2003 Ford Crown Victoria Logo
Anonymous Posted on Jun 26, 2013
High idle idles high then stalls out at a stop sign, we have replaced all hoses fuel pump filter, thermostat, water pump, radiator. Now its idling high whats next?
Lloyd Gardinerjr
Level 1:
New Friend:
  • Contributor 23 Answers
  • Posted on Jun 26, 2013
Lloyd Gardinerjr
Contributor
Level 1:
New Friend:
Answers
23
Questions
0
Helped
4462
Points
77
Your timing need to be reset
Arnie Burke
Level 3:
  • Ford Master 7,339 Answers
Arnie Burke
Ford Master
Level 3:
Answers
7339
Questions
0
Helped
1823897
Points
21459
Do u hav any $$ left-u went rong way-------cud be vacuum leak-some are hidden like on egr valves--but test idle air control and tps 1st--located at throttle body--buy a repair book or library sec629
5 Related Answers
Anonymous
  • 113 Answers
  • Posted on Jun 16, 2008
SOURCE: rough idle
check ur coil pack for cracks my wifes cousin car done the same thing and the coil pack had a hair line crack in it
c17hydro
Greg Bernett
  • 2993 Answers
  • Posted on Mar 04, 2009
SOURCE: MAP sensor / does a 2006 f150 have one? and if it
Bad MAP sensor....located on your intake manifold....one connector...1 o-ring
motor1258
Mike Butler
  • 6674 Answers
  • Posted on Apr 19, 2009
SOURCE: Self-adjusting idle brain often idles 1500-2000rpm range.
Faulty oxygen sensor or low fuel pressure can also cause these codes to be set. I'd go for a fuel pressure test when acting up if at all possible just to confirm I have pressure needed. Have heard of coil problems as well. Should be a good blue 1" min. spark from coil.
Anonymous
  • 957 Answers
  • Posted on Jun 03, 2009
SOURCE: 2001 ford focus zx3 stalling
It could be a lot of things, check the gas cap, vacuum leak, IAC, may need a tune-up ( check plugs, wires, air filter), seizing pulley, timing issue (check CKP sensor and CMP sensor), sticking valves, misfire, Fuel line pressure, or an issue with CAT or muffler.Good luck.
seanpwright
Sean Wright
  • 2045 Answers
  • Posted on Aug 27, 2009
SOURCE: 1997 Ford Contour with a rough idle while stopped
This is a common complaint on these cars. I own a 96 myself.
Assuming that you engine is fine and runs smoothly under normal operation, and just is rough "feeling" at idle while stopped; then I would suggest changing the motor mounts...the mounts may not be broken, but the rubber isolators get worn and soft, and transffer normal engine vibration into the chasis of the vehicle. Mine was doing the same after changing the mounts good as new again.
Please note...don't use cheap mounts, by the better grade/quality mounts.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
2answers
My 2000 Ford Expedition 5.4L V8 4x4 idles really bad when stopped at a red light. Sometimes it will just stall. It always starts back up. It goes just fine when I hit the gas, real smooth and powerful. It...
Check the idle fuel pressure. Load the electrical with headlights and heater defrost etc and see if problem gets worse. Attempt again with all accessories off. Could be fuel pump is getting low voltage at idle or fuel pump is failing. Bad fuel pump would definitely be a problem high fuel demand. Check vacuum line between pressure regulator to intake manifold.
Check for a air leak in the intake manifold. Gasket/hose etc. The P0171/P0174 is an indication that not enough fuel or tow much air. You can sometimes hear the air leak during idle.
Best solution is to use a graphic capable scan tool and watch the fueling trim/idle.
Its a 115000 btu multi fuel.it starts up,runs a few seconds,then shuts off.it doesnt smoke or anything wierd,it just shuts off.
