Question about Sony Ericsson Akono HBH-602 Consumer Headset
Sony Ericsson Bluetooth Headset
I can't get the headset to work with my bluetooth nokia 6110 navigator mobile. i was told they are compatible. Any suggestions?
SOURCE: bluetooth headset hb600 does not pair up to k800i
My Motorola V557 will not connect to the Akoo HBH-602 the search returns no devices found. My Motorola 365 returns the same result. Please give me the steps to make these phones recognize the signal.
Posted on Oct 07, 2007
SOURCE: please need help urgently
You should press both + and - button on your head set and wait until green light turns into red.
Posted on Aug 03, 2008
SOURCE: I need a passcode for my bluetooth headset
try 0000
Posted on Feb 21, 2009
SOURCE: Master reset HBH-PV702
How to restart my hendsfree? pls answer me, i can connect it with no one
Posted on Jun 07, 2010
  • 194 Answers
SOURCE: My Sony Ericsson Bluetooth headset
Posted on Mar 21, 2011
  • 82 Answers
SOURCE: I've lost the numeric passkey
The default password, as with most Bluetooth headsets, is 0000.
Posted on Jun 20, 2011
0 characters
1 Points
Sony ericsson bluetooth headset tryin yo connect
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Nov 18, 2009 | Sony Ericsson Mobile Bluetooth Car Kit...
I want to connect a motorola H700 bluetooh to my sonyericksion t616 how do I do this?
you can connect your sony ericsson t616 to your motorola h700. for that you have to switch on the bluetooth in your phone then you must switch on your bluetooth headset. after that from your phone select the option "search for any devices". but i would suggest that you can go for a sony ericsson bluetooth headset instead of any other brand,because motorola might not be compatible.
Oct 23, 2009 | Sony Jabra Earbud Headset - Ericsson T610...
Can't hear headset
Here is a list of compatible bluetooth headsets taken from the Blackberry web site.
  • Flamingo™ Bluetooth Headset *
  • Jabra® BT250v
  • Jabra JX10
  • Jabra BT125
  • Logitech® Mobile Pro™ Headset
  • Motorola® Bluetooth Headset H500 **
  • Motorola Bluetooth Headset HS820
  • Motorola Bluetooth Headset HS850
  • nXZEN™ 5000
  • Plantronics M3000 Bluetooth Headset
  • Plantronics Discovery™ 640 Bluetooth Headset
  • Plantronics Explorer™ 320 Bluetooth Headset
  • Plantronics Voyager™ 510 Bluetooth Headset
  • scala-500™ ***
  • Sony® Ericsson® Akono™ Bluetooth Headset HBH-602
  • It may be a compatibility issue with the H700. You may want to make sure the volume is turned up fully on the headset as well.
    Good Luck
    Jun 28, 2008 | Motorola Mobility H700 Wireless Headset
    Please need help urgently
    May 13, 2008 | Sony Ericsson HBH-PV705 Headset
    Motorolla H350 with Nokia N80
    You can reset any bluetooth headset by pressing the volume key and the power key pressing them simultaneously for few seconds and it will be resetted. TO connect with any other bluetooth mobile press the Power button of your headset while your mobile searches for bluetooth headset. when it asks for a pass key use 0000. now you can get connected. try this...........
    Sep 23, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
    Pairing Problem
    It may be that the phone does not play music through bluetooth and that it only plays through the earphones that come with the phone. The only way to find out is to read the documentation on the phone or try another bluetooth headset, really. The headset cannot be faulty as it pairs correctly and it works with calls. Bluetooth headsets are not really intended for playing music as it drastically reduces battery life.
    Sep 07, 2007 | Sony Ericsson Universal Bluetooth...
    Compatability bluetooth headset K 750i/K800
    Hi, The way that I paired my device is by pressing and holding the two volume buttons simultaneously for about 5 seconds, until the red and green lights began to appear. Then, i just 'refreshed' my bluetooth search for devices, and it discovered it, and was able to pair it up. Hopefully, this is useful
    Oct 18, 2006 | Sony Ericsson HBH-610a (Auto Pairing)...
    Sony Ericsson Akono HBH-602 Consumer Headset Logo
    23 people viewed this question
    Top Sony Ericsson Headsets Experts
    Justin Peters
     Mike M
    Mike M
    Are you a Sony Ericsson Headset Expert? Answer questions, earn points and help others
