Question about Ricoh FAX5000L Plain Paper Laser
Fax confirmation In our office we have an Aficio Fax 5000L and it's working fine. The problem is when it prints confirmations, they come out landscape instead of portarit which cuts everything off. Please help!!
  • 328 Answers
Re: fax confirmation
Check the settings in the paper tray. Do you have a manual? Should be info in it to change paper specs.
Posted on Aug 23, 2007
0 characters
3 Points
When trying to print the confirmation page - continually jamming - is there a place I could take the fax machine to close to Rivonia in Johannesburg SA?
Thank you for your email. we solved the problem by finding and removing a flower bud that fell into the area where the paper feeds through. The fax machine is working 100% now.
Kind regards
Diane Stevenson
Office Manager
Strats Inc
Nov 17, 2009 | Samsung SF-5100 Plain Paper Laser Fax
Is it possible to get a printed confirmation report after sending a fax on a UF-790?
Yes. Fax parameter #13 allows you to automatically get a journal after 32 transactions. Go here to get complete manual free.
Apr 17, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
How to have fax confirmation sheet print
open both one-touch speed dialing panels--press DATA REGISTRATION >set> press search buttons to display REPORT SETTING >set> search to OUTPUT YES (This will print a report with every transmission, next option will give you the option of whether to print the first page of the document (yes) to remind you of what it contains)
Mar 18, 2009 | Canon LaserClass 9000L Plain Paper Fax
Aficio 5000L will not receive most faxes.
That is a problem with your phone service. Your fax machine does not care where the fax comes from.
Dec 01, 2008 | Ricoh FAX5000L Plain Paper Laser
My office has a CANON IMAGERUNNER 3570 and all of a sudden all of our incoming faxes are printing off landscape instead of portrait style and our faxes are being cut off and we cant read the bottom. Please...
In the cassette change the blue dial back to the correct type, either a4 or A4R (landscape). Sounds like you have to set it back to A4, Blue dial right hand side, front of cassette when you open it.
Or press the paper select button on the copy screen and see what it has been changed to, then change the dial in the cassette.
Jun 09, 2008 | Canon Fax Machines
Print out orientation
Because they are being sent landscape to you.
Alternately...Reset the fax machine.
Function 7
Monitor key slowly 4 times
scroll down to shipment set
set....wait 2 mins
( CAUTION machine will reboot to factory defaults and blow out all speed dial numbers) [the LAST resort]
Mar 20, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
Richo Aficio 5000L Fax - Fax Operation not working !!!!!!!
First, determine whether the telephone line is working properly. Remove the telephone line from the machine and replace with a test handset. Try calling the fax number and see if you get fax tones on the handset. If not, there is a problem with line switching. If you do get fax tones, then the machine is at fault. Now plug the line cord into the machine, check that it is in the correct input jack, as there may be unmarked jacks open on this machine. Check the display and see that it is ready.Is the machine trying to communicate with another fax number? If so, change the service station fax number to a machine that is close by.(User Tools 2 then immediately 1998 start within 3 secs. then 13 and change the number.) Try to send or receive a fax and observe there is or not 3 sheets of data sent to the machine you just programmed as the service machine.So then, is the machine configured with 1 or 2 modems? Determine that the problem happens with both modems. If so, the modem is not suspect. Now let me stress this, that if you are not a qualified Ricoh technician, do not attempt any further checks yourself.
Next, do a complete level 3 reset. Remember that the machine may be configured with a feature upgrade card which may contain 999 additional speed dial numbers. Do not remove this card yet. However, repeat the receive checks with the memory card removed. If there is no Feature upgrade card or a fax on demand card in the left hand slot, then check the contents of system switch 16. If this is set to 1. If so, then the machine will not work unless a ic or data copy tool is present in the slot. Repeat the tests. Power off and remove the memory card and the feature upgrade card. Power on. Set System switch 16 to 0 and repeat the tests.
Theres more tests, but I don't have the space to go through them all, the manual is 300 pages.
Jan 24, 2008 | Fax Machines
Fax does not print a confirmation page.
Use Function 8 not 6 and use set to lock it in. Lawrence
Nov 09, 2007 | Panasonic Panafax UF-550 Plain Paper Laser...
Ricoh Aficio 5000L Fax Printer-Adding names to Group name
On every fax i've worked on, you cannot edit groups. You have to delete the group and start over.
Apr 17, 2007 | Ricoh FAX5000L Plain Paper Laser
Ricoh FAX5000L Plain Paper Laser Logo
271 people viewed this question
Top Ricoh Fax Machines Experts
Are you a Ricoh Fax Machine Expert? Answer questions, earn points and help others
