RCA outputs. Speaker wires go the speakers. Done!
Sep 12, 2007 | Pioneer GM-7300M Car Audio Amplifier
No power to amp
Are you sure it has the full voltage going to both BATT and REM? sounds like the REM signal is weak.
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Amlifier not working
connect your remote turn on and your problem will be solved
Sep 23, 2006 | Crunch BlackMaxx BLX2000D Car Audio...
Pioneer GM-7200M Car Audio Amplifier Logo
868 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
