Question about HP LaserJet 1020 Printer
Does not print
This is a share printer.nobody can print by this.
    President:
  • 317 Answers
Can you describe your problem a little more in detail and I might be able to help you?
Posted on Aug 23, 2007
  • Anonymous Oct 11, 2007
    When troubleshooting a problem, it's common to try different solutions.
    Why rate me as not helpful so quickly? Don't you want to try other
    solutions that I have for you?
SOURCE:
HP1020 problem with a livebox and WIN7 configuration
I found it somewhat difficult to completely Unshare files and folders on my HomeGroup Network and still allow Printer sharing in Windows 7 (Home Premium).
Initial UnSharing still allowed files like those below to be viewed on other home network computers:
C:/Users/
{user x} (folder)
AppData (folder)
Default (folder
Public (folder)
desktop.ini (file)
Other computers on the home network could step through many levels of hiarchy in the AppData folder and appeared to have "Delete" access!!
To completely decouple the computers, I had to go through the following several different Sharing/Unsharing assignment locations, till I could completely break the linkage.
I would appreciate any clarifications or simplifications.
File UnShare Confusion on HomeGroup Network
There are several different Network Sharing/Protection assignment locations in Windows 7.
To prevent all sharing between computers on the Homegroup Network, but allow Printer Sharing:
1) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options.
Uncheck sharing boxes that you don't want to share. Save changes.
2) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Click "Turn off Public folder sharing (people logged on to this computer can still access these folders)".
3) Start->Control Panel ->Network and Sharing Center->Choose Homegroup and sharing options->Change advanced sharing settings.
Choose Media streaming options.
Click "Block All" button. Turn off. Click OK.
Anomaly Note: You have to close Control Panel and repeat all step 3 again for the change to take effect.
4) Open Windows Explorer.
a) Select "C:/", select "Users" folder with single click, then click "Share with" in toolbar.
b) Select Advanced sharing.
Under Sharing tab, select Advanced Sharing. Uncheck box labeled "Share this folder". Apply and close.
5) Open Windows Explorer.
Select "C:/Users/", select all folders and files under "Users", then click "Share with" in toolbar, then click "Nobody".
6) Verify success by going to other home network computer(s) and trying to access your files and folders. You should only be able to see there is a computer and not be able to see any folders of files.
smooth printer service
Dec 16, 2012 | HP LaserJet 1020 Printer
I have sumsang SCX3200 & I want to print my some Document & figer frm dos mod. Windows Xp is runing on my desktop pc
DOS applications cannot print on USB ports, but there's a workaround by using a share and the NET USE command, first create a share of that printer check this site: http://compnetworking.about.com/od/windowsnetworking/ht/printer-sharing.htm, (take note of the name you gave the shared printer) than you use NET USE command to connect the shared printer to a virtual port (LPT2) first click on START, than RUN, than type CMD than hit enter, type the following command " net use lpt2: \\127.0.0.1\(shared printer name) /yes " than hit enter, if you have a " command completed successfully " than you have your shared printer connected to a virtual port (LPT2) now it is just a matter of setting your DOS software to print to LPT2... and VOILA! it prints...
Jun 25, 2011 | Office Equipment & Supplies
How to get a print by using wireless function
Share Your Printer on a Home Network· Navigate to the Control Panel and click on"Printers and Other Hardware."
· Click the printer you want to share in thePrinters and Faxes folder. Click on "Share this Printer" in the TasksPane or right-click on the printer and select "Properties."
· Open the Sharing tab and click on "Sharethis Printer." Enter the name of the shared printer and click"OK."
· Use the shared printer with any computer on thenetwork by navigating to Control Panel > Printer and Other Hardware.
· Click "Add a Printer" and browse forthe network printer you just shared.
Connect the Printer Directly to the Network.· Plug the printer directly into the network hubor router.
· Follow the instructions for setting up theprinter for networking provided by the printer manufacturer.
· Click "Add a Printer" and browse forthe network printer.
Dec 17, 2009 | Samsung CLX 3160fn All-In-One Printer
Printer Not Woking In Network
1. check that not any firewall or antivirus software blocking your printer.
2. try to look in paper settings what format you sending to the printer. is it letter format or A4 or what ? it should be A4.
have you tried to connect the printer with USB? or have you connected the printer with a network cable.?
Jul 03, 2009 | HP LaserJet 1022 Printer
Stop multiple copies from printing HP 6988
Hi, you will have to stop sharing your printer, if you have the administrator rights to do this you will have to go to the printer properties click on sharing and click do not share and save.
that should stop them from using your printer
Jan 27, 2009 | HP DeskJet 6988 Printer
My shared printer will only print a test page and nothing else!
Hi phall124
Have you made the new connected printer on 2 other PC's the default printer. Try selecting the printer in word by not just clicking on printer icon but using the following:
1.File
2.Print
3.Select printer from drop down box
4.Print
Regards
Go-Tech
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Trying to connect share printer w/Vista
If you connect the printer to the desktop computer and enable file and printer sharing on that computer. You will then need to go into printers and faxes and share your printer. Then go to the laptop and browse the network so you are looking at the desktop computer. You should see a folder that says printers. Open the printers folder and you should see the printer you just shared. Double click on it to install the shared printer on your laptop.
Now when you print from the laptop, you will print to the shared printer that you just installed (you may have to select it from the printer list). That will send the print job through the network to the desktop and the desktop will send it to the printer (the desktop will need to be turned on for you to be able to print).
If you don't want to have to leave your destop turned on just so you can print, you should look at a print server for your printer. That will connect the printer straight to the network. Then both computers will print to the printer over the network.
May 28, 2008 | Linksys 4-Port CPU Switch 843734000836
Network printe on vista
Accessing a Shared Printer To access a shared printer from a computer running Windows Vista, do the following:
  1. Click Start, and then click Network. The Network window displays a list of computers in the workgroup of the computer.
  2. Double-click the name of the computer containing the shared printer that you want to access.
  3. Right-click the shared printer that you want to access, and then click Connect. Alternately, you can double-click on Printers to see just the list of shared printers, and then right-click the shared printer that you want to access, and then click Connect.
After you have connected to the shared printer, you will be able to print to this shared printer as long as the printer and the computer sharing the printer are turned on.
please note that in network the computer that has the network printer if it is running XP may take as long as 15minutes to be recognized.
Apr 09, 2008 | Samsung ML 1610 Laser Printer
Sharing the printer over network
Can you print from the print server? If so that eliminates the drives. Are you sure permissions are correct?
Oct 30, 2007 | Lexmark T642 Laser Printer
HP LaserJet 1020 Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
