Question about Amana ASD2326HE Side by Side Refrigerator
Drs2662aw amana side by side
Quit getting cold. I took back panel off in freezer and tubes at top of evaporator are frozen. also defrost thermostat clipped on to coil is also covered in ice
  • 291 Answers
Sounds like you may have a restriction or blockage, may also be low on freon
Posted on Aug 25, 2007
  • zzzman007 Aug 27, 2011
    I have same model with no installations guide freezer stopped making ice or even freezing ice cream. I vacumed the coils underneath and turned the red knob underneath, not knowing where it was originally set at or even what it is for. Could this be why it stooped freezing?
My amana abb2522few1 fridge is not getting cold but freezer works fine.. Freezer fan is working as well.. Please help.. Thanks
either the damper vent door is stuck/frozen or broken in the closed position and cant let cold air from the freezer to the refrigerator,its located between the freezer and refrigerator compartments,or if theres a icy frosty buildup on the inside rear freezer wall panel,then the evaporator is frozen over and cold air cant be blown down to the refrigerator,then it becomes a defrost problem,remove this panel and test defrost heater element and thermostat and power to these components or the defrost timer or A.D.C. circuitry that supplies power to these components
May 06, 2012 | Refrigerators
I have an Amana 25 Side by Side Refrigerator, approximately 20 + years old. The freezer side doesn't seem to maintain the cold for freezing. I have vacummed and cleaned around the coil, in...
DEFROST PROBLEM
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can't flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won't turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass(disconnect the two wires plugged into it and twist them together) the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it's bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it's in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Jun 20, 2011 | Amana Refrigerators
Amana Model# ARS2365AC The freezer is not keeping the food frozen and the refrigerator is not as cold as it use to be. Both control dials are on 7 the maximum it can go. Thank you for all your...
if the rear wall inside the freezer has ice build-up on it then the defrost isnt working,remove this panel and check evaporator coil if its iced up the evaporator fan cant blow the cold air thru this coil,defrost it with a hand held hair dryer,then check the heating element located below the evaporator coil for continuity then check the round defrost thermostat on the top of the evaporator coil,note,this part needs to be tested below 32degrees to test good above that temp it will show open or bad
May 29, 2011 | Amana 22.6 cu. ft. Side-By-Side...
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Freezer part of my amana side by side is cold but not freezing
DEFROST PROBLEM
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad, it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
Part 1541 on this diagram is your timer. It's under the front behind the kick panel. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=21463&diagram_id=646025#d646025
Apr 24, 2010 | Amana SXD524VW Side by Side Refrigerator
My Amana (DRS2662A) fridge and freezer not cooling.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
Part 1541 is your timerhttp://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=DRS2662AC&productCategoryId=0165000&brandId=1268&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00012&componentDescription=MACHINE%20COMPARTMENT&documentId=M0503273&backToLink=Return%20to%20part%20list
Sep 21, 2009 | Amana 22.6 cu. ft. Side-By-Side...
GE Profile Artica PSH23PSAASV side by side refrigerator not cooling...this has happened before. The freezer stays cold but the rerigerator does not get cool. It does not seem to be getting cold enough....
You will need to unplug the refrigerator and remove the back panel inside the freezer. Check for ice or a frozen over evaporator coil. If frozen defrost and we will need to examine the defrost heater at the bottom of the evaporator. It may have a glass tube covering the heater element inside. I want you to check to see if it is burned out. The part number for the defrost heater is WR51X10042
You please let me know what you find. If the element is burned out I recommend you replace it and the defrost thermostat part number WR50X10068
You and order the parts by clicking the link below and entering the part number into the part number search feature and click FIND IT. Let me know what you find, Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Jul 24, 2009 | GE Profile Arctica Stainless Steel Top...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Freezer no cooling
check continuity thro the fan motor and check it rotates freely
Oct 02, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Jun 29, 2008 | Amana ACD2232HR Side by Side Refrigerator
Amana ASD2326HE Side by Side Refrigerator Logo
690 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
