Question about HP Compaq nc6220 Notebook
Dark laptop display
Can barly see the display. have replaced the screen with a brand new one and also the inverter board also with brand new one, item is mitac 8399, running xp.
  • conkclo Aug 23, 2007
    thks wil see if ones are available on bay site, if this dont work guess it could be totally wrecked.
  • 60 Answers
Well if youve already replaced both of those items with ones you know work then the last thing you can do is replace the LCD Cable
Posted on Aug 23, 2007
  • Peter Young Aug 23, 2007
    If this doesnt work you can be pretty sure youve got a motherboard issue. Good luck
SOURCE:
Why does my TCL tv stay dimmed and very dark screen? I've reset it and everything?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 30, 2017 | Televison & Video
My screen has gone very dark - what do I need to do to brighten the screen
You don't give any information about your computer, and that makes it hard to give a precise answer. But if you have a laptop, or you're having this trouble with an LCD monitor on a desktop computer, the display backlight may have quit working. Without the backlight you can only very dimly see the display. The usual reason is that the inverter board (in a laptop) or power supply (desktop monitor) isn't working.
Laptop inverter boards are pretty simple to replace, and you can find them for most brands and models now at reasonable cost. Check eBay where there are many sellers. Once you have the replacement, you just need to remove the front bezel of the display, which usually means taking out screws at the corners and releasing snap tabs around the edges. The inverter board mounts below the display panel and there are two cables connected. Unplug the cables, remove the old inverter, put the new one in and reconnect the cables and you're done. The brightness should be back to normal. (It's also possible but less common for the backlight lamp in the LCD panel itself to be bad. While it is possible to replace the lamp it is very difficult to do. It's usually simpler and safer to replace the whole display panel, although they can be expensive.)
In a desktop monitor, bad capacitors in the power supply often cause the backlight to go out. Many sites show what bad capacitors look like and describe how to remove and replace bad ones. It's a more difficult repair than the laptop inverter replacement, involving soldering on the circuit board, but it's still something you might be able to yourself.
Good luck, and thanks for using FIxya!
Aug 06, 2011 | Computers & Internet
Laptop screen is very dim. There is a very faint image. The LCD screen is brand new so that's not the problem
As per your description, it is probably your inverter which is faulty.
The inverter is an electrical device which 'lits' the LCD. Without the inverter and the bulbs it powers, the screen would be too faint to be seen correctly.
To test if the inverter is defective, just turn on your laptop in a dark space, then put a flashlight on the screen to see if you have a fainted display. If you can see something, it is the inverter which is defective and should be replaced.
If you are handy, you can also remove the screen cover to see if there is a neon like light which lits up behind the LCD. If you can see the light, it means that the inverter is just working fine and that the is with the LCD itself, but if there is no light coming from behind the LCD, then you need to replace the inverter.
Picture of an inverter.
Replacing the inverter:
1. After removing the screen 'cover', locate a small circuit board (usually below the LCD). Unplug the electrical cables and replace.
Hope this posts helps you.
May 16, 2011 | Computers & Internet
Thinkpad T20 display is very, very dark (unreadable). Does the display need to be replaced ?
1. Test using an external monitor. If it works, then either the screen bulb or the inverter board might be defective.
2. Test the inverter. Easiest way to do it if you have a good screen with a good bulb. Connect the good screen to the inverter board & test it. If it lights up, then the inverter board is good. If it did not, then the inverter board is bad & needs to be replaced.
3. If the inverter board is good, then we are left with the possibility that the screen bulb is bad. To fix this, we will need to replace the LCD screen.
Oct 08, 2010 | IBM ThinkPad T20 2647 Notebook
VERY Dim screen after a drop
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Sony VAIO VGN-NS190J/S Notebook PC
Dell ADAMO 13 w/Vista 64 Random power failure...goes dead in 1 second. Battery fully charged. Happened with external power and when on battery. I have latest BIOS v6.0. I ran pre-boot diagnostics...
If the power totally fails (i.e. power is cut off, LEDs turn off, fans stop, ... etc), then this more likely to be because of a short circuit developing in a failing semiconductor component, or a power supply problem.
However, if the laptop is still running & only the display on its LCD is cut off but the laptop itself stays powered on, then your laptop might be experiencing a failing screen inverter board, a failing screen backlight lamp, or a failing LCD screen cable.
TYPICAL INVERTER FAILURE SYMPTOMS
Feb 07, 2010 | Office Equipment & Supplies
Display is dark
try to adjst the brightness and the contrast..
Feb 21, 2009 | Dell Inspiron E1505 Notebook
Acer aspire 5315
Since the Acer Aspire 5315 works except that the display is dark, then it would be safe to assume that it is only the LCD display part that is the issue. Often LCD display (of laptops) are working but only that you can not see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Acer Aspire 5315.
This would be a good place to start for inverter boards. This is a nice tutorial if you are considering a DIY.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 08, 2008 | Acer Aspire 3100-1405 Notebook
Data Shows up only on External Monitor, not on Laptop Screen
Since the laptop works on the external monitor, then it would be safe to assume that it is only the L:CD display part that is the issue. Often LCD display (of laptops) are working but only that you can see the actual display. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen. If the desktop could be seen (albeit very very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps.
Often, the defective component would be the inverter. It is relatively easy to replace the inverted. It is sometimes more difficult and challenging cracking open the casing of the display panel of the laptop than replacing the inverter. Additionally, inverters are readily available online. It is also not surprising that inverters for other brands/models would also be used in your Toshiba.
In some worst case scenario, it could be the video interface or even a loose/open flat cable from the laptop's main body towards the LCD display panel.
May 08, 2008 | HP Pavilion dv9000z Notebook
Very dark screen
If the desktop could be seen (albeit very dark background) then it could either be the CCF Lamps (cold cathode florescent) or the inverter that powers the lamps. One way to verify is to shine a flashlight at an oblique angle to the screen, semblance or part of the desktop could be seen.
May 07, 2008 | Toshiba Satellite L20-S310TD Notebook
HP Compaq nc6220 Notebook Logo
175 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
