Question about Motorola Mobility RAZR V3
Bluetooth hi i have bluetooth on my razr and i have used it before, but my son took battery out to test his cell and see if his battery is just toats ..well when he put battery back from then on my bluetooth doesnt work and when i try and activate it in settings/connectivity/bluetooth ...it says ..."bluetooth module not attached " why would that be and how can i fix the issue?...also could it be that i deleted a lotta stuff on accident ...if i hit the games tab ...it says ..no installed midlet suites...that happened when i accidentally hit delete on some option when i was just looking at my phone setup and how do i get all that midlet stuff back?
  • Anonymous Nov 02, 2007
    my bluetooth will not come on, when i go to my bluetooth link it says "bluetooth module not attached"
  • luvemplump19 Oct 04, 2008
    when i try to pair wit my bluetooth it says bluetooth moduke not attached
    Problem Solver:
  • 9 Answers
Bluetooth is a software that every now and again fails. you just need to turn phone off and then back on. It isn't the headset and any phone replacement would do the same thing.
Posted on Aug 24, 2007
Try to press the master reset if not re-install software the qualify technician...
SOURCE:
I put my Droid Razr on charger but battery symbol comes on with ? mark. Won't charge or turn on.
1. Turn off your phone when it's not in use. If you're not using your Verizon Wireless Razr, then shut it off. Your battery will last much longer if you regularly do this.
2. Charge your phone less. If you charge your Razr nightly, then your cell phone battery won't last long. Try to charge your phone only a few times a week to extend the battery life.
3. Keep your Bluetooth turned off when you're not using it. Applications, like Bluetooth, are notorious for sucking the power from a cell phone battery.
4. Protect your Razr from extreme temperatures. Your cell phone battery lasts longer if kept at room temperature.
5. Discharge the Razr fully. Before you charge your phone, let it completely die. You can extend the life of the battery by regularly discharging and then fully charging it.
6. Leave the battery in the phone. Keep the Razr battery dry and free of dirt to prolong its life.
Aug 20, 2012 | Motorola Mobility Motorla MOTXT912 DROID...
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Won't charge
You have taken the appropriate steps. Now you have determined that the problem is not battery, it is the phone.
Most likely causes are:
  • Bad connection between battery and phone due to damage
  • water damage to the phone or corrosion
  • leads from the battery to the phone are broken.
Either way the phone will require warranty work or replacement.
Jun 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Samsund d500 mobile
You must try with different Bluetooth devices. I believed your D500 is not compatible with your Bluetooth Headset. Email me to [email protected], I will send you a troubleshoot guide
Feb 17, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Dec 14, 2007 | Motorola Mobility RAZR V3
Bluetooth & Moto V3m operation
look if the earpiece is compatible with your new phone, usually its a compatibility issue with your equipment.
Oct 21, 2007 | Motorola Mobility RAZR V3
My new razr phone
to send ringtones using multi-media message, you need to check with your carrier/srvice provider if they support this feature on your phone. if you are trying to send using bluetooth, power off your phone and take out the battery for few seconds put the battery back in, power on and try sending. if does not work, reset the phone to its original manufacturer setting. Go to
Sep 26, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Reception with bluetooth is bad
Unfortunately there isn't a "user servicable solution" that I know of. Most cell phones are designed that way. You can replace batteries, front/backs, bezels, keyboards, and screens but you can't fix the "guts". Only a qualified licensed repairman can fix this because it's under FCC regs.
Jul 15, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Razr battery trouble
Don't buy a RAZR. i work for verizon and the RAZR is the worst phone for battery life. There is, however an extended battery that may provide a temporary fix until you buy your next phone....and don't buy a RAZR
Apr 24, 2007 | Motorola Mobility RAZR V3
Blue light on outside display 1/2 on.
The blue light indicates that BlueTooth is powered on. On my phone it flashes. You can turn it off by going to Settings - Connection - Bluetooth Link - Set up - Power. Select and change to Off.
Feb 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
