I can't find the serial number for my Medina Craftmade ceiling fan, MD56DCVM. I've been told it is on the motor housing - where is that and how do I get to it?
SOURCE: reverse ceiling fan
are you sure theres not a switch on the fan body ,, up/down= summer / winter...There should be
SOURCE: I have a craftmade ceiling light fan which has
does it have a manual shut off switch to the lights?
SOURCE: I have a Craftmade Quest ceiling fan that will not turn on
looking for a manual for a craftmatic sewingmachine pretty old but hopefully there is still some out there
SOURCE: I just added a light
It sound like a common problem inside of one of your twist on connectors a wire is not making contact or has broken. The purple wire if grounded on one end is just a ground for the motor housing it is extra insurance to make sure you are protected from a short. It normally goes to the neutral wires. (neutral wires should be bare copper or white) Be causiouse elect kills.
SOURCE: I purchased a ceiling fan
The motor is pretty much the entire fan and I have taken apart many of them but I do not see any fees able way that you would be able to get it back together if you could get a motor. I would make sure that the problem is not just the speed capacitor or the speed control switch, witch are fairly simple to replace.
