GE DBSR453EBWW Electric Dryer Logo
Posted on Mar 25, 2009
Dryer takes many cycles to get clothes dry
My GE dryer is currenty not drying clothes without many cycles and a lot of time . The dryer vents are all clear.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 26, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
199
Points
While researching my problem I did find that the dryer vent hose could be partially clogged. The hose should be short and horizontal.
Takes turning on the drying cycle several times in order for the clothes to be dry.Is there a “best” setting to use?
A clothes dryer is as simple as heat and airflow just like a hair dryer. If you have heat then you are probably lacking airflow. Check that the vent is not crushed or pinched behind the dryer and also make sure the main line is not full of lint or anything else that could be blocking airflow. If this is beyond your skill, strength, or aggravation level then you can call a dryer vent cleaning company. Timed dry cycle is the old reliable setting and clothes should be dry between 30 and 50 minutes. The "best" cycle on a dryer is one that utilizes a moisture sensor bar and thermister to determine drying time without over drying the clothes. This will be found on cycles other than timed dry if your dryer has that feature. Always pay attention to the care labels on your clothing as they will tell you how to care for your clothing such as "tumble dry low temperature".
Feb 21, 2018 • Dryers
I have a GE model # DCVH680EJOMS front end loading Dryer and it seems to take multiple cycles to get my clothes dry. I discovered that Water is collecting in the flexible exhaust tubing...not just a...
Hi and Welcome to FixYa. I am Kelly
You already have discovered the problem. Lint has built up in the vent / exhaust ducting. Most of the time the through the wall vent flapper gets lint build up on it outside the house and then as that restricts airflow you get condensation in the ducting. The condensation causes the lint to form a cake like paste inside the ducting. THOROUGHLY Clean out your vent ducting from the dryer connection all the way thru the outside wall and your dryer will be fine. If you need to replace the ducting please do so. Ducting is cheaper than the electricity you waste on clogged ducting. You proved your dryer will work correctly when you dried a load of clothes with the ducting removed.
Thanks for choosing FixYa
Kelly
2answers
Dryer takes 4-5 hours todry clothes dryer seems hot just not drying
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Dec 08, 2009 • GE Dryers
3helpful
2answers
My dryer takes long time to dry the clothes. It
Check the following areas thoroughly to address this issue.
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
NOTE***(This unit is equipped with a dryness control board. if all points above check out ok, replace this board).
2helpful
My dryer takes 2 to 3 cycles to dry my clothes.
Check the following areas to combat this issue. in most cases, this will be a Venting issue.
1. Venting
2. Thermostat
3. Heating element
1helpful
GE DNXR47GW1WW Dryer is extremely slow to dry clothes (takes over 2 hours per load). The dryer does heat. Any suggestions?
1. Venting
2. Thermostat
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective. (if this is a gas dryer, please disregard this statement)***
Jun 16, 2009 • GE Dryers
1helpful
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
1. Venting
2. Thermostat
3. Heating element
Not heating properly, many cycles to dry loads
Check the following to address this issue--
1. Venting
2. Thermostat
3. Heating element
1helpful
Does not completely dry clothes in the time it used to
For Electric Dryers, check the following---
1. Venting
2. Thermostat
3. Heating element
For Gas Dryer, Check the following---
1. Venting
2. Thermostat
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 • Dryers
Top GE Dryers Experts
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
