Question about Hotpoint Ultima WD72 Front Load Washer/Dryer
Hotpoint Ultima WD71(probably the wd72 except in white)
Hi, after a wash cycle door did not open. the lock symbol is in the display. When switched on display says "Select Programme" but lock symbol is still on and door won't open. All programmes start & finish as they should, but it's no good if door won't open. Can you please help,regards maltaaman
  • maltaaman Aug 23, 2007
    Hi gittos73, dont live there yet but got a flat there, selling our house here and moving hopefully in the new year, Why you not there, surely you dont like it in UK. Thanks for info but water drains ok and all programms work with the well washed clothes stuck inside, maltaaman
  • Anonymous Mar 20, 2014
    'door open' always showing even when shut
    Novelist:
    Champion:
  • 244 Answers
Hi there what u can do is take your drain hose and place into a bucket water will come out the door will release now check the pump and make sure that it is not blocked up with anything if it isnt check the drain pipe that is under the washer in the middle of the drum there will be water in there but check inside if anything is inside there it will slow down the empty programme and will not let the door release do u live in malta then m8 as my dad is maltease and im half
Posted on Aug 23, 2007
  • peter gittos
    peter gittos Aug 24, 2007
    no hate it here but i had an accident and cant afford to be there ill go with my son next year what u can do to open the door is undo the screws at the top of the lid should be either at the side behind a small clip or at the back once youve got the lid off check the motor and see if there is a cable going to the motor if there is feel behind the clip there should be a small safety clip take it out now push the cable down slowly there should be a click each time ou push on it. with each click press the door release catch if it doesnt open thendo another click and it will open the door if not then feel down the front of the cabinet were you will find the door catch theres a small lever you can pull that will open the door make sure you unplug washer they still can have a current going through even when switched off at the plug have a great time m8 wish i was you loved to be out off this country its getting stupid over here laws for the criminals we need to opt out of the EU
Where is the 7.5 amp fuse in the hotpoint WD71?
the 7.5 amp fuse is near the power module, This fuse is on the motor circuit to protect the circuitry of the power module. If it blows the motor won't work .hope this helps
Dec 22, 2009 | Hotpoint Ultima WD72 Front Load...
Door stays looked on washing machine
you will need to remove the top cover and get a screwdriver to move the door latch over. it's a job for an engineer really as you have an electrical problem anyway.
Jan 27, 2009 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD71 - floods on drying programme
you may have a hose loose or holed at the inside rear of the machine.
Jan 04, 2009 | Hotpoint Ultima WD72 Front Load...
Wd71 with e30 code on display when i try to use the dryer
try changing the thermostat located on top of heater in top of machine
Nov 08, 2008 | Hotpoint Ultima WD72 Front Load...
Wd71 error 34
get a washboard and a jug
Feb 14, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima extra WD72
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Feb 28, 2007 | Hotpoint Ultima WD72 Front Load...
Check water supply error F11
pump cannot be activated:check pump , connections and wiring
Sep 12, 2006 | Hotpoint Ultima WD72 Front Load...
Hotpoint Ultima WD72 Front Load Washer/Dryer Logo
637 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
Eric Taylor
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
