Question about Toshiba CF35F50 TV
Picture problem The TV makes a popping sound and I lose the picture intermittently and sometimes lose the picture all together. When I wiggle the coaxial cable in the back, the picture will eventually stop popping. This has been an issue for at least 6 months now and it seems to be getting worse. Most of the issue is when the TV is 1st turned on...once it warms up it seems to perform better. The TV is about 9 years old. Should I get it looked at or I am better off buying a new one?
    New Friend:
  • 76 Answers
Since it is 9 years model definetely loose contact and flux corrosion is there in wire connector and pcb also. Make one general service. Prolem solved.
Posted on Aug 23, 2007
TV intermittently does not display picture. Back-light and audio are OK.
if reseating connectors and ribbons (assuming you've cracked the case open yourself and gotten your hands dirty...or atleast scratched up lol) then I would have to say it sounds like an issue with the logic board or maybe a particular component overheating? it sounds tedious but grab yourself a magnifying glass and look at your individual capacitors and resistors for any physical damage especially what I call, "bursting....." where it looks like they're puffed up and popped from the inside.. sometimes a capacitor will blow and not completely lose it's top so it works intermittently the same with resistors in my experience.... hope this helps.
May 09, 2016 | Samsung 50" Class 1080p 120Hz Smart LED...
42'' lcd turns on no picture/menu
Your tv is being attacked by electrical surges which seem very violent and has already damaged some logic controls. Please invest in a AC filter which will protect your tv from such spikes....... but first you need to get your tv serviced from the electrical damaged it has already suffered.
Nov 02, 2009 | Philips Televison & Video
Temporary losing picture
CHCK THE OPTIONS MENU SEE IF IT HAS A COLOR CONVERSION OPTION ,,TRY THAT,,ALLIGN THE COLORS
May 14, 2009 | Pioneer SD-582HD5 58" Rear Projection...
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
Fisher tv monitor intermittently turns to snow and loud buzzing
Could it be vertical IC loose connection. It is sometimes connected with correct tuning. Check it for crack or wiggling connection best is to resolder.
Feb 02, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
42" RCA Projection TV - Sound good, but Picture goes out intermittently.
resolder the vertical output IC . bad solder there can make the CRTs blank for protection and you will lose the picture when the vertical drops out.
Mar 27, 2008 | Televison & Video
Daewood tv model # dtq-26s1fc
you are having a intermittent sound problem probably some lose solder or in the audio circuit.take the set to a tech to have it repair.good luck.
Dec 20, 2006 | Daewoo DTQ-26S1FC 25" TV
Televison & Video Logo
129 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
