Won't turn on!
Check your fuses. Common ones are red 10amp under the hood, red 10amp under the steering column, cylindrical on the constant power wire (usually yellow) from the back of the stereo. Also, a test light or multi meter would be optimal on checking which wire is or isn't recieving power. You ground your negative terminal on your multimeter an
SOURCE: How do I remove a Clarion DRB4275 head unit??
I am not familiar with this particular model but the majority of Clarion Radios require special flat Clarion Extractor Keys.
see examples here
http://www.nexxia.co.uk/Car_stereo_spares/Extractor_keys/clarion.htm
This site shows how to extract a Clarion from a Peugeot (I expect yours will be similar)
http://www.fitaudio.com/?View=entry&EntryID=56
These are usually readily available on Ebay or your local Car Radio / Audio Store
See examples on Ebay.... Items 150297896696 and 360091776968
It seems the problem is the "SRC" key. It sporadically works, but mostly doesn't work!
