Question about Philips 9P6040C 60" Rear Projection Television
Philips 30PF9946/12 Sound but no picture, customer says sometimes it apparantly flashes on for a split second when set turned on, but I havn't seen this.
  • 2 more comments
  • Anonymous Dec 09, 2007
    no picture but sound
  • zecas May 28, 2008
    LCD doesn´t switch ON, sound is OK and change when change channel but no image. Whem switch on or OFF there is 1 sec that LCD becomes white and after turns black.
  • xiaoyu Aug 13, 2008
    power on but dark screen
  • shahfaisa Jan 23, 2009
Power on, can hear sound but no picture.
any suggestions
Posted on Aug 31, 2008
  • 3 Answers
This is most likely a problem with your inverter board, i have repaired a lot of these for years now have a look at my website for more info, all work is guaranteed.
thanks
andy
andys electronic stuff
Posted on Oct 05, 2010
  • Philips Master
  • 3,459 Answers
Check the site www.tvrepairkits.com. They have a few kits that fix the above problems with the Magnavox TV sets.
Posted on Oct 12, 2008
O yes, whe have the same problem to!
Posted on Feb 23, 2008
LCD TV backlight goes off but still sound is present. Sometime it happen within few minutes and sometime take 30 minutes plus. Is that inverter Problem or CCFL? how I can rectify?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Feb 12, 2016 | Philips Televison & Video
Have 40" Flat screen TV, first time use, have sound, and can switch channels, but the picture only stays on for a split second, Brand new just out of box.
read instruction manual and or call the customer service for the brand you have, last resort call the store where purchased and see if they will help.
Dec 03, 2012 | Televison & Video
No picture on screen
Is the TV under warranty? If it is don't muck around, contact them straight away as you have a electronic problem with your screen.
Before that make sure the yellow chord is in the visual port and red and white into sound. 2) If thats all good try an experiment, as you know the sound is good, use one of the sound cables to replace the yellow. Is there a picture now? If so replace chord, if not make contact to exchange for warranty.
Sep 02, 2012 | X2Gen MV32T8 32 in. LCD Television
TV will power on and the picture and sound will be seen after a while or immediately. Then it clicks and no sound, no picture, but blue power light stays on. It can do this for 5 minutes or past an hour...
I would suspect dying power supply module, I would look for caps with domed tops first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Jun 14, 2011 | Philips 42PFL5332D 42 in. LCD Television
Hi, I have just bought the Fuji JX530. When I take a picture I get a split second clicking sound coming from the lens before the flash goes and the picture is taken. The picture is fine and the...
When you press the button, the camera performs many functions in a split second such as set the focus, set the aperture and shutter speed, calculate the flash power, etc. It will make sounds and if the pictures are fine, then all is well.
Jan 05, 2011 | Cameras
No picture
have you found the soln. pls let me know i m also facing same problem. kashyap@nic.in
May 30, 2010 | Philips 47PFL7403D 47 in. LCD TV
Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
May 29, 2009 | Philips 47PFL3603D LCD TV
Model 9p6034c102 picture going out
If you have no sound or video or if your screen keeps shrinking and expanding its typicaly the opto chip. You can get the chip and repair instructions from www.magnavoxhelp.com . This is a fairly common problem.
Sep 02, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Jul 13, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Picture fails
hi,
sounds like a high voltage issue, it will have to go in, i dont recommend self servicing that. may sound strange but Ive seen several tvs go by way of spouse having a plant above or near the tv, that person watering it and a few hours later mad spouse sitting in front of a busted tv that sounded just like that. also I had a cat that sprayed one and it did that. just a couple ideas for ya.
J
Jul 12, 2008 | Philips Televison & Video
Philips 9P6040C 60" Rear Projection Television Logo
749 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
