Have a u-line 2075WC wine storage unit that is no longer cooling. Don't hear the compressor making any noise nor fan turning on. The light in the unit does work. Any ideas on what to start with? Thx
-   Same problem for me it looks like. This will be he second thermostat I have had since purchasing it in 2004! Not great given this is supposed to be a good wine fridge!
-   Guest
Jan 14, 2008
-   Purchsed 2075 WC April, 2004. Worked perfectly until two weeks ago. (Jan. 2008). Now it stops operating. When I turn the 'off-on' dial to 'off'' with a little more pressure beyond the 'off' 'click', and turn the dial back to 'on', it starts operating again. I can hear the motor and feel the exhaust. But the, in a few hours it shuts down again. Solution please? Is this covered by warranty? Respomse to roxy 22 indicates a by-pass possible. What are the details of doing this. Thanks.
This sounds like the thermostat is the problem. I wouldsuggest touching the compressor at the back of the unit to see if it is hot or cold. If it is hot then you have probably have power down to the compressor, if it is cold you could (if capable) bypass the thermostat to see if it kicks in. Hope this helps.
Most definitely the thermostat happened to me 2 each time at about 3 years--U-line is no help and their approved vendors will stick it to you --they wanted $450.00 for the fix
The augor for the ice maker has stopped working. I thought it was the motor but when I checked the...
(More)
The augor for the ice maker has stopped working. I thought it was the motor but when I checked the voltage to the motor I only got 26V. Now I am thinking it might be the circuit card. The door on the ice shoot opens when you press the ice lever but the auger motor makes no attempt to run.
electronic wine cellar model se80049-2.....when i turn it on it lights up for abour 2 seconds and...
(More)
electronic wine cellar model se80049-2.....when i turn it on it lights up for abour 2 seconds and then stops....however the fan in back still turns and I feel coolness from the radiator in back....but inside the box....no coolness....what's wrong.
I need a transistor, part # C47812, for a wine cooler. Model # SE80049. I would like to know if you...
(More)
I need a transistor, part # C47812, for a wine cooler. Model # SE80049. I would like to know if you could supply this part or could you tell me where I. could get it.Thankyou.....Dave
