Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Kenmore coldsopot 55536400
Left freezer door open 3 hrs yesterday the freezer got icy and now runs all the time
  • 909 Answers
Best thing is to give freezer a thorough defrost.this would in effect allow components to reset and start fresh
Posted on Aug 24, 2007
SOURCE:
LEFT DOOR OPEN OF FREEZER. CLOSE3D DOOR FOR 24 HRS. nOW LIGHTS FLASHING ON SUPER COOL AND SUPER FREEZE.
You will need to unplug and defrost the fridge for a few hours then replug the power. Leaving the doors open allows moisture to freeze on the evaporator while compressor continues to run confusing the control board
APPLIANCE911
Apr 10, 2016 | Hotpoint Combi FFFL1810G Graphite 297 l...
106.74259400 not cold enough
check to see if the fan in the freezer section is running, replace the fan motor if not running. if running, has the back wall of freezer got frost on it. if so turn off for 3 to 4 hrs with door open to defrost. if the frost returns in 2 or 3 days, call for service.
Jan 05, 2012 | Kenmore Refrigerators
Bottom freezer will not open
If you freezer door was left open for an extended period of time the rails that your bottom freezer slide on are most likely frozen. Repair #1 once you get the door open about every hour go in to you kitchen and open and close the freezer door a couple of times. Repair#2 Take your freezer door off remove the rails take a blow dryer and dry the rails untill you do not see any more water then add a sylcone based greast to the ball bearins on the rails and resinstall. Repair#3 Order a whole new set of rails.
Sep 01, 2011 | Kenmore Refrigerators
Does not get cold for freezer or main frige
IT MAY BE BLOCKED UP WITH FROST, TRY REMOVING FOOD AND UNPLUGGING FOR AT LEAST 6 HRS WITH DOORS OPEN.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 13, 2010 | Kenmore 57029 Side by Side Refrigerator
Frost on back of bottom freezer of a 3 year old kenmore
how long did you leave it unplugged? it's possible all the frost didn't defrost .you need to leave it unplugged and the doors open for at least 12 hrs.
May 20, 2009 | Kenmore 76283 Bottom Freezer Refrigerator
HI I HAVE AN OLD 13 CU. FT KENMORE UPRIGHT FREEZER. AFTER I DEFROSTED IT YESTERDAY AND AFTER IT HAD BEEN PLUGGED IN FOR ABOUT 6 HRS I NOTICED THAT THE SIDES OF THE FREEZER FELT VERY HOT . IS THIS NORMAL ?...
It had to run longer than normal to cool down the freezer again. The heat from the compressor running is what you feel.
I would not worry about it unless it is still hot after 24 hours. Then there is another problem.
May 03, 2009 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Left refrigerator door open over night, next day it stopped working
sounds like you sucked in a lot of warm air over night freezer still working? just the refrig went out???easiest solution empty unit completly, unplug and leave doors open let al frost melt out 24 hrs later plug back in and you should be find
Feb 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
