Question about Waring DF100 Deep Fryer
Removing the lid from fryer
The instructions say that the "removable lid is dishwasher safe." I would love to run it through the dishwasher.There is nowhere in the instructions, however, that says how to actually remove it. Any suggestions?
On each of the hinges where the lid attaches, if you look at it from the back there is a catch tab. If you push the little tab, the hinge will release. You should feel it give a little when you push in...you shouldn't have to push so hard like you are going to break it, but you do have to push in deep enough to release the catch.
Posted on Oct 11, 2009
How to remove the filter from a smart clean fat fryer
how do tou take lid off tefal smart clean fryer for cleaning
Sep 02, 2010 | Tefal Smart Clean Deep Fryer
I need a filter for My deep fryer
I have the Euro Pro F1066 and love it. But, I called the Euro Pro people and found that there is NO replacement filter. If you go to their site and put in the model number, it shows only the following accessories can be ordered. This is from the Eoro Pro site:
Accessories
Oil Container & Lid
Replacement Fryer Basket
Replacement Control Panel with Element (1700 Watts - U.S. unit)
Power Cord
Replacement Basket Handle
Call 1-800-798-7395 to order
So, the only way to get a new filter is to purchase the Oil Container & Lid which would come with a new filter in the lid. I am trying to figuire a way to rework the original filter but have had no luck so far. I hope this helps answer your question ;-)
Jul 31, 2010 | Euro-Pro F1066 Deep Fryer
How to remove the drawers of fisher paykel dishwasher dd603
Refer to page 7 step 2 for instruction on removing the drawer (tub).
http://www.fisherpaykel.com/admin/pdfs/pdf_installations/526607O_DD_Install_USw.pdf
I suppose you want to get to the flood switch at the base of the dishwasher and dry it out.
Make sure the mains power is turned off.
May 17, 2010 | Fisher and Paykel 23 in. DD603H SS...
Can't remove the oil reservoir to clean it.
We had same issue. My husband just unscrewed and removed the metal plate from the bottom of the unit looking for a solution. The reservoir cannot be removed. The heating coil is permanently attached (welded?) to the bottom of the reservoir. It is obvious, now, that the reservoir is not intended to be removed.
Ignore the statements in manual that say the oil reservoir is dishwasher safe and not to remove it until it's cool. They do not apply to this model.
Dec 28, 2009 | Oster Kitchen Appliances - Others
I have a mdl CZF725 rival deep fryer and the lid will not stay down.
The problem is that the heating element and front control panel is not sitting in correctly. Remove the heating element/front control panel. Grab the heating element and gently pull it away from the control panel. Use care as you can break the elements off of the control panel. Reinsert and attempt to close the lid. If it does not close, then repeat this process being careful to not over bend the elements. The lid uses two plastic extensions to latch to the control panel and if the control panel is extended away from the fryer front, the lid will not latch. Also the fryer will not work as there are sensors in the control panel to sense if it is close enough to the fryer.
Jul 18, 2009 | Rival Kitchen Appliances - Others
Can remove breadman pro lid
You might have figured out how to do this by now, but here's the answer anyway.
There are two slots that the lid's hinge pins slide into.  To remove the lid for cleaning or otherwise, tilt the lid at a 45-degree angle and pull it towards the front of the machine.  To put the lid back, simply reverse these directions.  CAUTION: Make sure that the hinge pins are completely inserted into their respective slots before carefully lowering the lid.  Not doing so could bend them or break them off and would ruin the lid.
Feb 14, 2009 | Breadman TR875 Bread Maker
Rival Deep Fryer
used the correct cord. have a Fry Daddy and the plugs a very similar but are not interchangeable. Thank you for the responce
dan71
Feb 27, 2008 | Kitchen Appliances - Others
How do I remove lid for cleaning
With lid in open position just pull it straight up and off.
Feb 12, 2008 | Rival CF153-WM Deep Fryer
Lost my instruction booklet
website is www.rivalproducet.com . . . but did not find a manual . . . ours come with every other page blank . . . not much help . . .
Jan 16, 2008 | Rival CF153-WM Deep Fryer
Cleaning
From http://www.rivalproducts.com/help.aspx?helpNav=1: How can I clean my fryer? - Unplug from outlet and allow unit to cool. Always turn control to OFF then disconnect plug from wall outlet BEFORE disconnecting BREAK-AWAY CORD. - Clean the outside of the fryer and lid with a damp cloth. CAUTION: Do not use abrasive pads or alcohol to clean the fryer. - Remove basket handle, if one is included. Frying basket can be washed in hot soapy water. - Rinse and towel dry carefully. - Pour out oil and discard properly. - Wipe the inside with paper towels to absorb excess grease. Wash interior of fryer with hot soapy water. Rinse and dry thoroughly. CAUTION: Never immerse the fryer in water or wash in running water. If you own a fryer with a removable bowl or other removable parts, refer to the Owner?s Guide for your specific fryer to determine which parts can be cleaned in the dishwasher.
Mar 08, 2007 | Rival CZF630 Deep Fryer
Waring DF100 Deep Fryer Logo
124 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Robert Weir
Robert Weir
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
