Question about Teac P-55 Thermal Printer
Transfer ribbon printer will no transfer on to disc as it can not see Clear transfer ribbon. printer is 10 month old
Remove the transfer cartridge, loosen the ribbon slightly and put it back in. This works for me!
Posted on Sep 28, 2007
SOURCE:
How to clean the print head
No easy way to clean the print head. You will need to remove it from the printer to gain access to the area to clean. What does the label look like on the disc? Streaks is probably a dirty print head. If sections of the label are missing it could be the print head or heat roller. Look at the re-transfer (clear) ribbon. If the missing part of the label is left on the ribbon you have a heat roller issue.
Mar 12, 2013 | Rimage Everest II Printer
Using CD Designer I try to print my disc on my Everest II printer and it appears to be printing and then the tray opens and the disc is blank - "no image printed on the disc" I do not get any...
Check the ribbons. If your CD image is still on the color ribbon your print head is probably bad. If the image is on the transfer ribbon replace the heat roller.
Apr 17, 2011 | Rimage Everest II Printer
When i try print the label..no output at the label..how to test whether the ink is function or not
I'm including this link to the users manual:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
But here is the basic troubleshooting info for that issue
No print on the label.The media may not be direct thermal media when printing without ribbon (i.e. thermal
transfer). See the test procedure
Determining Thermal Media Types on page 29.
• For thermal transfer printers, the media may not be outside wound or approved for use in
the G-Series printer. See the following ribbon test procedures: Ribbon Test with Adhesive
on page 32
and Ribbon Scratch Test on page 33.
• Is the media loaded correctly? Follow the instructions for
Loading Roll Media on page 11
in the Getting Started section. For printing using transfer ribbon, see
Loading Transfer Ribbon
on page 14.
Mar 28, 2011 | Zebra GK420t thermal transfer and thermal...
I have a few Datamax-I-4206 printers and some of them have the Thermal Transfer ribbons and some do not....Do I need to have Thermal Transfers or cant I just print to them without it?
If the unit is set up for either(with the thermal trasnfer option- ribbon unwind and rewind assembly) you can use either ribbon- with thermal transfer stock, or direct thermal- with direct stock.
You can tell the stock by rubbing something across the stock to see if it will turn black, that is direct thermal stock.
If using direct, go into the setup and select media type- direct thermal.
If using ribbon- use thermal trasnfer option. But remember to install ribbon before calibration as ithe printer will error on out-of -ribbon.
Dec 31, 2010 | Datamax DMX I-4206 Printer
Ribbon feeds out with label on the intermec easycoder PM4i
check setings Printer or Driver
(Direct -Thermal - labels without ribbon or Thermal transfer if use ribbon).
2nd solution install segull drivers (www.seagullscientific.com) and you can reset to factory defult if you need.
Oct 15, 2010 | Intermec EasyCoder PM4i Printer
I have an old Zebra 140Xill, will this do direct thermal transfer, do not have the manual
Press cancel for 5 seconds while power on to print config. Then check the following parameter.
direct thermal = no ribbon
thermal transfer = ribbon
Sep 16, 2010 | Zebra 140XiIII Plus Thermal Label Printer
110xi111plus error code: warning ribbon in? what does that mean?
that ribbon occures when you are set for thermal direct printing in the driver or printer and you should be set for thermal transfer in the driver in printing defaults off of the advanced tab and the printer needs to be set for thermal transfer in print method in the setup menu. thermal transfer is printing with black ink ribbon and paper and thermal direct is just chemicaly treated paper.
Jul 02, 2009 | Zebra Printer 140-751-00000
Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Jun 03, 2008 | Datamax DMX-I-4212 Label Printer
Vertical fading lines
Sounds like dust on the CMY ribbon. Did you try a new color CMY ribbon?
Possibly the printer has dust floating around on the inside, but if balck prints good, that may not be.
- techwaredit
Apr 01, 2008 | Rimage Everest II Printer
Teac P-55 Thermal Printer Logo
190 people viewed this question
Top Teac Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Teac Office Equipment and Supply Expert? Answer questions, earn points and help others
