Question about Pyle PLCDCS220MP CD / Cassette Player
Need replacement radio/cd player for 1990 buick reatta
The radio/cassette player in my 1990 reatta has a cassette stuck in player. How do you remove it? if not possible what is the correct aftermarket radio with cd player to replace. note the factory radio is a 1.5 din size. need help. with the pyle plcds220mp cd/cassette player work?
  • 22 Answers
SOURCE: can the Pyle PLCD-42
Yes there is a couple possible ways.
1. Get 2 RCA Y adapters and split your Preamp Output you will not have any type of fader control this way because you are using a single output.
2. Run one amp from the radio with a set of RCA Cables.
Hook up amp #2 using a Line converter connected to the output of your stereo which will convert you to RCA the just run a cable to the amp..
3. If one of the amps has a High Level Input Run a set of speaker wires from the stereo outputs to the High level Input.
I personally prefer the above 2 methods I find Low Level input sounds better.
Hope this gives you some Ideas and helps
Posted on Jul 22, 2009
0 characters
1 Points
Replacement of Land Rover Discovery Radio/cassette/cd
Refer your inquiry directly to Alpine to determine interchangeability.
Feb 23, 2014 | Alpine Car Audio Receivers
Jeep cd player says error
Cd player wont play or eject the cd.
Oct 25, 2009 | Jeep AM/FM Cassette with CD Changer...
SEA2300 +ESP - cd disc stuck in player
disconnect the power and open the side where the cd motor is and remove manually
Jun 20, 2009 | Sea Worthy 9001G Marine Casseiver...
Can you install a CD player in a 2001 Ford Focus that only has a radio and cassette player? Someone told me that you cannot pop out the cassette and radio and install a CD player.
I do not know who told you that but that is bull. I have installed many stereos, especially CD players, in to many fords. I don't care if the year of the car was 1978 or 2006. As long as you have the right harness connected you will have no problem with the system in you car.
Mar 27, 2009 | Car Audio Receivers
How do i remove a jvc cd receiver kd-g312
how do i remove a jvc cd kd/g312 reciever from my car
Feb 15, 2009 | Kenwood KDC-122 CD Player
My cassette player will not play the radio...
it sound like you fried the radio by taking the fuse out of the system that fuse was blowing for a reason power wire maybe grounding somewher check the power wire with a meter good luck.
Jan 05, 2009 | Blaupunkt Hollywood C30
Code for c 90 blaupunkt miami cassette player
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Jun 07, 2008 | Blaupunkt Madrid C72 Cassette Player
Cd stuck
All You Have To Do Is Unscrew The Radio And Take It Apart. Take The CD Out And Put It Back Together Again. This Solution Worked Like a Charm For My Stereo.
Mar 15, 2008 | Jeep AM/FM Cassette with CD Changer...
Sony xr-ca670 cd player
if this radio has a removable face check connectors behind face,..if so clean these with Qtips/alcohol. and make sure its seated correctly.If it dont then try to locate main radio fuse and remove fuse to reset radio.some radios have a reset on the front panel..
Dec 15, 2007 | Sony XR-CA670X Cassette Player
Pyle PLCDCS220MP CD / Cassette Player Logo
290 people viewed this question
Top Pyle Car Audio Receivers Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Pyle Car Audio Receiver Expert? Answer questions, earn points and help others
