Question about Motorola Mobility E398 Cellular Phone
Alarm function dead
The alarm function is still listed under Office Tools, but when I try to create a new alarm nothing happens. Both the Select and Exit buttons appear to be inactive. Any help appreciated!
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 91 Answers
Go to settings then initial setup and then go to master clear. normaly code will be 000000 or 123456 or as u have kept
Posted on Aug 23, 2007
Please assist me on how to set alarms to my Gps when i get close the destination i am heading to.
to create a proximity alarm for one of your waypoints is a very simple process. First you will want to create a waypoint for you destination. Be sure to name the waypoint something that will remind you of the destination. After this is done go to your main menu by pressing the "menu" button 2 times. Navigate to the "proximity" icon select it by pressing "enter" it will now allow you to create a proximity alarm select the open space and press "enter" it will now give you a list of items you can use select "waypoint" using "enter" and pick the waypoint you created earlier. now all you will have do is select a radius for thee alarm. You can also use the other items to create your proximity alarm such as cites addresses and any other navigation category.
Hope this helps!
Mar 15, 2011 | Garmin GPSMAP 76CSx GPS Receiver
Alarms
press ok..tools..alarm..select the alarm u setup..here is where u can turn on /off by toggle with the left / right softkey (dismiss)...alarm is off
May 29, 2010 | Sanyo Katana LX Cell Phone
HOW DO U SET ALARM
To create an alarm follow the steps below:
  1. While in standby mode, press the Menu / OK button
  2. Select Tools
  3. Select Alarm Clock (9)
  4. Highlight the desired Alarm, using the navigation keys, from the following:
    • Alarm #1
    • Alarm #2
    • Alarm #3
  5. Press the Menu / OK button
  6. Set alarm to On, using the navigation keys
  7. Set alarm time, using the keypad
  8. Select either A for AM or P for PM, using the navigation keys
  9. Press Menu / OK button to choose the Ringer Type from the following:
    • Single Tones (1)
      • Tone 1 through Tone 9
    • Ring Tones (2)
      • Ring Tone 1 through Ring Tone 15
    • Melodies (3)
      • Ball (1)
      • Caribbean Cruise (2)
      • Chorus of Clocks (3)
      • Right Here (4)
      • Guitar Man (5)
      • Latin Lady (6)
      • Minuett (7)
      • Mixed up World (8)
      • Pressure (9)
      • Simply Blue (10)
    • My Content (4), for previously downloaded music
  10. Select desired Repeat frequency, using the navigation keys, from the following:
    • Daily
    • Once
    • Mon to Fri
    • Sat & Sun
  11. Select the Snooze Interval, using the navigation keys, from the following:
    • 5 Minutes
    • 10 Minutes
    • 15 Minutes
    • 20 Minutes
  12. Press the left soft key for Done to save the alarm changes
Dec 16, 2009 | Samsung SPH-M500 Cellular Phone
1995 ford escort, alarm keeps going off and car wont start
The alarm brain should not be the easy to locate if stock. Put everything as it was. The alarm brain, control, module or whatever any one wants to call it is most likely behind and under the radio possibly on the floor but in that area. That is if it is OEM if not then it should have been installed under the instrument cluster. I should be a small box probably held with zip-ties and it should have all the information, manufacturer, model and wire functions on the brain. If you think he found the right thing then have him look for the red wire that connects to it. It should have a 15amp fuse on the cable. If its taken out this will disable the alarm. What ever he found should say Security, Alarm or something like that. Not door control or anything other.
Jun 20, 2009 | 1995 Ford Escort
Set alarm clock?? transfer mp3 to phone... ???
you can try and master reset and master clear the phone if that does not help then try having the mobile firmware reflash, this should correct any issues that you had earlier.
Mar 20, 2008 | Motorola Mobility RAZR V3
Alarm snooze
prees the menu button'
select the Office tools
scroll down and select the alarm clock
you can choose by pressing the right soft key
by choosing the disable the alarm clock..
Jan 08, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola E815 alarm full
At the alarm screen, highlight one of the alarms, then press the main menu button, several choices, including a delete option will be given. There is even a delete all option
Dec 17, 2007 | Motorola Mobility E815
My alarm clock is full!
Yes delete them or edit them if chose or for some reason can't delete.
Feb 14, 2007 | Motorola Mobility RAZR V3
Help setting alarms
To set an alarm for an event: 1. Create a new event or double-click an existing event. 2. In the New/Edit Event dialog box, select the Alarm check box. 3. Click the time interval selector and select Minutes, Hours, or Days. 4. Type a number between 0 and 99 in the Time Measurement box. 5. Click OK. To set a default alarm for all new events: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Date Book tab. 3. Select the Alarm Preset check box. 4. Click the time interval selector and select Minutes, Hours, or Days. 5. Type a number between 0 and 99 in the Time Measurement box. 6. Click OK. Setting Alarm Options You can configure the Alarm Manager settings for the Desktop application in the Alarm tab of the Options dialog box. To set Alarm options: 1. From the Tools menu, choose Options. 2. In the Options dialog box, click the Alarms tab and click one of the following actions: * Always available: Click this option if you want alarm notifications to appear regardless of whether the Desktop application is running. * Available only when Palm Desktop is running: Click this option if you want alarm notifications to appear only when the Desktop application is running. * Disabled: Click this option if you do not want alarm notifications to appear on your computer. 3. If you want an alarm tone to sound when the alarm notification message appears, click Play audible notification with alarm dialog. 4. Click OK.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Motorola Mobility E398 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
