Question about Uniden CEZAI998 Phone
No electrical outlet available for the base station (wall mounted)
Wanting to know if the base unit for this Uniden CEZA 1998 needs only a telephone connection. I want to mount the base onto an existing phone jack in my kitchen, where there is no electrical outlet nearby. I can only plug in my phone into the phone jack, so the phone I get must have a caller i.d. (and answering machine..but that is not necessary)that is only battery operated. The other handset (the cordless one) will be going (obviously) next to an outlet. Please advise. Thank you. -AndrewBear
  • gbloom707 Dec 02, 2008
    I am moving into an apartment that has the old fashion plate for the phone to plug into on the wall and no elecrical outlet. I still want a cordless wall mountable phone. what can I do?
  • Anonymous Dec 07, 2008
    In the location where I want to place my phone I have only a phone jack and no electrical outlet. However, I would like to have phone with an answering machine. Does one exist that does not require an outlet? The phone does not have to be cordless.
  • 625 Answers
Most cordless phones need some access to 120 volt power to recharge the internal NiCad batteries. It wouldn't be cost effective to have on hand a bunch of charged batteries that you'd replace on a daily basis. they got to be charged up eventually.
Posted on Aug 23, 2007
    Sniper:
  • 84 Answers
AFAIK there is no answering machine that will work without being connected to an electrical outlet, neither will the caller ID. The corded handset on the base unit will work, but that is it. The base uses the AC power to transmit and receive to/from the cordless so you won't be able to use the cordless handset with out the base being connected to AC.
Posted on Feb 27, 2009
Hi i have a uniden ZO68 i want to add another hand set to this i have brought another uniden ZO68 second hand hand set and i can't set it up can you help me please
did you get the charging base with the hand set
is it a charging base or a base station base
if it is just a charging base , follow the instructions as how to get the base station to recognize the next phone
if it is a base station, probably won't work as you will have 2 base stations trying to work and that will create conflicts
talk with a telephone technician to see what can be done
Oct 30, 2016 | Uniden Lands Phones
Lost phone manual, uniden d2997
I have a standard trouble-shooting routine for cordless phones. 1) Remove the battery from the handset (from all handsets for a multi-handset version). Then unplug the power cord from the base and wall outlet and also remove the telephone cord. Wait a few minutes and then reconnect the power and phone line cords. Reconnect the battery (ies) for the handsets. Make sure this connection is tight. Then make sure that the battery is fully charged (15 hours before first use) and register the handsets if needed. This is done by putting each handset onto the base in order for the D2997. Wait about 30 seconds for each one until you see the Handset Registered message. Make sure that you are within range of the base.
Next try a different telephone (RJ-11) phone cord between the base and the wall jack. Also check if the power adapter for the base is warm. For the next set of tests, I like to use an old corded telephone. Using a different phone, check if you get dial tone at the jack. If there is a dial tone, then the problem is with the Uniden phone. If the above trouble-shooting didn't help, then contact Uniden. These phones aren't meant to be user serviced.
If you do not have a normal dial tone, try another jack on the same telephone line. If there is dial tone at another jack, then you have a problem with the first jack. Otherwise find where your telephone service comes in. If you have a fairly new service, you'll find an RJ-11 jack. Plug your test phone into the jack and test for dial tone. If you have no dial tone or can't test your line, call your phone company. They will fix any outside problem for free. If it is an inside wiring problem, look at the visible wiring and determine if the wires are damaged. Open the jack (if only one is bad) and check for loose wires. There are two types of jacks. One secures the terminal wires with screws and the other uses a punch-down jack. For the screw type, strip additional insulation from the conductors, if needed, and then reconnect them. For the punch-down type, you will need the punch-down tool. It is available at many hardware stores in the wiring section. Use this diagram to check your jack wiring: http://www.lanshack.com/wire_phone_jack.aspx . If you can't see an obvious problem with the wiring, you may want a professional to deal with the wiring in the wall. Your telephone company will do this for a fee.