It can be low fuel pressure issue or clogged fuel pump. Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem: ------
Engine stalls when gas is given?
http://technoanswers.blogspot.in/2012/01/engine-stalls-when-gas-is-given.html
Car stalls when MAF sensor is connected?
http://technoanswers.blogspot.in/2012/01/car-stalls-when-maf-sensor-is-connected.html
Car Engine Stalls While Driving?
http://schematicsdiagram.blogspot.com/2011/12/car-engine-stalls-while-driving.html
Car stalls and throws white smoke from exhaust?
http://repairhelpcenter.blogspot.com/2012/01/car-stalls-and-throws-white-smoke-from.html
Stalls And Dies At Stop Sign?
http://www.howtobyme.blogspot.com/2012/07/stalls-and-dies-at-stop-sign.html
GMC Sonoma Stalls and idles low
http://technoanswers.blogspot.com/2012/10/gmc-sonoma-stalls-and-idles-low.html
Nissan Pathfinder stalls and bucks on Acceleration?
http://technoanswers.blogspot.in/2012/02/nissan-pathfinder-stalls-and-bucks-on.html
1992 Chevrolet stalls and shutdown?
http://schematicsdiagram.blogspot.in/2012/04/1992-chevrolet-stalls-and-shutdown.html
Stumbling and stalling at idle after engine rebuild?
http://schematicsdiagram.blogspot.in/2012/03/stumbling-and-stalling-at-idle-after.html
1990 mazda 323 stalls and quit running?
http://technoanswers.blogspot.in/2012/02/1990-mazda-323-stalls-and-quit-running.html
2000 Toyota Camry: Idling and Stalling Problem?
http://whatisbyme.blogspot.in/2012/05/2000-toyota-camry-idling-and-stalling.html
1995 Toyota Corolla: Stalls, Sputters and Pops Through Intake Manifold?
http://whatisbyme.blogspot.in/2012/05/1995-toyota-corolla-stalls-sputters-and.html
1999 Toyota Camry: Erratic stalling and high engine RPM at idle?
http://whatisbyme.blogspot.in/2012/05/1999-toyota-camry-erratic-stalling-and.html
Dodge Dakota stalls, stumbles at idle. Has low fuel flow and runs hot?
http://schematicsdiagram.blogspot.in/2012/03/dodge-dakota-stallsstumbles-at-idlehas.html
1994 Toyota 4Runner: Stalls and Stops While Driving?
http://whatisbyme.blogspot.in/2012/05/1994-toyota-4runner-stalls-and-stops.html
1997 Toyota Camry: Erratic Idle and Intermittent engine stalling?
http://technoanswers.blogspot.in/2012/04/1997-toyota-camry-erratic-idle-and.html
Ford Maverick: No Idle and Stalling issues?
http://schematicsdiagram.blogspot.in/2012/04/ford-maverick-no-idle-and-stalling.html
These details will help.
Thanks.
2answers
08 ss trailblazer stalls on take off
It can be low fuel pressure issue or clogged fuel pump.Or its engine related issues,---------------
Check the help link mentioned below to troubleshoot the problem :------
Thanks.
1999 jetta overheating need to know where thermostat is and how to replace
Follow the upper radiator hose to the housing where it is located at the top of the engine.
Also possible is blocked radiator, water pump not working and or a head gasket if signs of water in the oil--several possible causes--remove thermostat and boil it in hot water to see if it opens or not.
