Question about Lexmark Optra T610 Laser Printer
Paper Jam First of all thanks for taking the time to help others. OK I have a paper jam in a lexmark optra T-610N BUT there is NO paper stuck anyware. WE have opened the printer and there is NOO piece of paper or anything stcuk. Can It be the fuser Unit..? or part of the fuser Unit? Thanks Terence
  • Anonymous Mar 27, 2008
    241 paper jam error
  • Anonymous Dec 05, 2008
    Where is the paper sensor on the fuser unit?
  • 98 Answers
The fuser unit has a pape sensor. If, for some reason, the sensor is stuck, the printer will read a paper jam. Open the rear door and inspect the paper sensor located in the fuser assembly. See if it came out of it's original position or if there is something blocking it from moving freely. Good luck.
Posted on Aug 23, 2007
22 Paper Jam Lexmark OptraLx+
Check the rear of the printer, there is a flip down panel that exposes the fuser exit and redrive assbly (delivers the paper to the exit rollers). The paper sensors are little black plastic flags that swing in and out of optical sensors.
Jan 01, 2012 | Lexmark Optra Lx+ Laser Printer
I have a paper jam. Is there a paper feeder button or anything I can do to get the paper out. I have already taken out the paper tray, toner cartridge and opened the back and can barely see the paper. I...
To access possible paper jams areas, please click the link http://bit.ly/jtehCY and then go to page 69.
The manual shows the path the paper travels through the printer and the options. The path varies depending on the paper source and paper exit selection (output bin). The jam areas are also shown on the pages.
For further assistance, please contact Lexmark Technical Support.
Jun 30, 2011 | Lexmark Optra T610 Laser Printer
Lexmark optra s1855 paper keeps jamming
check this site http://www.ehow.com/how_5326976_fix-carriage-jam-printer.html
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem. thanks
Aug 17, 2010 | Lexmark Optra S 2455 Laser Printer
Stuck on 202 paper jam error message. there is no paper jam. Tried unplugging but message still persists
check the paper switches, there is one in the front under the cartridge and another one in the fuser unit.
Oct 23, 2009 | Lexmark Optra S 1255 Laser Printer
My Optra e312l was working fine, but now will not pull in paper and the paper jam light comes on. There is no paper jam.
Which geographical region you live in. Is it monsoon season in your location at present. Kindly do let me know for solution.
Jul 22, 2009 | Lexmark Optra E312L Laser Printer
Paper jam due to water condensation in fuser unit Optra C710
The problem is that you have paper that contains too much moisture. (I bet it's been in the printer for a long time and has absorbed moisture form the atmosphere.. has it been rainy lately? When the moist paper gets heated in the fuser, the excess moisture turns to steam which then condenses back to water
on paper guides etc. Your diagnosis that the water is causing the jam is correct.. Try using some dry paper and it should be fine.
May 27, 2009 | Lexmark Optra C710 Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
202 pam jam
usually it means that a sensor in your fuser is bad. If you have a P.M. Kit replaced the fuser and clean the printer.
but before you do, make sure that you have cleared all jams, including in the fuser.
Its probably time for a Preventive Maintanence
Jun 13, 2008 | Lexmark T630 Laser Printer
I need help.
If your priter is showing a 241 paper jam and the paper stops in the paper tray or lower front, then you can replace the pick rollers to fix this problem. If the paper stops in the middle, then check to make sure the sensor flag in the middle left of the printer is clean and in place. If the jam is in the back of the printer then check the fuser rollers to make sure that they are rolling when the printer starts to print, check the exit sensors on the fuser, there are usually two flags, one on each side of the fuser. If there is no paper stuck in the printer, then make sure that all sensor flags are up and not stuck halfway down. Or check for dust in the sensors.
Apr 04, 2007 | Lexmark Optra T614 Laser Printer
Lexmark Optra T610 Laser Printer Logo
264 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
