Question about Hotpoint NBXR463EBWW Electric Dryer
Hotpoint DLB2450RAL i replace the timer and my timer still doesnt work. any help..on what next to check.barry
  • muskin Aug 24, 2007
    I tried removing the hose on the vent and still the timer did not move. I check the voltage on the timer and it was 0. I ohmed the timer and I got 2.5, does this sound correct? If the timer is good and the vent is removed and the timer still doesnt move, what would be the next thing to check?
    Thanks Jennifer
On auto dry settings, the timer doesn't get voltage until the regulating thermostat is satisfied. A clogged vent will cause this problem, as the dryer is cycling the heat on the hi limit thermostat. disconnect from vent and see if the problem goes away. Also, remember that a voltmeter doesn't lie.
Posted on Aug 23, 2007
Not heating up hotpoint 9303
Try flipping breaker all the way off than back on. If you have a volt meter check voltage. Next unplug and check cord connections,on back if all good check vent fir clogged if still not working problem inside thermostat fuse timer board belt switch There's a lot to check
Mar 30, 2016 | Hotpoint Dryers
Tip
I have a Hotpoint DLB2450RAL and I was having no heat, but drum was turning. I...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on Jun 17, 2009 | Kenmore 62602 Electric Dryer
Hotpoint TVM572 timer is faulty
It is important not to open the door of the dryer if it is still running. The timer controls the cooling cycle otherwise the clothes will get damaged if kept on hot.
It is very likely the timer contacts are frozen at some point and the timer will need some attention.
It is not hard to locate it. I cannot find the actual parts drawing for your model (it is good you have provided the full model details). But to help you locate the part I have found another Hotpoint model that may be similar to yours. Check this drawing to see if the front panel is similar.
Item 100 is the timer.
HOTPOINT Electric Dryer Backsplash blower moto Parts Model NWSR483EB1WW
The actual timer for your model looks like this.
Hotpoint TVM572P Timer
As the clothes are not getting burnt or singed I will assume the thermostat is ok and keeping the temperature within the range.
Aug 07, 2014 | Hotpoint Dryers
Dlb2450ralwh dryer
Part number is WE11X103 if that's what your needing.
http://www.searspartsdirect.com/partsdirect/part-model/Hotpoint-Parts/Dryer-Parts/Model-DLB2450RAL/1811/0151200?searchedModel=Dlb2450&blt=06
Above is a link to parts breakdown. Use this ONLY for information, wouldn't buy anything from Sears unless you can't find it cheaper (which you can). At least it will give you a general idea about parts and disassembly.
Nov 08, 2013 | Hotpoint Dryers
My dishwasher does not complete a cycle. It continually washes and just keeps washing without going on to rinse and dry.
Thier are 2 possible things causing the timer not to advance(without knowing the model# i am assuming it does have a timer as oppesed to a touchpad/electronic control)
1) the timer motor is defective and it isn't advancing to the next cycle..to repair that the timer needs to be replaced
2) IF EQUIPPED on your model..the part called the energy option switch is bad and it needs to be replaced...GE/Hotpoint dishwashers used this energy option switch on several models and when it was bad it would not send power to the timer.
If your model has a energy option switch i would highly suspect that as being the problem
GENE
Sep 07, 2011 | Hotpoint Dishwashers
Lights flashing
temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Jul 13, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Have a hotpoint model ctx16bazbrwh. its stuck on auto defrost. runs for 8 hrs. which part do i need to replace?
You need to replace the defrost timer.It is usaully found next to the thermostat control in frig compartment. You will have to remove cover and two mount screws to replace. Hope this helps
Jul 29, 2009 | Hotpoint Refrigerators
Turned knob and got a buzz. turned knob again and no sound. Just finished a load and was starting on the next.
Hi. im assuming the buzz came from the timer knob(behind the knob). if so, this will confirm timer failure and, you will need to replace this timer control module in order to restore proper function to your unit.
If the buzz was located behind the start switch, replace as well.
May 21, 2009 | Hotpoint Dryers
Hotpoint NBXR463EBWW Electric Dryer Logo
112 people viewed this question
Top Hotpoint Dryers Experts
jimorris77
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