Uniden has the manuals for their DECT phones on their site: http://www.uniden.com/bin/venda?ex=co_disp-view&bsref=uniden&scat=dectphones_mnl . The manual for the D2997 is available here: http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D2997om.pdf .
I hope this helps.
Nov 26, 2011 | Uniden Lands Phones
There is a hum on both lines as well as the base station. How do I get rid of the hum? EX13226
Hello! Do you have another telephone that you can plug into the wall outlet that the base is plugged into? If you can I believe you will still hear a hum...When a resistive ground, due to wet cable, is on the tip side of the cable pair that feeds your wall jack a "hum" will occur...Even though you are using digital phones there is still a telephone cable from the base to the wall jack...Open a trouble report and have the cable pair tested by a technician...
Guru...Saailer
Dec 30, 2010 | Uniden Cordless Phone
Uniden 5.8ghz cordless W/2handsets has no dial tone cannot call out or recieve calls
There can be a lot of different things that could cause this. The first thing I would do is disconnect the telephone cord from the Uniden phon eand connect it to another telephone and see if you get a dial tone from it. If you do then we know that the telephon eline and the cord are OK so we go back to the Uniden telephone. Next, does the unit light up when you plug it in? are you sure that the telephone is getting AC Power? Are the displays on the handsets working? Does the handset display show "Handset XX" or does it show "Searching"? If it shows "Handset XX" then the base unit is getting power, if not the base unit may not be getting power.
If the base unit is getting power and the handsets are working and the power cord and jack were proven good by conecting another phone to them, then you would need to call uniden Customer Service for further trouble shooting or repair/replacement. the number is 1-800-297-1026
Jan 26, 2010 | Uniden Cordless Phone
There is no dial tone. cannot call out or recieve calls
• Check both ends of the base unit telephone line cord.
• Make sure the AC adapter is plugged into the base unit and wall outlet.
• Disconnect the AC adapter for a few minutes, then reconnect it.
• Reset the digital security code
• Make sure TALK is pressed.
Jan 26, 2010 | Uniden 5.8GHz Cordless Phone
No dial tone after an electrical storm . I had to replace the AC adaptor. Everything else works.
Having to replace a power adapter indicates a pretty severe power surge that could easily have destroyed your Cordless Phone Base station delicate electronics!
But to ensure that it is not a faulty telephone line, plug a working corded telephone directly to the phone wall jacket and see if you get a dial tone.
Hope it helps: let me know how you go.
Jan 13, 2010 | Uniden Cordless Phone
My Uniden TRU9485, all units (4 in all) get a dial tone, but will not dial out on TONE dialing. If I change it to PULSE, it works. These are about 1 year old and just noticed this today. Is it the phone or...
Ok, comming from a Cable Tel Technician, this is most likely your telephone service.
Contact your Telephone repair for them to reset your tel service (this will most likely be due to a digital service outage and will need to be repaired.)
An option is to try a cheap wired phone in the outlet experiencing the issues and attempt the problem again. if this rectifies the issue, remove the phone from the wall outllet(electrical) and wait a few moments and also remove the batteries for 30 seconds total.
If all the above does not fix this issue, attempt calling the manufacturer for a more abrupt powercycle method to reset the base unit (Transmitter)
Sep 02, 2009 | Uniden TRU9485 Cordless Phone
My tru9480 handset is saying connecting but won't connect and won't get a dialtone
Reset Procedure for Cordless Phones
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
Jun 13, 2009 | Uniden TRU9480 Cordless Telephone
We can't get dial tone on any of our 3 uniden phones
The base station must be plugged into a live jack. Take a known good telephone and plug into the wall jack. If that checks good use the same cord to hook up the base. If the base still doesn't work, pull the cord loose and look into the jack hole on the base and see if the wire connections are out of alignment. If they appear straight then the base is in need of going to a repair shop.
May 27, 2009 | Uniden TRU-8860-2 Cordless Phone...
Uniden CEZAI998 Phone Logo
794 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
