Question about HP (D7580-60003) Motherboard
Problems with the screen
The imagen in screen is not clear, I think that have problem with the video card, and I want kwen if the video card come wiht the motherboard as a one piece
    President:
  • 2,961 Answers
If you take the side off the pc case and look inside, you will see the back of where your vga lead is connected to from the monitor, if it is straight into the the motherboard, you have onboard graphics, if tou see your lead connected to agraphics card fitted into a brown (AGP) slot or a white (PCI) slot, then you have a seperate graphics card. If you have onboard graphics and suspect it is the graphics then you can fit an AGP graphics card and dissable the onboard graphics in the bios set up.
Posted on Aug 23, 2007
SOURCE:
Dynex PO2-w30-003s no picture sound ok
put a flashlight behind the TV screen or front screen close, just try as close as possible, if you see image that means that the Back-Light inverte is defective or the screen lamps are not working, if deres no imagen the video card is not working (main board)
Aug 06, 2014 | Dynex DX-LCD32-09 LCD TV
MY 46 INCH TV WHEN IS ON THE IMAGEN GET LINES
Sounds like a defective T-con board. Worst case is your Panel, but I don't think so.
Mar 20, 2013 | RCA 46 46LA45RQ LCD TV
Tv emerson 14" no tengo dato del modelo tiene los siguientes circuitos LA7671S---TA8782N---STR30110 ---LA7837, sintoma: le doy la orden de encendido, y primero le viene el sonido, luego se ve un...
If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Search the site by type in the "brand name" of your device, in the "Search box at the top right of the Homepage" to get gathered related posts.
May 21, 2017 | Emerson ET-14J2 13" TV
When turned on, my Canon Power Shot A530 has a message that says N imagen, it does not prepare the lens for pictures, just stays with the black screen and the N imagen message.... do you have a solution?
try to change your SD card else There is an external software which you can install in your memory card and then you can insert it in your camera and if it does not work then go to canon service provide
Jan 14, 2010 | Canon PowerShot A530 Digital Camera
Line in lcd
Most of the time, symptoms like those appearing on your laptop are caused by problems with your video card or the LCD screen. One of the main causes for the problem is excessive heat buildup in the laptop that damages either component, or both of them. If you have a jack for connecting an exterior monitor, try hooking up a monitor to the laptop. If the problematic lines don't show up on your LCD, that;s the component that's going bad, If they are still visible, there's a good chance your video card is going bad (or both the video card and LCD screen are going bad).
Hope that helps isolate your problem.
disaksen
Aug 11, 2008 | Compaq Presario M2000 Notebook
StudioWorks 700s Monitor No Signal
It could be that the resolution settings that you had with the old monitor are not compatible with the new monitor. Try hooking up your old monitor and either lowering or highering the resolution and see if that corrects the problem. Can you give me the model number off the new monitor so I can further look into the compatibility of the video card and the monitor.
Apr 29, 2008 | Proview PL926WBi 19" LCD Monitor
BAD DISPLAY
Try replacing your video card. That video card may not work with your motherboard.
Dec 05, 2007 | Compaq Evo D500 PC Desktop
Problem with the imagen in my haier plasma monitor
My experience with a Haier Plasma 42EP24S is that they have weak software chip that goes bad and can cause a number of symptoms from picture with no sound, will not recognize video inputs, or my current problem tv turns on and off irratically.  This is the second time i have replace this chip, which is the socketed chip on the vga/component/dvi input circuit card.  Last time i had this problem i ended up fixing it myself because sears took over 3 weeks and still could not figure out the problem.  I am working on obtaining this chip, probally get about a dozen so if anyone thinks this may fix there problem as well i my have some for sale.  [email protected] of Malobicky Digital Systems.
Sep 30, 2007 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
HP (D7580-60003) Motherboard Logo
61 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
