Question about Philips 32PW8608 32" TV
Hi i got a philips tv model no is 32pw9527/05 got a east/west fault
  • Anonymous Nov 30, 2007
    image is all the time 4/3
    New Friend:
  • 76 Answers
Change horizontal linearity coil and change 8pin EW ic.
Posted on Aug 24, 2007
SOURCE:
Poor east west correction on fenice f28ac monitor
ahhh..that's in the menu settings on front of panel of monitor...should be easy to access..
Apr 29, 2008 | Computers & Internet
I WORKING ON LOGIK TV LK74PF LOPT WAS FAULTY NOW IT HAS AND EAST WEST FAULT.THE EAST WEST TRANSISTOR 2SC5248 IS SHORT CIRCUIT.REPLACED IT BUT IT BLEW AGAIN.THE TRANSISTORS THAT DRIVE IT 2SC1815 AND...
Hi, The Logik lk74pf flyback that you replaced. What did you replaced it with. I also have the same tv with the same problem. Also found a 1k resistor blown in the supply line from the flyback to the vertical deflection circuit.
Sep 12, 2013 | Cameras
East west cuts both left and right ends.
What is the brand name to your TV? Model number? It sounds that horizontal width of the picture is less than normal. This can be due to a fault to the switched mode power supply system circuit to your TV too. If you wish to get more details, surf this link. http://electronicshelponline.blogspot.com/ There are more than two thousand and five hundred posts. All are related to television and other domestic electronic equipment service help. More than Ten Lakh viewers cannot be wrong.
May 21, 2013 | Televison & Video
My 27inch Sanyo tv screen is shrinking-sides have curved black is=nstead of the full picture. Can you advise what this might be?
That is caused by an East West Modulator fault. That will give you an Hour Glass picture.
Check for dry joints around the line output stage and faulty driver transistors.
Hope this helps.
Dec 17, 2010 | Televison & Video
Where is samsung s630 digital camera's service center in Mumbai?
Purnima Sales Services Centre
Electronics & Home Appliance
Goregaon East,Mumbai
Fine Tune Service Centre
Andheri West,Mumbai
Balaji Electronics
Electronics & Home Appliance, Cellphone Repair
Chembur West,Mumbai
Maya Steel Centre
Andheri East,Mumbai
Sep 04, 2010 | Samsung Cameras
Rca f35670mb
hi there.im not familiar wih the model,but your fault lies in the east west correction circuit.excessive width usually means a short circuit e/w modulator diode,with the curved sides.normally,a narrow picture with curved sides points do dry jointed/open circuit polyester capacitor.if a firm slap has an effect,then its most likely a dry joint which makes for an easy life.the vast majority of east west correction circuits are based in tle line output stage,and generally not complex to fix.hope this helps,regads,steve.ps. look for s/c by 299 and by 228 diodes,check those..
Nov 05, 2008 | RCA F35670MB 35" TV
Hello.We were given a grundig tv. ws70/3020. We cannot find the information,regarding the pin cusion. The picture seems to bevell all the time.Would you be kind enough to let us know how to fix this...
Hi there!
My guess on this is that you have an East West fault on the set and therefor you have the Pin Cusion or bowing on the sides. The settings are usually only available in the service mode. I do not have the info on hand but I will check wether I have for this model. Regards, Jus004
Mar 11, 2008 | Televison & Video
Black circles on both sides ov tv
This fault is referred to as an East-West pin-cushion fault. Depending on the make and model, it can mean that some capacitor(s) have failed (dried-out) or a single medium power transistor or both in the pin-cushion correction circuit have failed.
In any event it isn't a very big problem to fix. A competent technician nearby ought to sort it out quickly. Also, if you area tech then please post additional information on the make and model and you'll get more technical data. Good luck.
Jan 18, 2008 | Recoton Advent Advent HT3251A TV
Vertical
Hi. Im not at all familiar with your make of TV set, I am in the UK we dont have RCA make of TV. But what you are discribing is an East/West fault this is a common problem on all TV sets. It could be quite a few things that can cause this eg (make adjustments in engineers mode, E/W coil burnt up, Resistors or caps burnt up) Its not an easy repair for a novice to tackle It requires fault finding & being able to read A meter. Usually not exspensive to put right by A shop.
Sep 15, 2007 | RCA G35851LA 35" TV
Philips 32PW8608 32" TV Logo
132 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