How do i replace the water thmostat 99 6 cylider
WELL YOU NEED TO DRAIN COOLANT LEVEL BELOW THERMOSTAT LEVEL.YOU HAVE TO DISCONNECT MAF SENSOR LOOSEN AIRDUCT 2 LARGE CLAMPS LOOSEN REMOVE 4 SCREWS TO AIR FILTER COVER LIFT UP REMOVE COVER. THEN REMOVE AIR FILTER AND HOUSING, FIRST DISCONNECT MAF SENSOR.YOU HAVE TO DISCONNECT THROTTLE CABLE AND SHIFT CABLE.YOU HAVE TO DISCONNECT REMOVE THROTTLE BODY COOLANT HOSES DISCONNECT IDLE SPEED CONTROL VALVE CONNECTOR AND DISCONNECT TPS SENSOR CONNECTOR. THEN REMOVE THROTTLE BODY ASSEMBLY. YOU NEED TO BUY NEW THROTTLE BODY COOLANT HOSES AND NEW THROTTLE BODY GASKET FOLLOW TOP COOLANT HOSE TO ENGINE BLOCK.NOW YOU SEE CAN AND REMOVE THE THERMOSTAT HOUSING REPLACE THE THERMOSTAT.BESURE TO HAVE EXTRA COOLANT ON HAND.BLEED COOLANT SYSTEM WHEN DONE.TO BLEED COOLANT SYSTEM REMOVE RADIATOR CAP ON OVERFLOW JUG.THEN OPEN BLEED SCREW ON THE WATER PUMP BYPASS HOSE PIPE JUST A LITTLE.POUR COOLANT IN THE OVERFLOW JUG UNTIL LEVEL STOP DROPPING.STOP AT COLD MARK ON JUG.CLOSE BLEEDER SCREW ON WATER PUMP BYPASS HOSE PIPE.CRANK VECHICLE CHECK FOR LEAKS. START UP ENGINE LET IDLE FEW MINUTES THEN CHECK COOLANT LEVEL ADD MORE UNTIL UNTIL LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON OVERFLOW RESERVOIR. LET ENGINE IDLE WATCH COOLANT TEMPERATURE GAUGE.WHEN GAUGE START CLIMBING. TURN OFF ENGINE WAIT FEW MINUTES TAKE A LARGE RAG OPEN RADIATOR JUST A LITTLE YOU HEAR HISS NOISE.WHEN PRESSURE STABILIZE DONT GET SCALDED BECAREFUL.OPEN CAP LITTLE MORE.IF COOLANT PRESSURE STILL BOILS OUT WAIT 20 MINUTES ADD MORE COOLANT TO RADIATOR OVER FLOW WHEN COOLANT LEVEL STOP DROPPING.PUT RADIATOR CAP BACK ON START VECHICLE UP LET IDLE UNTIL THERMOSTAT OPEN. THEN FEEL TOP RADIATOR HOSE FEELS HOT THERMOSTAT OPEN WATCH TEMPERATURE GAUGE.IF GAUGE TEMP START CLIMBING TURN OFF ENGINE WAIT A WHILE.CHECK AND ADD MORE COOLANT.WHEN THE ENGINE CAN IDLE TEMP GAUGE STOP CLIMBING YOU HAVE BLEED COOLANT SYSTEM.KEEP CHECK ON COOLANT LEVEL.
3helpful
I have a 2000 Pontiac Sunfire. It keeps overheating. I have replaced the radiator, water pump, a couple hoses, and the thermostat. I ariated it. It still overheats only runs cool if I run it without the...
i'm not being smart, but do you know for sure you are installing the thermostat correctly? the thermostat is there to slow the water flow down long enough for the water to obsorb the heat .also is the cooling fans operating ?do the fans come on at around 210 degrees?is the radiator grill clean? lower spoiler intact? does the engine over heat at highway speeds or while idling? are there any codes?is the engine running lean? possible fuel filter stopped up.fuel injectors dirty. let me know
1helpful
2answers
1989 VW cabriolet, fuel odor, engine stalls in 1st and 2nd gear
Ignition system sounds probable on vhicle when everything gets warmed up. High pitched hum could be bad tire or worse bearing.
2answers
96 tracker overheats at highway speeds temp ok at idle or low speed. Replaced water pump thermostat flushed rad checked hoses. any ideas?
Presurize system with radiator cap on to see if you are holding 10 to 13 LB pressure as high as 17 LB. Get new radiator cap for your radiator. Check for a slow leak at pump hose thermostat conection , is it wet ?
Do you have a Summer Thermostat ?
Vitally
3helpful
98 GMC k2500 7.4L Rouch Idle
TRY THIS BEFORE U SPEND ANYMORE MONEY N PARTS.
Here is the common cause of surges, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake
1992 Mitsubishi Eclipse battery seems to drain & idle high/low
check for vacuum leaks in failing hoses and loose fittings
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
