Question about Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC
Automatic garbage value taking in turbo c++
I cant even run simple programs involving addition of two numbers. compiling the program gives "success" but on running the program the compiter automatically take numbers (~7816 - the first no. and 0 as the second number and give the sum 7816).i am using the borland turbo c++ 1991 year version on my win XP media center edition 2005 pc. plz help me soon....
  • 104 Answers
When you are define the parameters you should initial them with zero. unless you do so the system will initial, then they will receive random number or minimum number.
Posted on Aug 23, 2007
Write a program that accept a number and output its equivalent in word
Use the value that will be printed by the keyboar.
After you enter the value.
You have to cast the type you have used as integer or float into string or character type.
So here the type casting of the datatype will be used.
Oct 10, 2011 | Borland Turbo C++ 4.5 Full Version for PC
How to garphics program in turbo c++ 4.5 ? Please give an elaborated example.
problem is not turbo c++ but your windowswindows only upto xp support bgi graphics vista and 7 doesn't.You can compile the program on any xp machine or try Linux.orTry using the visual studios to compile on windows.You can easily search on how to compile c/c++ in visual studios
Jul 04, 2011 | Borland Turbo C++ 4.5 Full Version for PC
I want to transfer a program written in c++ language in microsoft word to turbo c++ what I have to do?
You have to copy and paste the program in new file in turbo c++.Compile it and correct errors and run it.
Nov 30, 2010 | Borland Turbo C++ Suite 1.0...
Turbo C/C++
64 Bit operating systems like Windows Xp64, Windows Vista64, and Window 7 will no longer run 16 bit applications and this includes Turbo C 2.01/Turbo C++ 3.0/3.1 or the programs they produce.
Turbo C 2.0 was first released in 1989, Turbo C++ 3.1 in 1991 making these programs nearly two decades old. They are just too old to run on modern PCs.
Upgrade To Modern Compiler
Note that Turbo C/C++ is very very very very old and produces 16 bit programs which no long run on many modern computers. So the best advice is to upgrade to a new compiler. There are many free compilers out there that you can use.
Free Compilers:
  • Microsoft Express 2008 -- Great compiler and comes with a nice IDE (Visual Studio)
  • MinGW -- Command line compiler but there are many IDEs that use it such as Code::Blocks, Eclipse, Dev-C++
  • Borland C++ 5.5 -- Will compile Turbo C++ programs (including graphics.h) but produces 32bit code (slightly better than Turbo C) Only includes command line tools.
  • DigitalMars -- Its still old but at least it produces 32bit programs (better than Turbo C). You might stumble across D++ which is a very powerful language derivative of C++.
  • OpenWacom -- Again, nearly as old as Turbo C, but it produces more modern 32bit applications! (this project is still active too).
If you are just working with C there is:
  • Pelles -- and excellent modern C compiler and IDE. Pelles also has the new TR1 libraries available so you can use regex and other new features. As well as support for many older libraries.
  • LCC-Win32 -- Used as the basis for many of the research compilers.
  • Tiny C -- is said to produce very fast programs.
All of the above are Free and all excellent replacements for Turbo C which is so old it will not even run on your computer.
May 24, 2010 | Microsoft Windows Vista Ultimate Edition
Can you help me make a program using turbo c that will show floor plan of a building and time schedules of it? please
write a program that will display the following pattern, given the value of n.
example: if n = 4, output
Jan 09, 2010 | Computers & Internet
How to knw that a given memory contains a garbage value or some allocated value thru a program(garbage collector)
just check it against a condition which checks whether the variable is already assigned a value. if not it probably has a garbage.
Oct 20, 2009 | Borland Turbo C++ Suite 1.0...
Can anyone tell how run java program in cmd prompt???
You need to type:
If it's a program.class
java program
or of it's a program.jar
java -jar program.jar
Apr 03, 2009 | Sun Java Programming Language (cdj-275)
Do while
a very simple example scriptlet:
#include <iostream>
int main()
using namespace std;
int i=1;
cout << "value of i:" << i << endl;
} while (i<=10);
return 0;
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
I have vista 64 bit osis there any tc/c++ compiler that can run
You may try donloading Dosbox which is an Excellent program for running all 16bit and 32bit Programs
you can checkout Dev++ which is a C++ compiler for all 64bit and 32bit Operating Systems as an option. Search it on Google and Download it may be better compiler for Vista than the traditional C++!! Rate if the answer helped!!
