Question about Creative Labs Nomad Jukebox Zen Xtra MP3 Player
Zen Xtra I want to upgrade my hard drive is it just a 2.5" notebook hard drive? What is the max Gig and rpm it will support?
I can do it for $40 I have done it on several before. I only use 3 year warranty drives. Thats $40 plus the shipping both ways about $10 and the cost of the drive which is $76. The Drive is Brand New Western Digital and has a 3 year Warranty. I guarantee all my work. Use the link below and email me.  http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=260169183066
Posted on Oct 11, 2007
My nomad zen jukebox is stuck in rescue mode and still not working correctly
If you can boot into the Recovery Mode menu, run the Disk Clean-Up option from there. As long as your drive isn't physically damaged, it should be able to fix your problem.
> You can try the "Clean Up" option in Rescue Mode. - let it run for a few hours, and then try to reformat. if that dosnt resolve it then you know its almost gone.
If the hard drive is mechanically damaged (as it most likely is - the drives used in the Zen Xtra are rather fragile compared with current drives),As for recovering the files from your existing drive then the only possible way to retrieve the data stored on it is to utilize a Data Recovery Service but it will cost you a lot except if still under warranty
you can only replace the hard drive Taking the Zen Xtra apart is rather easy - two screws on the back, and that's it. The Zen Xtra uses a standard laptop hard drive, so it'll be easy to locate and install a new one - just be sure the new hard drive you install has a current rating equal to or less than the current rating for your existing drive. To remove the hard drive, you'll need to pop off the front cover, remove the battery, and remove the four broad-head screws that retain the hard drive in place. Then carefully pry the top end of the hard drive out, and pull it away from the case, pulling from the top end.
When you install the new hard drive, you will need to re-install the firmware.
Sep 11, 2009 | Audio Players & Recorders
Need a driver for a creative, nomad jukebox/zen xtra 30 gig. player for my vista...if i could it would be awesome !
download "MEDIAMONKEY" it will sync most mp3 players and is a cool FREE media player and ripper/tagger aswell.
Aug 04, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Zen Xtra Error Message When Creating Playlist
The only solution I know of is to reformat the hard drive. It's pretty time-intensive, but it does work. I use Notmad to back up the playlists. Once restored, they all work, even the ones that had initially failed.
I've never had the problem on my 60GB Zen Xtra (non-upgraded hard drive), only with my 120GB, so my naive guess is that the problem may be caused by the machine somehow not handling the extra hard drive space properly.
Also, both times it's happened, I've seen a warning sign: I usually have a lot of stuff loaded into "selected music", and when I add another album or two it partially clears the selections. And it does so in a weird way: only a few selections remain visible, yet it keeps playing at least some of the now-invisible selections.
I'm starting to think it's time to switch players, and maybe get something I can put the Rockbox OS on.
Feb 02, 2009 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Pp1020 harddrive
Hi doug160451,
Could you please post the specifications of your laptop, but if your laptop originally came with a 5 Gb Hard Drive then chances are it would be an old laptop and you would do better upgrading to a new laptop than go through the problems associated with upgrading only your hard drive.
Cheers
CptHaddock
Nov 07, 2008 | Compaq Presario Notebook
Upgrade Notebook hard drive capacity
hi there,
you Dell Latitude D610 can support large hard drives from 100gigs up to 250gigs ... but i very much think this is the limitation of your system bios if u are looking to go higer ... u might need to upgrade your system bios.....
Apr 07, 2008 | Dell Latitude D600 Notebook
My Nomad zen xtra 40gb is stock !!!
It sounds like the hard drive may be damaged. Have you tried to put it in recovery mode?
Put a paperclip in the reset hole while holding down the play button until you see the screen go to recovery mode. Then try the format option; this will erase all your files but it will tell you if you need a new hard drive.
Mar 24, 2008 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Creative Labs Nomand Jukebox Zen Xtra
Zen Nomad Xtra - to go to Rescue Mode do the following:
1. Insert a pin into the small hole on the left side of the player
below the volume adjustment switch.
2. Hold down the Play button on the right side of the switch
3. Rescue Mode Menu will appear
4. There are 4 Options available, but best option to fix most
problems is reformat hard drive.
5. Reformat is very fast
6. Turn off and reboot.
7. Problem solved.
Oct 31, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Jukebox Zen Xtra 40 gig
You probably have Winders Media Player 11. If you can find another computer that has WMP 10, you can use that computer to do the firmware upgrade, then go back to the original computer. Thingsa should work fine. Otherwise, you need to unistall WMP 11 and WMP11 runtime. Another case of Billy messing us up. And don't even get me started about vista....
Aug 14, 2007 | Creative Labs Nomad Jukebox Zen Xtra MP3...
Player Won't Load Any More Music
Try with downloading the latest driver from their website.
Feb 27, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
48 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
