Question about Sony Cyber-Shot DSC-T33 Digital Camera
Flash stopped working but camera is fine.
The camera is in fine working order, just the flash has stopped working. Where can I buy just the bulb? I suspect that this is the problem. When I go to the Sony parts site you need to be an authorised dealer to purchase parts. If I send off the camera to Sony then it cost £114 or more. Should I just try to do it myself?
    Problem Solver:
I find on at NextTronics NextTronics 1001 S. Capitol of Texas Highway Building L. Austin, TX 78746 USA Telephone: +1 512-328-9898 +1-512-306-9599 Fax: +1 512-692-6122 E-mail: [customerservice@nexttronics.com] Item - ( FLASH UNIT ), 147897212 : $35.98 + $16.95 shipping to France What they call Flash unit is only the bulb !
Posted on Aug 23, 2007
  • 625 Answers
The camera uses a xenon flash tube. it operates off what is called a capacitive discharge circuit. a low dc voltage is stepped up to over 7 thousand volts to flashover inside the tube. try doing a search for replacement xenon flash tubes.
Camera flash will not work. Is there a fuse or can the bulb be replaced?
Check the settings... some specific settings like multi burst and video mode will not allow you to shoot with flash... Also try resetting the Camera.
Aug 19, 2012 | Panasonic Lumix DMC-FZ8 Digital Camera
How do you replace the flash bulb in sony cyber-shot dsc h10 camera?
You must send the camera in for repair to replace the flashing unit
Jan 23, 2012 | Sony Cyber-shot DSC-H10/B Digital Camera
My Nikon CoolPix S560 has worked great since I bought it about 2 1/2 yrs ago. I know how to set everything, the battery is fine and charged. Natural light photos are fine. Just recently in the middle of an...
Yes, the flash can burn out or the flash circuit can short out. You can send it in for service but, since it's out of warranty, it will be very expensive. B&H photo has a refurbished one for $70. If you send yours in, what you will get back is a refurbished one....they do not bother to fix point-and -shoot cameras. Your choice.
Jun 13, 2011 | Nikon Coolpix S560 Digital Camera
Flash of my Canon PowerShot SD1100 IS not working at all
Has the camera been dropped at all? It may need a new bulb. Most camera stores replace them rather cheap.. But if you want to do it yourself..
How to Replace Your Digital Camera Flash Bulb Like any light bulb, your camera flash bulb can blow at any time. The rest of your camera might be state of the art, but the flash bulb itself is relying on some pretty old fashioned technology. Unlike a light bulb, however, replacing a flash bulb can be a little difficult. Depending on the type of camera or flash you have, some dissection might be required.
Step 1: Choosing the Bulb There are literally dozens of different shapes, sizes and connectors used for camera flash bulbs. These will typically vary depending on the manufacturer. However, be warned, many manufacturers will use different types of bulbs in different cameras. Just because you have a Fuji camera, for example, doesn't mean you can buy any Fuji flash bulb.
Step 2: Safety First Camera manufacturers will never advise you to replace the camera bulb yourself unless you know exactly what you are doing. This is because your camera's flash uses very high voltages. A capacitor will be charged up in order to fire the flash. This capacitor can stay charged for months, if not years. If you're not confident doing this job yourself, then you will need to take it to a camera repair shop.
Sometimes if the camera is too old, you might consider using it as an excuse to upgrade it for a newer model rather than repairing it.
Step 3: Dismantling the Camera Now, you will need to dismantle the camera carefully so that you have access to the flash bulb itself. This may be time consuming and nerve-wracking. One false move could end up breaking the delicate plastic case of your camera.
Once the camera is dismantled, you should then discharge the capacitor safely so that you can continue to work on the camera.
Step 4: Removing the Old Bulb Most bulbs are soldered directly onto the circuit board. In this case, you will need to use a soldering iron to heat up the solder at the back of the bulb and carefully pull it away from the board. This can be difficult, as you need three hands to do it properly. With the old bulb removed, try to clean up the solder pads as much as possible so that the new bulb can fit properly.
Step 5: Replacing the Bulb Push the legs of the replacement flash bulb in position through the holes in the circuit board. Then, using a soldering iron and some solder, fix it in place. Be as accurate as possible to prevent shorting out the circuit. With the bulb in place, cut back the legs of the flash bulb so that it doesn't stick out too far from the board.
Step 6: Reassembly With the replacement flash bulb fitted in the digital camera, you will then need to reassemble your camera. This will be easier if you kept all of the screws in a safe place.This is the one occasion where it's a good idea to assemble before testing simply because of the high voltages involved.
Step 7: Testing Now, put the battery back in the battery and try taking a photo with the flash. Check whether it works; if not, you will need to investigate the cause of the problem
Nov 03, 2010 | Canon PowerShot SD1100 IS Digital Camera
Easyshare Z8612 IS Digital Camera: My flash bulb has blown and I need to know how to ...
May 17, 2010 | Kodak Easyshare Z8612 IS Digital Camera
Flash on EasyShare DX4330 stopped after 7 years
Most likely the capacitor or xenon flash bulb is bad. If you're a techhie of sorts, you might be able to fix it yourself, just make sure you discharge the capacitor when you open the camera up (in case it's still good, and charged). With the low prices on digital cameras today, it would probably be better to buy a new one than have it repaired, and keep this camera as a backup.
Mar 29, 2010 | Kodak EasyShare C875 Digital Camera
How to replace bulb in flash for a Kodak z710
Dec 31, 2009 | Cameras
FLASH LIGHT BULB of my DSC H1 digital camera HAS BLOWN
You need to replace flash bulb board of DSC-H1 as shown in below image. (item # 304) Part number is as follows..
A1119331A ST-124 BOARD, COMPLETE
It is available in Part Store.
Replacement of ST-14 board (flash bulb board) requires expertise and solder work.
Thanks.
Jul 28, 2009 | Sony Cyber-Shot DSC-H1 Digital Camera
Flash not working on olympus x-785 camera
devon, nicely summed up ...red light truely indicates that the flash is charging however you couldnt get it to flash becuase the bulb needs to be replaced.
Mar 25, 2008 | Cameras
Open Questions:
Sony Cyber-Shot DSC-T33 Digital Camera Logo
157 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
