Tried new batteries,no change! When I hold unit near middle side unit stops flickering for a short time? Any ideas are welcome. How do you open the unit? Since Magellan dropped support once production stopped my only recourse is to try to fix it myself. Magellan has lost a future customer since they only support their products while they are selling them!!!
Ray E.
SOURCE: Magellan Roadmate 360?
You can download the latest firmware here:
http://www.magellangps.com/support/notes.asp?supportID=290
It looks like your right, and it is no longer supported..
perhaps with the Magellan RoadMate PC application, there may be additional download available...
SOURCE: magellan maestro 3100 gps
Did you try to install the "Region Update 2.18" from magellangps.com ?
SOURCE: magellan roadmate 760 gps receiver
unfortunately you have to purchase the unlock code from magellan. You contacted magellan and the unit is no longer able to be unlocked? Once I have more information I can assist you further.
Thank you,
lee
SOURCE: i dropped my magellan gps system and need to order
How could you lose the Sim on dropping it?
Any new sim card or SD card really will fit it. But if you are looking for map replacement then Magellan are the only people who can supply the correct maps. There is a charge for maps $150 approx. So be aware that they do not replace maps of SD cards free. You will need your serial number, as these are tracked to stolen GPS before any new map0s are provided.
Please rate my
help++++Thanks for using FIXYA
SOURCE: Magellan Roadmate 2000.. No GPS signals
make sure the
battery is charged up good, then take it outside and turn it on and
leave it in clear view of the open sky for up to 30 minutes to acquire
the satellites especially if its been reset.
if that fails, reset
the unit...turn it on, then locate the reset button on the left side bottom of the gps and use a paper clip to depress the reset switch...it should restart on its own..take it back outside
and let it in clear view of the open sky for up to 30 minutes.
if
that fails..go HERE and get the update and follow the instructions..you will have to sign on to the Magellan site
before you can download anything.
if you need more help, just
post back
bill
