Question about Teac Floppy Drive 235HF Internal Floppy Drive
FD-235HG Hai, I am trying to fix this drive in PC-9821 XB10/j8 NEC model computer. the computer needs 1.2 mb floppy drive. My drives are currepted. I found FD-235HG is a 3 mode floppy drive and can solve the problem. I don't know the jumper setting to make 1.2 mb. 3 lines of pins and 7 lines length wise pins are there. 1 line is without pins. can you please advise me. regds, rajkr
    Sergeant:
    Champion:
  • 317 Answers
1.2 MB? is this a 5 1/4" drive you are talking about?
You need an older floppy IDE ribbon. No drivers needed for that.
Posted on Dec 10, 2007
  • Baja Data / Jay Arias-Chavez
    Was your problem solved? Do you have more information or questions?
    The more information you provide to us, the better we can help.
    If the solution was good, please rate it accordingly! :D
    Thanks!
Driver for Teac FD-505 Combo Floppy Drive?
You may have to enable 'A' drive through the bios. Depending on the bios, you need to hit F1 or F2 or F10 at initial start up. You can hit all three at once and get into the bios. Then navigate your way through the bios to find where to enable and disable drives.
May 21, 2012 | Teac ZDS/ Combo FD-505-3XX Floppy Drive...
Hello! I have a Floppy Drive FD-235HG-C332 manufacturer TEAC. I want to know what data capacity (Operations modes) has my device: 720Kb, or 1Mb, or 1,44Mb, or 1,6Mb, or 2Mb. There are jampers, placed...
Your TEAC FDD (floppy disk drive) is a Tri-mode device (720 KB, 1.2 MB, and 1.44MB)
The "235" part of the model number indicates the drive's form factor (size) is 3.5 inches.
The "HG" part of the model number indicates that the FDD is a Tri-mode device, with the 3 modes
given above.
The manufacturer notes that it has no jumpers, but every FDD I've ever seen has jumpers for
bus master/slave selection. Either master or slave will work.
Here's the manufacturer's web site URL for your TEAC floppy disk drive:
http://www.teac.com/DSPD/support/floppy_drives/fd235hg_id_your_drive.htm
Here's the info on the NEC FD 1137C drive:
Enclosure Type Internal
Interface Floppy (IDC)
Platform: PC
Technical Features Capacity 1.44 MB,2.8MB,360MB,720KB,1MB,640KB
Minimum System Requirements:
Operating System Microsoft DOS • Microsoft Windows 3.1 • Microsoft Windows 95 • Microsoft Windows NT
Form Factor: 3.5" floppy disk drive
Here's the best info I found on your NEC FD 1137C Floppy disk drive:
http://www.aliexpress.com/fm-store/602209/210081532-394871196/NEC1137C-DATE1992-floppy-Adaptive-720K-1-44M-120M-Capacity-120M-40PIN-Interface-3PIN-Jumper-FD1137C-NEC1137C.html
May 13, 2011 | Teac Floppy Drive 235HG (FD-235HG) Floppy...
I need the driver of NEC FD 1231H floppy
You can download the driver from Windows Update.
Plug the floppy drive in to your computer/laptop. Found new hardware wizard should pop up. Just follow this guide & it should work.
http://support.necam.com/oem/fdd/w2kusb/
Mar 11, 2011 | NEC Slimline (FD1231H) Internal Floppy...
My floppy drive does not seem to recognise that a floppy disk is inserted...after inserting a floppy disk and trying to run it ......it says ' please insert disk into drive A' ? any advice would be much...
Hello there!
Well, you 1st should check is your floppy drive properly insterted into your pc mb. Open your hardware check the joins on your FD(floppy drive) if thats ok, assemble the box. Next move is to check is your FD even enabled in ps BIOS. Open your bios acess general settings, and you should find setting flopy disc 1,28~ enable/disable.
After that if you still experience problems you should thinking about usage of usb pen drives, since floppy drive systems are really outdated, as I know there never been any drivers for that system , so those steps should solve your problem.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Samsung SFD 321B (SFD-321B) Internal...
New Sabrent external floppy disk drive causes
Try to connect the Sabrent in some other computer.
If it works, then the hardware is OK.
Nov 11, 2009 | Computers & Internet
Drive wont read
-is it correctly detected on your operating system.
-if yes please turn your computer of and turn it on after couple of minutes and try again.
-try to find floppy disk cleaning kit and apply it on your device.
-you may try to clean it`s lens using a piece of cotton with spirit.
-do not try to open your computer case if you don`t have knowledge on computers.
Oct 14, 2009 | Teac Floppy Drive 235HG (FD-235HG) Floppy...
I am unable to access my teac FD-05PUW usb floppy disk disk drive it come up in my computer as disk B but when I try to assess the drive it tells me the disk is not formatted but when I attempt to format...
Solution 1.
Try using the Installation CD or Utiltity CD that came with your drive to format it.
If theres a Utility CD then install it on your computer and try formating it from the utility application.
If the windows error messages still persist then try formating it with the windows default options or NTFS option.
Apr 26, 2009 | Teac FD-05PUB External Floppy Drive
Need a new one
Any brand name floppy drive will work just fine. Does not have to be the exact same model or model number.
You can pick these up at either any computer distributor online (www.newegg.com , www.tigerdirect.com , other ones out there) or almost at any place that sells computer related devices (walmart, best buy, frys, local small computer shop). The plugs/pins are all the same in the back of the floppy, so it is completely interchangeable.
Apr 16, 2009 | Computers & Internet
Teac Floppy Drive 235HF Internal Floppy Drive Logo
576 people viewed this question
Top Teac Computers & Internet Experts
Starnley Johnwells
Starnley Johnwells
k24674
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
