Question about Frigidaire FRS26R4A Side by Side Refrigerator
Electrical strap connecting module to housing selector
I followed the advise on "fixya" for replacing my water paddle actuator but in the process the "strap" or wire connecting the main part to the electrical part of the housing that allows you to select the options became loose. It is unclear to me how to reattach.
  • 42 Answers
Re: electrical strap connecting module to housing...
Model # is always a good start. Which end came loose? Look on the ribbon and you will see where it is written top or up, that is if it pulled loose from the board located in the dispenser housing in the door itself. If you pulled it loose from the user interface board (in the frame that mounts on the outside with the buttons on it) get a good light and look inside the connector socket. Inside the socket you should be able to see the metal contact surfaces. Make sure the metal contact surfaces of the ribbon mate to the socket metal contact surfaces and you are in business again. On the user interface end can be connected either way without damage but will only work if plugged in correct.
I hope this helped and please don't forget to rate me if it did.
Posted on Jan 26, 2008
0 characters
3 Points
Does not dispense ice or water
Check to make sure you have sufficient water flow through the supply line. If water flow is good then listen closely to the solenoid valve when the water dispenser is actuated. If there is no click the solenoid probably needs to be replaced.
Dec 29, 2015 | LG Refrigerators
How to remove water filter paddle for ge fridge
From the looks of the illustration you'll have to first pop the trim off from around the dispenser area using a small flat head screw driver. Once that is done remove the control panel, which is sometimes held there in place with a screw from bottom area of the board. Lift the board out of the retainer that holds it in place and you disconnect any wiring to remove it completely. Once that is out of the way you should have access to the paddle to replace it. Be sure that the machine is unplugged when you start, don't want to get shocked
Jun 22, 2012 | General Electric PFCF1NJX Bottom Freezer...
I have purchased a replacement water actuator to replace a broken
Remove the top freezer hinge cover , and disconnect the plug there . This removes power to the door , where you can disassemble the dispensor , without electricity to the door .
Nov 22, 2009 | Refrigerators
I have a stainless steel Frigidaire side-by-side refrigerator with an ice/water dispenser in the door. The paddle on the water dispenser broke, and I need advise on how to disassemble the dispenser in...
the front cover will come off. if you dont see any screws then it WILL unsnap. look for a slot on the top or bottom of the cover. good luck some of them can be nasty
Oct 28, 2009 | Refrigerators
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Ice and water dispensers not working
I don't think that you need to replace the hole door unless something is physically wrong with it. Could be a lot of things one is the limit switch (number 14)->
if for some reason the limit switch is not working properly then the paddle never send the signal to the valve to dispense. The same thing is for the auger motor (the one that dispense Ice).
If you see your dispenser under the paddles and activate the paddles you can see when the paddle touches the limit switch. You should hear a click. Also could be the switch pack (#18 in the drawing) that is short circuited. But this is most complicated to resolve, not impossible, but you need the schematics of the switch pack to check continuity, if you don't know a electrical technician can do the job. Also he can check the harness to check for continuity. The harness inside the door send the signal to the board to actuate the valve or to move the auger motor that send the ice.
Maybe the repair man tought that you need to remove the door because for example... LG foam the harness inside the door but Whirlpool use a conduit in the foaming process and when the door is already foamed they put the harness inside the conduit that is why you don't need to remove the door.
Also could be the valve... your ice maker is making ice?
Feb 19, 2009 | Whirlpool ED2FHEXN Side by Side...
Broken water actuator
Hi this is tech crazy
the solution to the problem is
You should be able to replace this part yourself. Follow these steps to replace the water actuator:
  1. Unplug the refrigerator to completely disconnect electrical power. Turn off the water supply to the refrigerator.
  2. Remove the drip tray (Key 23 in the image below) from the bottom of the dispenser.
  3. Remove the screws (Key 43) from the bottom of the dispenser module cover (Key 4). NOTE: You model may not have screws at the bottom of the dispenser cover. If not, push down on the top of the dispenser cover and pry out on the bottom of the cover with a flat tip screw driver to remove it.
  4. Pull to dispenser module cover up to release the top clips and remove this cover and set it aside.
  5. Remove the screws (Key 17) that are on each side of the dispenser module (Key 8).
  6. Carefully pull the dispenser module out slightly from the door. It will have wires attached. Pay attention to how the water tube and the ice door assembly are positioned. Pull this module out far enough to remove and replace your water actuator (Key 24).
Reverse the above process for reassembly.
Jan 25, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water Actuator is broken.
I had the same problem with my water dispenser and since they were willing to sell me a part but provided no directions and I couldn't locate any I decided to make my own for those who might need them. Here is a link to a PDF I made, hope it helps.
Before starting this job I would also like to warn all to please be save and UNPLUG the fridge. The whole job took me less then 30 minutes and I doubt anything will go bad in that amount of time.
Jan 13, 2007 | Frigidaire FRS26R4A Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
263 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
