Question about Brother EM-430 Typewriter
Correction ribbon I can't find out how to insert a correction ribbon on my typewriter.
  • Anonymous Feb 14, 2009
    How do you insert a Brothers Correcton ribbon?
  • Maureen8 Feb 19, 2009
    Unable to determine correct position for the lift-off correction tape (dry) for a Brother EM-430 typewriter.
  • Brother Master
  • 1,113 Answers
SOURCE:
WP3400 & AX-12M
  1. Is the daisy wheel locked in the forward position?
    1. Pull the black lever back, away from the platen.
    2. Lift out the daisy wheel and inspect it for damage; replace the daisy wheel if it is damaged.
    3. Re-insert the daisy wheel and push the black lever towards the platen until it locks in place.
  2. Is the ribbon moving?
    1. Lift the ribbon cartridge out of the typewriter
    2. Inspect the ribbon for damage
    3. If the ribbon is silver, it is exhausted and must be replaced
    4. If the hammer has been striking in one place, there will be a clear area near the center of the ribbon.
    5. Turn the colored knob on the left side of the ribbon cartridge counter-clockwise to advance the ribbon a small amount. Replace the ribbon if it will not advance.
    6. Re-insert the ribbon
  3. Turn on the typewriter, insert a piece of paper into the typewriter and type a few letters
    1. Did the hammer move forward?
    2. If the hammer moved, did the ribbon advance with each keystroke?
If the hammer did not move or the ribbon did not advance, the typewriter will require service. If the typewriter still does not make an impression on the paper, your typewriter will require service.
Dec 09, 2013 | Brother Office Equipment & Supplies
CORRECTION RIBBON
The correction ribbon is installed on a separate mechanism on a typewriter. If you look between the regular ribbon guide and the card holder you should see the correction ribbon guides on the right and left hand side of the card holder. the spool holders will be to the right and left of the correct ribbon guides. This is true only if the typewriter has a correction mechanism installed. Some machines do not have a correction mechanism. Correction is achieved by using a correction tab which is held by hand, in front of the letter to be removed, or white out. Some correction tapes attach to the bottom of the print ribbon.
Nov 06, 2013 | Swintec Office Equipment & Supplies
I have a brother GX6750 typewriter do not understand how to install correction ribbon
well, the correction ribbon is for erasing mistakes, it literally, pulls the ink off the paper, but you have to hit the correction button, the type writer will back up and pull the ink, but you would hear ait and be able to tell the diff. I think maybe you should check 1st that the ink ribbon is the 1 closest to you, and the correction ribbon is behind the ink ribbon- also make sure they are in the correct direction- ink side of the ribbon facing your paper- sticky side of the correction ribbon facing the paper- so its you, the ink ribbon and then the correction ribbon then the paper
Feb 07, 2012 | Brother GX-6750 Typewriter
Need visual instructions to change ribbon
Move the blue lever on the R. side of the ribbon to the rear and lift the ribbon out unsnap the correction tape from the bottom, reattach the correction tape to the new ribbon. Insert the the two small tabs on the rear of the ribbon into the slots in the ribbon deck and snap ribbon into place. For apicture go to lexmark.com, click your way to publications and you will find a manual.
DickyO
Oct 19, 2009 | Lexmark Wheelwriter 15 Series II...
I can't get the ribbon cartridge in the down position to type.
It seems to me that your cartridge is not sitting correctly. If you are using an OEM ribbon, then it may well just be that you have not correctly inserted the casing. In that case, I suggest you try again.
If you are using a COMPATIBLE ribbon, then it is most likely due to wrong design of the casing. Unfortunately, some compatible ribbons in the marketplace do come with lugs, even though they look very similar to the correct cartridges. If you require further advice or would like to replace your ribbons, i suggest you contact www.inkribbonpaper.co.uk.
Sep 22, 2009 | Brother ML-100 Typewriter
Typewriter won't type
check to see that when yu replace the ribbon it has not slipped in front of the print ribbon and that you have not got the button for corection pressed by mistake it is using this to print you letters not the ink ribbon
Jun 11, 2009 | Brother ML-300 Typewriter
How do I put in new ribbon in the wheel writer 1000
Your description is a little hard to understand, but it sounds like you bought a ribbon and it dosen't work right.
If the ribbon looks lie the old one then to install it like this.
1) Insert the two little feet on the ribbon into the the cut outs on the front of the ribbon deck and snap it into place.
2) If the ribbon dosen't look the same you have the wrong ribbon.
DickyO
Oct 20, 2008 | Lexmark Wheelwriter 3 Typewriter
Ribbon/correction tape
Ribbons:
Correctable film - MODEL 1230 or 1030
Nylon - MODEL 1032
Multi Strike - MODEL 1031
Correction tape:
Lift-off - MODEL 3010 for use with correctable film ribbon & cover-up - MODEL 4010 for use with nylon ribbon and multi strike ribbon.
Aug 22, 2008 | Brother SX-4000 Typewriter
Correction Tape
Two possibilities, one the correction tape is twisted and the wrong side is .facing the paper. The shinny side should be facing you, the dull side facing the paper. Second possibility you must make sure the ribbon is compatible with the correction tape. There are 2 types of ribbons. A correctable one (orange or yellow knob) and a multi strike (blue or purple knob on ribbon cartridge). The lift off correction tape (orange or yellow spools) only works with the correctable ribbon and the cover up correction tape (blue) works with the multistrike ribbon.
Jul 17, 2008 | Brother ML-100 Typewriter
Correction ribbon
make it sure that the correcting ribbon correct insert to the guide of the ribbon push it then you feel lock , test correcting not jumping ribbon case , then ok.
Dec 11, 2007 | Brother GX-6750 Typewriter
Brother EM-430 Typewriter Logo
201 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
