Question about Samsung HLN617W 61" Rear Projection HDTV
TV won't shut off
The TV picture loses its color(almost looks lke a partial black & white negative)freezes up and the TV won't shut off. I have to pull the plug to turn off the TV. Upon restart, evrything is fine for about an hour when the TV again gose into the same mode as previously described. Pulling the plug and restarting the TV restores the picture for a short period of time. The lamp is on.
  • bebebebe Jan 29, 2008
    Have the same problem. Picture freezes in black & white like
    a negative with lots of snow. Even the closed caption is
    frozen. You cannot change channels, you can't do anything except
    turn it off. Repairmen came out & said they couldn't find
    anything wrong & maybe it's my cable box. Problem is getting
    worse. The only thing the repairman said that was helpful was
    that when you turn it off, you have to leave it off for 2-5 minutes
    until the fan shuts off. Otherwise, it just keeps recycling
    trying to come on, but it can't. I have a service contract on
    this unit, but apparently they don't know how to fix it?
    Problem Solver:
  • 16 Answers
The symptoms of picture freezing, tv won't turn off and b'w pix are all indications of a bad dmd board.
Posted on Jun 11, 2008
    Problem Solver:
Here's the link to a post I made concerning a similar problem with two Mitsubishi DLP tV's with a similar problem.
Greg
http://www.fixya.com/support/r659530-fix_mitsubishi_wd_62627_going_black
Posted on Jun 10, 2008
  • 87 Answers
Sounds like color wheel BP96-00250A. Have installed by professional $350 ish
Posted on Jan 25, 2008
SOURCE:
Color problems vizio lcd hdtv
If your tv has a custom settings area, first turn all color down on set so picture looks black and white. Now in color settings look for red blue and green color bars. Use the bars until the picture looks as true to black and white as possible. Also, try changing color temp.
Dec 21, 2013 | Vizio VW37L 37 in. LCD HDTV
When TV is first turned on, color looks like a reverse negative in a photo, picture is mostly black, white, and purply pink. TV picture then shuts off, power light indicator stays green, sound stays on....
we had a SONY Rear projection and we had that problem turned out to be a bad fan and caused the main control board to fail thus the same problem contact the company and see what the warranty covers
Jan 02, 2011 | RCA HD61LPW42 61" Rear Projection HDTV
We have a Samsung DLP about 5 years old. We noticed that the fan or some sort of hummning sound was coming from the back louder than normal while TV is on. Then suddenly the picture would start to freeze...
This tv have a colors wheel,hear loud motor noises,humming noises,squiling or grinding noises,have pictures black and white.All these causes are by the colors wheel is worn out, warp rubbing against it motor or fiber plastic glass briddle about to brake aparts.Don't turn this tv on anymore until,u change the colors wheel or u will damage the projection engine.The colors wheel are hard to change for amatur and hobiest.Because involved taking out many machanical parts,before even can come to the colors wheel to take out and change it.The best course to to hire a Tv Tech.to do this job.The price colors wheel part and labors.Awhile back was about $500-550,now??
Sep 10, 2010 | Samsung DLP HL-P5663W 56" TV
50" DLP Samsung HDTV
That sounds like one of 2 things:
  1. Color wheel
  2. Light engine
Color wheel because of the losing color, but the light engine because of the picture freeze. It's very difficult to judge since I can't be there to see it. I'm leaning toward the light engine though. The only fix is to replace the DMD board, or entire light engine.
Feb 04, 2010 | Samsung HLN5065W 50" Rear Projection...
Black and white screen...
The color wheel can cause a black and white picture but not the jumpy or negative look.
Those symptoms are usually caused by the DMD assy which drives the color wheel and is somewhat expensive, most of the time you can purchase the whole Light Engine which includes the DMD assy for the same price.
Mar 20, 2009 | Samsung HLN617W 61" Rear Projection HDTV
HLN4365W Picture goes askew and turns to black and white.
Hi...what you are seeing is the DMD board (digital Mirror display board) going bad. And if you leave it turned on like that it will damage the DMD mirror and freeze that picture into the mirror. It will look as if someone etched it into the mirror. DMD boards can be repaired and some cannot be repaired. The DMD board can be replaced. The DMD mirror can also be replaced too.
Mar 27, 2008 | Samsung HLN4365W 43" Rear Projection...
BLACK AND WHITE SCREEN AFTER AN HOUR
This is usually caused by the tuner which loses the chrominance part of the NTSC signal. Your did not say how you have it connected but it you try using a composite video input (yellow jack) and get the color OK than it must be the tuner which is not cheap but is worth having replaced.
Hope Ya Fix it!
Dec 28, 2007 | RCA 27V530T 27" TV
SAMSUNG PICTURE FREEZE (LOOKS BLACK&WHITE)
I have the same problem... It turns B&W
I can still hear the sound... however I can still turn the tv off when that happens
Aug 28, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Our Color TV is now Black & White
it sounds like the main board to me, I can purchase them if you want one let me know
May 22, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung HLN617W 61" Rear Projection HDTV Logo
194 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