Feb 02, 2009 | Microsoft Windows Vista Ultimate Edition
Compilation error in Turbo c++ 3.0
Can send your program to me i will try to clear it
Feb 22, 2008 | Borland Turbo C++ Suite 1.0...
Open Questions:
how to write c/ c++ sourcecode for Merkle-Hellman Knapsack Public Key Cryptosystem ??? In this problem you will implement the Merkle-Hellman Knapsack cryptosystem. The encryption and decryption algorithms are based on solving a knapsack problem. The knapsack problem consists of finding a way to select some of the items to be packed such that their sum (the amount of space they take up) exactly equals the knapsack capacity (the target). Formally the knapsack problem is as follows: Given a set S = {a1, a2, ..., an} and a target sum T, where each ai >= 0, is there a selection vector V={v1,v2,...,vn} each of whose elements is 0 or 1, such that (ai*vi) = T. The idea behind Merkle-Hellman scheme is to encode a binary message as a solution to a knapsack problem reducing the cipher text to the target sum obtained by adding terms corresponding to 1s in the plaintext. That is, blocks of plain text are converted to knapsack sums by adding into the sum the terms that match with 1bits in the plaintext as shown below: Plaintext: 1 0 1 0 0 1 Knapsack: 1 2 5 9 20 43 Cipher text: 49 Plaintext: 0 1 1 0 1 0 Knapsack: 1 2 5 9 20 43 Cipher text: 27 The receiver will have to use the cipher text (the target sum) to recover the plaintext. A knapsack problem is said to be ``easy'' if {missing}. The solution for the easy knapsack problem is straightforward, and can be achieved in O(n).Furthermore, there exists a way for transforming an easy knapsack set S into a non-easy knapsack H simply by multiplying the elements of S by w mod n where w and n are well chosen integers. Formally the terms of H are: hi = (w*si) mod n. For example if S = {1, 2, 4, 9}, w = 15, and n = 17 then H = {15, 13, 9, 6}. Encryption algorithm (executed by the sender) H is called the public key and is made public by the receiver Choose w and 1. n such that n > max(S) and n is prime, and w < n. Construct H from S, w, and n. Sender uses H to encipher blocks of m bits P0 = [p1,], P1 = [pm+1, pm+2...p2m] and so forth (m is the number of terms in H), as follows: Ti = Pi*H = (pj*hj). Thus T0 = P0*H, T1 = P1*H and so on. Ti are then transmitted to the receiver via a reliable channel. 1. Decryption algorithm (executed by the receiver) The tuple (S, n, w) is called the private key and is kept secret by the receiver Use w and n to compute w-1 where w-1*w = 1 mod n. if n is prime then w-1 = w (n-2) mod n 2. Compute Ai = w-1*Ti mod n 3. Find Pi by solving Ai = Pi*S Input file The input consists of N test cases. The number of them (N) is given on the first line of the input file. Each test case begins with a line containing a plaintext to be encrypted. The second line contains the number of elements (m) in the knapsack S that show in the third line. The knapsack elements are positive integers separated by space. The fourth line of each text case contains n and w in this order separated by space. Output file Print exactly 3 lines for each test case. The first line should contain the encrypted values of the plaintext of the set separated by space. The second line should contain the plaintext obtained by applying the decryption algorithm to the plaintext, preceded by `Recovered plain text: '. The third line should contain the value of w-1 Sample Input 2 Salaam! 4 1 2 4 9 17 15 hello there? 4 1 2 4 9 19 7 Sample Output 29 25 22 16 22 28 22 16 22 16 22 44 9 16 0 24 Recovered plain text: Salaam! 8 23 7 23 20 23 21 23 21 23 36 9 0 29 14 23 7 23 20 29 9 23 20 15 36 0 16 Recovered plain text: hello there? 11
Feb 24, 2009 | Borland Turbo C++ Suite 1.0...
Borland Turbo C++ Suite 1.0 (TCB0000WWFS180) for PC Logo
251 people viewed this question
Top Borland Computers & Internet Experts
Robin Hill
Robin Hill
Are you a Borland Computer and Internet Expert? Answer questions, earn points and help others
