Question about Admiral AAV7000A
Control Knob Replacement
The control knob has cracked and needs to be replaced. The skirt and timing mechanism are fine. How do I remove the knob?
  • 1 more comment
  • Mercury 372 Aug 23, 2007
    Have a replacement part MC 21001526 and neither it nor the broken knob has any screw fitting The Washer Model is AAV8000AGW not the 7000 as originally posted.
    Pulling the knob outward meets stiff resistance and as the machine is operated by this action of pulling out the knob I was afraid to just pull it apart with force as this might damage the control main arm?
  • Mercury 372 Feb 16, 2008
    You need to pop the front off the top control panel. At the back of the electrical control box to which the arm is fitted in the control panel, there is a release pin, pull outward and the knob is released.
When you pull it the control knob works;  however,  if you try to turn it,  it does not seem to lock on?  free flow?  like it has lost its attachment?  any ideas-suggestions please
Posted on Oct 22, 2008
  • 625 Answers
Either pull it off or look for a set screw on the bottom. could be a regular screw but most likely an allen head set screw. go to repairclinic dot com for a replacement
Posted on Aug 23, 2007
  • THOMAS MIERZWA
    THOMAS MIERZWA Aug 23, 2007
    I looked a a different site [www.partselect.com] and found the knob and skirt two seperate parts. so I'm assuming the knob part just pops off the skirt. Once you get the knob part off, removing the rest should be easy
Is the volume control easy to repair and are needed parts available?
If it is a potentiometer that controls the volume and you have some experience and a few tools you will almost certainly be able to find a replacement in one of the many constructor catalogues and be able to change it.
Modern electronics tend to just use buttons to turn the volume up or down and those have been with us for longer than we realise. In the early days of this technology the manufacturers wanted to use buttons but the buyers still wanted a nice big volume knob so there was a compromise where behind the big knob is a mechanism that presses buttons as it is turned.
I suggest you take the amp apart and take a look at which method is used. I have managed several years ago to repair such a mechanism by making a replacement pert from a piece of junk plastic.
Jan 03, 2016 | Audio Players & Recorders
Frigidaire washer control knob problem
Hi
I think the problem wont be that much serious. Try any electrically skilled labour to check the knobs and get it replaced. Dont allow those who dont know about electrical/electronic things.
Thanks
Sep 08, 2008 | Frigidaire GLTF2940ES Front Load Washer
On/off swith knob broken
Is it the actual knob that is broken or the little tab the knob holds onto that is broken. You either need a replacement knob or a replacement switch assuming the know is also the thermostat for the unit. Does that same knob control the fan speed? Temprature or timer?
Mar 31, 2014 | Pelonis Heating & Cooling
General Electric WHDSR209DWW Top Load Washer. Timer works but has lost proper synch with knob and skirt. Can force timer to a position that will run the machine from an unknown starting point. When knob...
Hello:
Its either your knob is stripped or the timer itself is..Most commonly its the knob assembly that's bad.(part# WH01X10061) I would try it first since the knob is only around $7.00 where the timer is around $140.00or so...
Good luck
Jun 04, 2017 | General Electric WHDSR209DWW Top Load...
Heat blows out at floor only and ac does not come on even though light Indicates it's on. Has rear defrost and light works..Also has recirculating air button . I'm guessing the whole heating control in...
I would first remove the fuse for the heater control head for one minute and then put in and retry.
The control head could have locked up on you with a volt spike. The rear defrost switch does not go through the same circuit in the heat as the hvac controls. Could be a broken know also.
Could also be mechanical linkage on side of heater box above accelerator pedal may have broken or popped apart. or if electrical motor control may be actuator.
#76-11-01: HVAC CONTROL KNOB SPINS FREELY (REPLACE) - (Oct 9, 1997) 999999995.gif SUBJECT: HVAC CONTROL KNOB SPINS FREELY (REPLACE ALL THREE KNOBS)
MODELS: 1996-97 CHEVROLET AND GMC M/L AND G VANS 1995-97 CHEVROLET AND GMC C/K TRUCKS
CONDITION:
SOME CUSTOMERS MAY REPORT THAT ONE OR MORE HVAC CONTROL KNOBS SPIN FREELY, RESULTING IN LOSS OF FAN, TEMPERATURE AND/OR MODE OPERATION.
CAUSE:
THE KNOB'S PLASTIC INNER SHAFT MAY CRACK WHEN FORCED AGAINST ITS STOP.
CORRECTION:
IF ANY ONE OF THE THREE HVAC CONTROL KNOBS EXHIBITS THIS CONDITION, REPLACE ALL THREE KNOBS WITH NEW P/N 16268157.
PARTS INFORMATION:
P/N DESCRIPTION QTY 16268157 KNOB, HVAC CONTROL 3
Sep 27, 2010 | 1995 GMC Yukon
The knob on my kenmore elite won't move the timer.
The knob itself turns the switch on . The skirt move the timer position. Try turning the skirt. You probably have a broken knob. On these the knob is held in place with a plastic rod inserted into it all the way. This spreads the tip and retains the knob. To get the knob off to yank out the skirt for a look see you need to pull that rod out a tad to release the knob. 88be11a.jpgThat shaft has a rounded end on it that spreads out and locks the knob on. Clever ain't it? These timers are cheaply made, if you cannot find fault with the knob or the skirt then you is gonna need a timer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 05, 2010 | Kenmore Washing Machines
The bar isn't turning on my dyson..the belt is still fine looks like maybe something with the motor?
The DC07 has a "brush control system" operated by a knob on the right side of the base. This knob has two positions: "bare floors" (or "off") and "carpet" (or "auto"). The roller will turn only when the knob is on "carpet", and even then only when the handle is tilted back (with the base still flat on the floor). The problem is that this system uses two belts, only one of which is easy to see. If you're sure that the control knob is in the correct position, and still the roller doesn't turn, then most likely the belt that you can't see is broken (that belt goes from the motor to the clutch mechanism behind the control knob).
Belt replacement on this model is not for the faint-hearted! To see what's involved, you can go to www.dysonmedic.com then scroll to the bottom of the page and click on "DC07 clutch replacement". At least you will see how to remove the clutch cover so you can check on the other belt and confirm if this is the problem or not. Then you have to decide who is to do the job!
I value your feedback, so please remember to rate this response. Good luck!
Jan 18, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Time control knob for bravetti platinum pro convection oven
Thanks for allowing me to help you. The replacement knob is available from the following link:
www.euro-pro.com/europro/productdetail.aspx?pid=1D76CC6A-4A86-4D6B-8120-7DB204F16DF4(Euro-Pro+Base+Catalog)
You can also get a user's manual if you need one.
If you found my assistance valuable, please give me an appropriate rating. Thanks for using FixYa!
Oct 19, 2008 | Euro-Pro EP278 Bravetti Platinum 1500...
How can I replace a damaged timer control knob?
i was reading up on this item and i came across section where they mentioned you have to purchase 4 complete different replacement knob boxes or panels
heres the link boy this product is having one heck of time
http://www.reviewcentre.com/reviews105062.html
Dec 01, 2007 | Neff U1661 Double circotherm super...
Admiral AAV7000A Logo
136 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Marvin
Marvin
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
